Old 10-02-2012, 06:22 PM   #30856
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,129
good question
Originally Posted by Mikef5000 View Post
Since you were ordering from Rocky Mtn, why didn't you just get the right sprocket to use your factory bolts? Not trying to be a dick, serious question. More sprocket choices or something?
Rocky Mtn listed the sprox sprocket for the WRr but neglected to mention it only had tapered holes. I must have missed the Primary drive sprockets, I am cheap and surely would have chosen them due to the lower price . Since others have stated that they have both sets of holes, well they must.
One other good reason to switch to the tapered bolts is that a whole host of brands for multiple bikes come with the tapered holes that will fit the WRr.
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 10-02-2012, 06:31 PM   #30857
byron555
byron555's Avatar
Oddometer: 1,129
New chain
Originally Posted by jon_l View Post
when I'd order a new chain, I'll get a 110 or 112 (not sure which, so prob the longer one?).
With a 47t I'd order the 112 link, I am not sure a new unstretched 110 will work with a 47. even if it does, I'm not sure how much adjustment you would get?
That's my .02
WRr re-build
Old 10-02-2012, 07:03 PM   #30858
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,356
I ran a 110 fine with a 12/13/14 x47 all depends in how wide your tire is. As you get closer the wider tire can come in contact with the plastic inner fender. I am now running a 112 with 13/48. Had to move tire way back in the slides. A 110 is an easy find chain likely stocked at many local shops. But a 112 would need to be ordered.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 10-02-2012, 08:57 PM   #30859
japako
japako's Avatar
Oddometer: 592
Originally Posted by scottmac View Post
Absolutely no difference except for colors.
Thanks.. I appreciate it..
japako is offline   Reply With Quote
Old 10-02-2012, 09:02 PM   #30860
Longboardr
Longboardr's Avatar
Oddometer: 143
Wish there was consensus on this.
12 holes, 6 are tapered, 6 are counter-bored flat. Either style bolt will work.
Longboardr is offline   Reply With Quote
Old 10-02-2012, 09:20 PM   #30861
DaymienRules
Traffic target
DaymienRules's Avatar
Oddometer: 197
FWIW, I always order the chain too long, like 116. Its only a few bucks more. Then use the chain breaker tool to pull the extra links out.Now you have spare links for the tool kit, guaranteed to fit your existing chain. And a 2nd(maybe even a 3rd) masterlink to make trail side repair that much easier. Not that I've ever had a chain need repair.
DaymienRules is offline   Reply With Quote
Old 10-02-2012, 10:16 PM   #30862
bhd1223
bhd1223's Avatar
Oddometer: 294
I'm guessing your tool isn't simply a breaker and is also used for installing rivet links? Do you just keep extra pins handy to rivet the links on? This wouldn't work for me as my breaker is just a breaker. I use clip links and just buy a few when I get a new chain. Problem solved.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 10-03-2012, 12:23 AM   #30863
NL-Patrick
NL-Patrick's Avatar
Oddometer: 59
The answer is probably somewhere in the 2000+ pages of this thread but that's gona take a while....
How high can handlebar risers be , before the cables become to short?
Gr. Patrick
NL-Patrick is offline   Reply With Quote
Old 10-03-2012, 03:43 AM   #30864
jon_l
jon_l's Avatar
Oddometer: 3,268
Wow, thanks for all the sprocket and chain feedback guys!
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 10-03-2012, 04:23 AM   #30865
Krabill
Krabill's Avatar
Oddometer: 4,888
I run 13/47 with 110 links and have ordered a couple extra masterlinks to keep in my tool kit.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 10-03-2012, 04:50 AM   #30866
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,352
WARNING: Most things posted above contain sarcasm.
Daamud screwed with this post 10-03-2012 at 05:12 AM
Daamud is online now   Reply With Quote
Old 10-03-2012, 08:07 AM   #30867
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,728
You can safely increase the height by 1 1/2" without getting into trouble. Any more than that, and you'll be looking for longer clutch & throttle cables and brake hose.
Gr. Patrick
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 10-03-2012, 12:28 PM   #30868
Gryphon12
Gryphon12's Avatar
Oddometer: 1,333
Chain length summary...
I try to take notes when I see important information discussed here, so that I don't have to search 2000+ pages. Sometimes I make mistakes, however.
I believe that the stock chain is 110 links for stock 13/43 gearing on the WRR. Is this accurate?
I have notes from two different inmates regarding chain length for 13/47 gearing. One says 110 and one says 112 links. So, is the 13/47 sprocket set the transition point from 110 to 112, with some adjustability left for stretching with wear?
All my notes for 13/48 or larger say 112 links, until I get to 14/52 where I have a blank. 14/50 apparently works with 112 links. 14/52 (3.71:1) is really close to 13/48 (3.69:1), the latter of which uses 112 links. But 4 more teeth on the primary sprocket seems like a big step up. Will 112 links cover it?
13/52 (4.00:1) and 13/54 (4.15:1) are the shortest gearing ratios I have seen discussed on this thread. I can't see ever need them myself, but someone has tried and found them useful. Does 13/54 required a chain longer than 112 links?
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 10-03-2012, 12:42 PM   #30869
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,249
108 links
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 10-03-2012, 01:14 PM   #30870
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,743
I believe that the stock chain is 110 links for stock 13/43 gearing on the WRR. Is this accurate?...
This may be a good place to add a recommendation to use http://www.gearingcommander.com/
Extremely useful when figuring out this kind of stuff. Has accurate data on WRR/X stock gearing/chain length/tires to use as a base. The big takeaway for me is that talking about gearing is pointless without including tire diameter (or circumference). It will also allow you to calculate what chain length is required for a given sprocket combo.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Times are GMT -7.   It's 07:04 AM.
