Old 09-25-2012, 08:28 AM   #30751
bash3r
bash3r's Avatar
Oddometer: 1,596
Send a message via ICQ to bash3r Send a message via AIM to bash3r
Originally Posted by Crawdaddy View Post
.I like these sorts of easy fixes.....especially since my ~400 mile Primm/Bar 10 ride is a short week away.......lot's of wide open riding.....that ride is meant for the WR250R as opposed too my 300XCW singletrack weapon.....
Awesome Chris... glad to hear your WR will make the trip!
08' Yamaha WR250R
08' Kawasaki Versys
My ADV Website
| ADV Legends
bash3r is offline   Reply With Quote
Old 09-25-2012, 09:23 AM   #30752
Krabill
Krabill's Avatar
Oddometer: 3,520
Originally Posted by theMISSIONARY View Post
what is it with after market parts
Just finished putting a nomadic cycle rack on and the bolts are to short by at least 10mm.....there goes another $9 in bolts and time stuffing about
then i moved onto the Flapper,AIS and IMS 4.7 install
AIS went well with the little kit from Krabill
then the IMS now this went well until i went to put the tank on and the vacuum hose none of the instructions(looked it up on the Forum) tell you that if your removing the flapper just use that hose instead of cutting it and putting the "T" in no problem i just put the little black block-out on the "T" i put the "breather hose into the steering head as i don't have the "canister"(cali model thing?) on my bike
then after i put the tank in place none of the bolt holes line up and it touches the radiator guard and the cover on the other side(i just cut it to fit)
things wont be any better with Fuel and the tank wobbles on the mounts, so its going to "rock" from side to side a little eventually making a hole in one or the other
bike is still in bits wondering if its just me that has these issues
are there any Radiator guards that will fit WITHOUT touching
I cut some spacers to go under my tank mounts out of 1/4" aluminum. Raised it up enough to clear everything.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 09-25-2012, 09:26 AM   #30753
jon_l
Southern Ontario
jon_l's Avatar
Oddometer: 1,982
Originally Posted by freetors View Post
When I changed my front sprocket I did reuse the nut but I put a red paint line across the countershaft and the nut so I can visually see if it has loosened.
Good idea. I'll punch mine, and do the same.
'09 Honda CBF1000; '09 Yamaha WR250R
jon_l is offline   Reply With Quote
Old 09-25-2012, 11:16 AM   #30754
jon_l
Southern Ontario
jon_l's Avatar
Oddometer: 1,982
I read a post from you about this before GSBS, and yours is a valid point.
I like being able to see the sprocket and front of the swingarm & seal-guard, and I like that the Sandman part doesn't trap dirt.
I will re-punch the flange and monitor my C/S sprocket for tightness, but the swingarm / seal guard issue causes me more stress than this nut, which is simple enough for me to understand, and to monitor. The chain eating swing-arm issue seems to be caused by:
- chain too loose
- chain too tight
- kinked chain
- too small front sprocket
I'm not sure anyone really knows.
Jon
Originally Posted by GSBS View Post
I've decided to keep the plastic OEM countershaft sprocket cover, even though I much prefer the look of the open aftermarket ones.
Recently when I removed my cover to inspect the sprocket the nut was only finger tight. Turns out the C-shaped keeper that's made into the OEM cover was the only thing that prevented my CS nut from spinning all the way off!
This time I took extra care to be sure to use the recommended Locktite, correct torque value and to carefully stake the sleeve on the CS nut into the detents on the shaft.
If the WR had the conventional keeper washer that many other bikes use - the kind you bend (dog-ear) over onto one or more of the sides of the CS nut, I'd for sure go with an aftermarket case saver.
But the poorly engineered (IMO) system of "staking" the collar on the nut makes the keeper that's made into the OEM cover mandatory for me.
My 2¢
Old 09-25-2012, 11:25 AM   #30755
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,447
- chain too loose
- chain too tight
- kinked chain
Jon
Jon,
My swingarm guard was chewed up in a few thousand miles after I geared down using a 12T CS and the stock 43T rear. I'm now running a 13/47 and have had very little wear on the replacement swingarm guard.
And FWIW, I'm in mud on my WR fairly often and haven't had any issues with dirt, mud, debris building up in the plastic OEM CS cover.
GSBS is offline   Reply With Quote
Old 09-25-2012, 12:29 PM   #30756
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 8,300
Originally Posted by RichardU View Post
... I think the simple option is to pull the engine.
...best way is to un-bolt the front downtubes than?
'08 R1200R / '10 WR290X/R
'81 R100RS Rattlecandy Red
'06 950 ADV Orangeboom
'05 R12GS Wedding Bike '91 R100GSPD Derelict
Rapid Dog is offline   Reply With Quote
Old 09-25-2012, 12:54 PM   #30757
BarKnee
BarKnee's Avatar
Oddometer: 58
I recall seeing posts where using the non-recommended vacuum hose caused problems with the aux vacuum pump operation. If I understand correctly, the recommened hose has a pulsed vaccum, the other hose has constant vacuum. The pulsed vacuum line allows the vacuum pump to operate correctly.
I guess you will know when the fuel level gets below the well in the stock pump.
BarKnee is offline   Reply With Quote
Old 09-25-2012, 12:54 PM   #30758
Moto da Vinci
Alive & Living
Moto da Vinci's Avatar
Oddometer: 60
Originally Posted by Rapid Dog View Post
I'm getting an Athena kit in today.
Pulled the bike down last night.
Lots of stuff in the way of the head/cylinder, wire loom, tubes, cables.
Those aren't a problem.
Do you remove the airbox, and if not, how do you get the throttle body out?
Just disconnect the rubbers and pull it up through the frame?
Doesn't seem to be much room in there...
This one way to do it and I am sure it would be worth the read.
http://advrider.com/forums/showthread.php?t=621532
Get on your bad motor scooter and ride!
Moto da Vinci is offline   Reply With Quote
Old 09-25-2012, 01:25 PM   #30759
Rapid Dog
Rapid Dog's Avatar
Oddometer: 8,300
...gonna do that as soon as I get home from my day job, which is cruising ADV while the pics are blocked...
Old 09-25-2012, 01:31 PM   #30760
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 1,642
i'll give that ago after work today it was late by the time i finished putting the tank on but i was thinking at the time it might be the best option
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 09-25-2012, 01:33 PM   #30761
theMISSIONARY
Oddometer: 1,642
Yeah i read that on the WR250r forum also but there was no definitive answer so i'll wait and see
Old 09-25-2012, 01:53 PM   #30762
mwgak
Oddometer: 14
I have run the big IMS on several bikes and never had trouble with the pump. I tap into the same port that you cap when you remove the intake flapper. Make sure you dont kink the line (I tie wrap a nice loop) when you reverse direction up near the tank.
mwgak is offline   Reply With Quote
Old 09-25-2012, 02:01 PM   #30763
theMISSIONARY
Oddometer: 1,642
Originally Posted by simmons1 View Post
My IMS tank hit the radiator guard as well so I removed the guard and I am just using the OEM plastic one. I figure the tank itself gives a fair amount of protection.
on mine the plastic one is the one that touches.... i am going to see what i can do with some rubber latter
Old 09-25-2012, 06:54 PM   #30764
Jolly705
Jolly705's Avatar
Oddometer: 2,137
Send a message via AIM to Jolly705 Send a message via Yahoo to Jolly705
Has anyone mounted a WR250X set of SM wheels to a WR250R? If so what mods need to be done? Thanks again.
Jolly705 is offline   Reply With Quote
Old 09-25-2012, 10:33 PM   #30765
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 2,183
Send a message via Yahoo to indypup
Nut Cracker 200 D/S Hero Hill Video
If there's no video...it didn't happen
2007 ST1300, 2008 KLR650, 2008 WR250R, 1995 Ninja 250R
Only a dog knows why a motorcyclist hangs his head out the window! Be real, be whole, be innovative.
indypup is offline   Reply With Quote
Times are GMT -7.   It's 11:08 PM.
