Old 09-26-2012, 06:07 AM   #30766
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,753
Originally Posted by indypup View Post
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 09-26-2012, 07:03 AM   #30767
Shawnee Bill
Shawnee Bill's Avatar
Oddometer: 2,114
So did you ever make it over the top?
Shawnee Bill is offline   Reply With Quote
Old 09-26-2012, 07:23 AM   #30768
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,764
This hill took me three attempts to climb with nearly the same results twice!
The first two shots were attempted in first gear which caused a bit too much wheel spin. The successful third attempt was made in second gear with more traction hook-up.
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 09-26-2012, 07:32 AM   #30769
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,250
Put an MT43 trials tire on the back.......run it at ~8PSI (with an Ultra Heavy Duty tube and rim lock)......and you'll cruise right up hills like that without ever looking back as the knobbied/traditionalists slip and slide all over the place.....
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 09-26-2012, 07:48 AM   #30770
Shawnee Bill
Oddometer: 2,114
Interesting. I am just now beginning to want to try a MT43, problem is I'm stubborn and just 2 weeks ago bought a new knobby. Kinda wish I could take it back but I don't think I can, I'll have to use it up then try a MT43.
My real concern about the low air pressure is pinch flats, SE Oklahoma has a lot of rocks and we get a lot of pinch flats down there. How do the MT43s with 8psi stand up to that or do you pressure up a bit more for rocks?
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Old 09-26-2012, 07:51 AM   #30771
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,572
I got my Athena 290 kit in yesterday.
Didn't expect it but it came with the Athena fuel module.
I have an FMF fueler.
Wonder if I should just stay with the FMF or use the Athena...
flapper gone/drilled airbox w/K&N filter
Powerbomb header/stock pipe opened up a bit
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 09-26-2012, 07:56 AM   #30772
soupknotzee
soupknotzee's Avatar
Oddometer: 245
Mt43
+1
I love the MT43 (except the front on SoCal grooved concrete freeways is the squirmiest tire ever- A real thrill ride going 70 with traffic)
So convinced that I even got a set to go on my 300XcW when my Maxxis Deserts are done.
They take all the drama out of steep rocky climbs where a knobbie just bounces and spins.
soupknotzee is offline   Reply With Quote
Old 09-26-2012, 07:58 AM   #30773
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,764
Hmm, it had rained the night before so I put a knobbie on instead of the MT43 which I took off. :(
I just really suck because here is an attempt on a rocky hill with an MT43.. :(
Old 09-26-2012, 08:05 AM   #30774
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,572
Question
Originally Posted by soupknotzee View Post
+1
I love the MT43 ...
What size MT43's you boys running?
Old 09-26-2012, 09:29 AM   #30775
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,250
That's why I run 4mil Bridgestone Ultra Heavy Duty Tubes.....it's like stuffing a tire inside a tire
Plenty of Rocks in So. CA. (this pic is from Big Bear Lake area)
Old 09-26-2012, 09:48 AM   #30776
soupknotzee
Oddometer: 245
Mt43
4.00x18 & 2.75x21
Keep in mind its a tall tire. It will fit but is close to plastic shock mud guard on the inside of your swing arm so proper chain length is a must. This isn't a problem as you will also want to change your gearing to suit the new tire diameter. I personally went with the 13/47 but others have gone 13/48 or the equivalent with a 14CS (52 rear I think?) and a longer chain but at the moment can remember how many links (plus 2 I'm guessing)
I always run 11-12 PSI at all times whether on street or dirt. feels like a slot car on street. So Fun!
No rim locks and Slime in both front and rear standard tubes. Next time around I would like to try Tubliss setup if I can muster up the courage to crack open my wallet to the $200+ investment
soupknotzee screwed with this post 09-26-2012 at 09:57 AM
Old 09-26-2012, 09:52 AM   #30777
Crazy_Dave
Back'in it in
Crazy_Dave's Avatar
Oddometer: 582
520/ 112 link
It’s easier to apologize then it is to ask permission.
01 R1-01 CBR929-08 WR250R-92 DR650 (24-7 365)-07 F650GS-05 200 EXC-03 450EXC
Crazy_Dave is offline   Reply With Quote
Old 09-26-2012, 10:08 AM   #30778
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,764
4.00x18 & 2.75x21
Tubliss system has worked great for me so far. I run about 10PSI in each tire. I had an inner tube in the tubliss system split on me and Nuetech sent me two rear and two front tubes when I called about the tube splitting. That was pretty cool because all I was expecting was for them to send me a new rear...
indypup screwed with this post 09-26-2012 at 10:39 AM
Old 09-26-2012, 10:18 AM   #30779
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,572
Taller rear, taller than a 606?
I had a taller rear tire before, I think a Michelin AC-1- Enduro, a monster.
The front end pushed in the dirt and was kinda weavy on the pavement.
I'm on the 606s now and still at times it feels abit weavy on the pavement.
I attributed it to too tall a rear as the smaller T63's first on the bike had no problems.
I have my forks about 7mm up in the clamp as suggested by my suspension guy.
Any negative street habdling from you guys on the MT-43s?
Old 09-26-2012, 10:21 AM   #30780
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,250
To each his own.....my 300 XCW was set up with Tubliss when I bought it......fine for dirt/rocks but a PITA in the open desert where I ride lot.....I had a whole slew of tiny cactus punctures.....too large for Slim and a PITA to find/plug.....so I ditched the Tubliss in favor of what I know works......Ultra Heavy Duty Tubes......a lot of weight but I don't care, I'm an old/fat trail rider not a racer.....
Times are GMT -7.   It's 02:27 AM.
