10-02-2012, 06:41 AM
#30841 |
10-02-2012, 07:47 AM
#30842 | |
Oddometer: 1,668
Since you were ordering from Rocky Mtn, why didn't you just get the right sprocket to use your factory bolts? Not trying to be a dick, serious question. More sprocket choices or something? |
10-02-2012, 08:14 AM
#30843 | |
Southern Ontario
Oddometer: 2,001
Funny about the bolts - I asked a Rocky Mtn rep about them and was told I don't need them. That would be really irritating to need and not have. I'm glad you mentioned them. ![]() Is this what you used? http://www.rockymountainatvmc.com/p/...sprocket+bolts jon_l screwed with this post 10-02-2012 at 09:03 AM |
10-02-2012, 08:38 AM
#30844 | |
Red Sox Nation
Oddometer: 8,902
I like my stock gearing, but there have been a few times I wish I had lower gearing. My habit is to ride nothing tougher than two track, but they can have washouts and such that make for a lot of clutch slipping. Also, trying to extract the back wheel from a rut can be challenging because of the tall first gear. I generally get off the bike and walk along side her to get her out.
I'll probably leave it stock for now, but I'm due for a new chainset so maybe not. That 14/49 option sounds good. It's a little taller than the 12/43 I had on it for awhile. I use stock size 120/80/18 Michelin T63 tire. Quote:
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
10-02-2012, 08:44 AM
#30845 |
Oddometer: 1,951
>"not a sprocket size that causes it, but more likely a work-out, kinked chain. A smaller front sprocket would not cause it, but it could exacerbate the situation."
I ate my chain guard in Baja with a new chain/sprockets and a band new guard on before making the trip. Pretty sure it was from carrying luggage on the bike... and I'm f'n heavy too. I'm pretty sure an overly loaded bike did it... if you get the swing arm up in it's travel, you've got to watch the chain guard wear carefully. Since Baja, I went to 14x49 sprockets. I now have an extra 5,000 miles on the bike and I don't show any wear on the swingarm portion of the guard yet. RM offers up to 52 tooth rear sprockets... If you get the WRR sprockets (not the F model), they have 2 hole sets so you can use either the square or countersunk bolts. >"That 14/49 option sounds good. It's a little taller than the 12/43 I had on it for awhile." I'd go 50+ on the rear. 14/49 is a little tall geared.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga! |
10-02-2012, 09:02 AM
#30846 | |
Oddometer: 3,526
Loud Sucks! www.wrrdualsport.com www.designatedvaping.com <- for all your electronic cigarette needs |
10-02-2012, 09:10 AM
#30847 |
Oddometer: 113
I ordered the kit but it turned out I didn't need them, at the time I bought a 48 and 50 tooth Primary Drive sprocket. I've since bought a 52 tooth Primary Drive sprocket and didn't need the tapered bolts either. The sprockets come with two different sets of holes, one for a tapered bolt and one that fits the bolts that came on your bike from Yamaha.
10-02-2012, 10:52 AM
#30848 |
Adventure Geek
Oddometer: 55
Thanks for all the responses, I appreciate it! I'll do some experimenting between now and next August....like I really needed another reason to put miles on the new toy...
To answer your question, HardWorkingDog, I actually use 6th gear pretty often. More of an afterthought than out of necessity though because it (marginally) improves my gas mileage. I also ride the super slab at least once a day for 15 minutes, and I feel like I may be stressing out the motor if I don't use 6th gear. Either way, I'm good with swapping it/them out. Should be interesting. |
10-02-2012, 11:28 AM
#30849 |
Oddometer: 550
If I had a buck for every time I tried to shift to 7th...
2009 Can-Am Spyder RS, 2008 Yamaha WR250R ArmyJoe's Perpetual Picture Thread - http://advrider.com/forums/showthread.php?t=888783 |
10-02-2012, 04:26 PM
#30850 | |
Southern Ontario
Oddometer: 2,001
When I order a new chain, I'll get a 110 or 112 (not sure which, so prob the longer one?). jon_l screwed with this post 10-02-2012 at 04:36 PM |
10-02-2012, 04:31 PM
#30851 | |
Southern Ontario
Oddometer: 2,001
![]() I asked a Rocky Mountain parts rep about it today, and this was the reply: Hi Jon, I have been checking into this and from looking at the OEM Schematics of your bike I can’t tell if the sprocket bolt has a tapered head on it or not. If it does your stock bolts should work just fine. This Primary Drive Sprocket doesn’t have a special taper on it and it looks exactly like the Renthal Taper. If your stock bolts are a flat based it might work as well because on this Primary Drive Sprocket it has what looks like two sets of holes (one for flat based and one for tapered). If you want to check into this and let me know what you find we can get you taken care of. If you have any questions let me know. Thanks and have a great day! Wes ________________ Krabill - I think you were the first WRR guy I noticed using Primary Drive brand; can you shed some light on this question? |
10-02-2012, 04:32 PM
#30852 |
Southern Ontario
Oddometer: 2,001
Maybe because I avoid divided / high-speed highways, I rarely use 6th (12/43 gearing). I typically ride 80 kph (50 mph) roads to get to slower roads/gravel/dirt.
10-02-2012, 04:39 PM
#30853 |
Oddometer: 2,009
110
'13 KTM 500 EXC, '08 Yamaha WR250R, '08 Kawasaki KLR650 (Sold), '04 CRF250X (Sold) Member AMA, NETRA, MVTR, CCCOFVT Stealth is good! Noise annoys! |
10-02-2012, 05:10 PM
#30854 |
Oddometer: 65
In answer to primary drive bolt head issue for the rear wheel. I recently put on the 50 tooth primary drive brand and the sprocket came with both tapered and regular holes drilled. I had ordered the tapered bolts so I put them in but could easily have used the original bolts. Both lined up fine. Saved the standard bolts for spares.
I have a 14 in the front, with 50 in back and 112 links and love the change for both off road and every day rideabilty. Easily does 70 mph (GPS) for commuting on the LA freeways. Planning on going to 13-50 and an MT 43 rear for the LA-Barstow-Vegas ride. Should be perfect for 400 miles of desert and mountains.:) Sent from my Galaxy Nexus using Tapatalk 2
Jon WR 250 R |
10-02-2012, 05:32 PM
#30855 |
Oddometer: 436
X and R rear fender??
Could someone please tell me if the X and R fenders will swap.
I want to order a white fender and need to know if they will before I do. Thanks for helping.. japako screwed with this post 10-02-2012 at 05:47 PM |
