Old 10-10-2012, 01:41 AM   #30976
Joe Watson
Joe Watson's Avatar
Oddometer: 1,031
Just a quick little WR250R review. A mate and I rode them from Cairns to Cape York in far northern Australia where we did about 3200km on the bikes. They performed almost flawlessly. A couple of loose bolts here and there and my starter button packing it in. A little bit more power would have been nice in the soft sand and on the higher speed transport sections, but overall, I loved this bike for the job.
Joe Watson is offline   Reply With Quote
Old 10-10-2012, 03:50 AM   #30977
jon_l
jon_l's Avatar
Oddometer: 3,149
Originally Posted by blaisew View Post
And, my last post was incorrect. Last trip was with the 13/45. No need for lower gearing on that one.
Please clarify - do you mean the gearing you ran on the TAT was 13/45? Or only the dash home from Oregon?
Thank you.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 10-10-2012, 04:26 AM   #30978
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,189
Originally Posted by what broke now View Post
"No relays, fuses, or other stuff required?"
The battery tender brand pigtail includes a fuseholder with a 7 amp fuse in it already. My gerbing jacket is 76 watts,eg, so that 7 amp is perfect for it.
All you need is to make a cable [16 gauge automotive primary wire is fine] with the battery tender style [sae] plug on one end, and your compatible style plug for the vest on the other. Make the cable long enough to suit the vest riding condition. When done riding, remove the vest adaptor cable, and you are back to a tender connection.
Get a thermostat control for the vest so you don't cook yourself.
One of my other hobbies is amateur radio, so I use Anderson Powerpole connectors for all my 12 VDC needs. The gender-less connector allows me to mix and match my cables however I need them.
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 10-10-2012, 04:34 AM   #30979
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,137
Warm n Safe SAE/Pigtail cable: $10
http://www.warmnsafe.com/sae-coax-plug-adapter-6-in/
Originally Posted by Mr. Fisherman View Post
STOP!
DO NOT use the pig tail that came with the tender.... it is very likely to have thinner gauge wires which could overheat with the increased heated gear amperage. Use a pig tail that is supplied with the heated gear. I recommend the ones from Warm and Safe.
YMMV, just don't melt your harness... you will regret it.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 10-10-2012, 06:08 AM   #30980
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,733
The battery tender pigtail has a 7 amp fuse in it, same rating as the jacket liner.
I've run it hot enough to cook Hebrew Nationals for hours, never a problem.
Just wouldn't want someone to think they could upsize the fuse in a common tender lead and think it was ok.
Cheap insurance and a very good idea
Do it once, do it right and be done with it.
Mr. Fisherman is offline   Reply With Quote
Old 10-10-2012, 06:21 AM   #30981
Yaozer
Oddometer: 178
SS Brake Line Length
Hey Riders,
I'm picking up a set lines from Hel and I'm wondering if anyone has the exact length they used for a shortened front line on an X. I want to make sure there is enough for suspension travel, but you all know the stock one on there is way too long and hangs above the master cylinder in its OEM configuration.
I saw the thread in WRR, but I didn't see any specific lengths. Thanks so much for your help.
Yaozer is offline   Reply With Quote
Old 10-10-2012, 07:15 AM   #30982
what broke now
Petroleum Brother
Oddometer: 1,379
The leads shipped with my tender are 16 awg, probably the same as all of them. it's fair to point out that the amperage capacity for that gauge bundled into a loom or "enclosed" is ~13 amps. In "free air" [ not enclosed] the capacity is ~22 amps.
All of us will, and do, effect the solution we deem best; in my case, I made a lead and am happy with the result. Others may choose a different path.
what broke now is offline   Reply With Quote
Old 10-10-2012, 09:15 AM   #30983
AZ TOM
Oddometer: 3,938
Originally Posted by LoFlow View Post
2800 miles in 4 days after doing the TAT...
My kind of guy
AZ TOM is offline   Reply With Quote
Old 10-10-2012, 10:11 AM   #30984
jckid
Oddometer: 321
Thanks for all the input on getting my bike ready to run an electric vest. I did some browsing on Aerostich last night and I think I found the perfect setup. This is what I'm planning to get:
http://www.aerostich.com/sae-switch-coil-cord-kit.html
It comes with the pigtail to connect to the battery, and it has a fuse in it. It also has a coiled cord with a switch, and then it has an extension. It seems like it has everything I need in one kit. Now I just have to decide if I want to get the Aerostich heated bib or a full vest.
And now I found these:
http://www.aerostich.com/aerostich-warm-wrap-grips.html
I might get a splitter and run these too! I had the under the grip type heaters on my KLX, but they didn't work that great. Maybe these would work better.
Current: WR250X (ADV 19"/17" wheel conversion), CT110
Previous: SM610, KLX351
WR250X ride report: http://advrider.com/forums/showthread.php?t=903806
jckid screwed with this post 10-10-2012 at 10:23 AM
jckid is offline   Reply With Quote
Old 10-10-2012, 10:56 AM   #30985
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,237
Originally Posted by Lima Tango View Post
Please excuse my cluelesness, but I was wondering...
The 3.1 IMS fuel tank for the wrr has a vent tube sticking out of the cap. What is this for? Why doesn't the stock tank have this? My wrr is a California model if it matters.
thanks!
I believe the stock locking cap on the WR250R is vented, the IMS tank cap isn't, so it has the vent line. Found that out also. Kinda a pain in the rear. I found a swivel vent hose that came with a pre-formed angle and I use that under my tank bag. There are some smaller vent hoses optoins also. Gotta have a some sort of vent. FWIW my bike is NOT a CA model.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 10-10-2012, 11:15 AM   #30986
ramz
Professional Trail Rider
Oddometer: 1,994
Don't tell where you got it, brand/model name, and cost.
Especially if anyone else might want to buy one...
ramz is offline   Reply With Quote
Old 10-10-2012, 12:41 PM   #30987
AZ TOM
Oddometer: 3,938
Must be a Troll
Old 10-10-2012, 06:14 PM   #30988
Mikef5000
Oddometer: 2,030
Really?
http://tinyurl.com/8z566es
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 10-10-2012, 08:06 PM   #30989
Sewcrates
Oddometer: 3
Hey all,
Someone mentioned a bracket or something to use when swapping between X and R wheel (17" to 18/21") sets that prevents you from having to reset your chain tension bolts every time. Apparently, this device will take up the slack for the shorter set.
Anyone know anything about this?
I picked up a 2008 WRX with 3400 miles with both wheel sets a few months back. I mostly use the R wheels because it is such a pain to swap. I would like to use the sumo tires more.
I love the bike, by the way. Thanks to everyone here for helping me make the decision. I came from a WR250F.
Sewcrates is offline   Reply With Quote
Old 10-10-2012, 08:08 PM   #30990
bhd1223
bhd1223's Avatar
Oddometer: 294
Originally Posted by Sewcrates View Post
Hey all,
Search for reversible axle blocks. I can't remember what people mentioned as a specific brand but I know they were something like reversible axle blocks.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Times are GMT -7.   It's 09:29 PM.
