Old 10-10-2012, 07:21 PM   #30991
Blaise W
Blaise W's Avatar
Oddometer: 679
Originally Posted by jon_l View Post
Please clarify - do you mean the gearing you ran on the TAT was 13/45? Or only the dash home from Oregon?
Thank you.
I ran 13/47 on the TAT, and changed to 13/45 on the way home as I wanted to be able to pull 6th gear most of the way. I could, except for some of the steepest grades on I-10. In retrospect, the 47 would have been fine on the interstate. For any serious trail work, or steep climbs as in the Rockies, use a 49, min. I think BigDog runs a 50 rear with several different front cogs, minimum 13, to keep the chain away from the swing arm.
Blaise W is offline   Reply With Quote
Old 10-10-2012, 09:38 PM   #30992
Llamaha
Oddometer: 851
Originally Posted by Joe Watson View Post
Just a quick little WR250R review. A mate and I rode them from Cairns to Cape York in far northern Australia where we did about 3200km on the bikes. They performed almost flawlessly. A couple of loose bolts here and there and my starter button packing it in. A little bit more power would have been nice in the soft sand and on the higher speed transport sections, but overall, I loved this bike for the job.
One of my dream rides that is! Your bike is looking good these days too
Llamaha is offline   Reply With Quote
Old 10-10-2012, 09:45 PM   #30993
Sewcrates
Oddometer: 3
Originally Posted by bhd1223 View Post
Search for reversible axle blocks. I can't remember what people mentioned as a specific brand but I know they were something like reversible axle blocks.
Thanks for the info!
Sewcrates is offline   Reply With Quote
Old 10-10-2012, 09:54 PM   #30994
jkstehn
Oddometer: 117
Originally Posted by Sewcrates View Post
Hey all,
Someone mentioned a bracket or something to use when swapping between X and R wheel (17" to 18/21") sets that prevents you from having to reset your chain tension bolts every time. Apparently, this device will take up the slack for the shorter set.
Anyone know anything about this?
Pretty sure it was the Zeta Axle Blocks which you can get at Wheeling Cycle Supply. http://www.wheelingcyclesupply.com/shop/1/17/868.shtml
Sent from my Galaxy Nexus using Tapatalk 2
Jon
WR 250 R
jkstehn is offline   Reply With Quote
Old 10-11-2012, 07:24 AM   #30995
SkidMarx
SkidMarx's Avatar
Oddometer: 2,243
YZ/WR reversable axle blocks from various sources work. Not sure what years work, but likely most of them.
I have a set from Pro Circuit from my brothers '98 yz125 on mine.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 10-11-2012, 07:48 AM   #30996
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,250
Originally Posted by AZ TOM View Post
Must be a Troll
Hey Tom - Do you recall receiving a "whoops, sorry, wrong number" phone call two weeks ago? That was me looking for a different "Tom" in Bullhead City......I had my names/numbers crossed up.....sorry for the mix up......I'll be over in Bullhead again this weekend......probably bringing the 300XCW.....the WR250R needs some love after the last few weeks (tires/fork seals/sprockets/oil/filters - toasty.....no time for maintenance this afternoon......leaving tonight after work)
We'll definitely need to hook up for a ride over in Prescott or (?) now that the temps are down....
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 10-11-2012, 07:51 AM   #30997
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,572
Axle BLocks
I picked up a pair on Ebay for $25.94 this week.
Not made by Zeta but I suspect they're all about the same.
Solid Solutions Performance Products
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 10-11-2012, 08:51 AM   #30998
AZ TOM
Oddometer: 4,074
Yes I do remember that call but had no Idea it was you.. I was out in the garage working on Motorcycles I am soloing, so far anyway a ride on Nov. 13,14,15,16 from home to Laughlin overnight, Moave Trail to Barstow, overnight & reverse it back to Prescott. We will for sure hook up one of these days
AZ TOM is online now   Reply With Quote
Old 10-11-2012, 04:36 PM   #30999
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,989
Originally Posted by jckid View Post
Thanks for all the input on getting my bike ready to run an electric vest. I did some browsing on Aerostich last night and I think I found the perfect setup. This is what I'm planning to get:
http://www.aerostich.com/sae-switch-coil-cord-kit.html
It comes with the pigtail to connect to the battery, and it has a fuse in it. It also has a coiled cord with a switch, and then it has an extension. It seems like it has everything I need in one kit. Now I just have to decide if I want to get the Aerostich heated bib or a full vest.
And now I found these:
http://www.aerostich.com/aerostich-warm-wrap-grips.html
I might get a splitter and run these too! I had the under the grip type heaters on my KLX, but they didn't work that great. Maybe these would work better.
You will see the tender leads are the same gauge as the Aero leads, only nicer, since the tender leads have that cap on the end.
My suggestions from a bunch of frigid ass Ohio cold weather riding, get the full vest; and opt for actual grip heaters installed on the bike. The overwrap ones are okay for a temporary fix but if you are gonna do it, do it right.
I have used on multiple bikes the Oxford Heated Grips. The purpose built ones are scads better than the under element style, though a bit more expensive.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 10-11-2012, 05:58 PM   #31000
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 339
Try www.mobilewarminggear.com
Battery li ion heated gear convienient affordable and no draw on bike!
EEKAMOUSE is online now   Reply With Quote
Old 10-11-2012, 06:47 PM   #31001
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
wr250r brake and clutch lever replacement
I need to replace my levers. i want something shorter and ones that can be adjusted for reach for smaller hands. any suggestions?
oxygenrace is offline   Reply With Quote
Old 10-11-2012, 06:52 PM   #31002
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,951
I bought a set or drc shorty levers. Cheap at $7 ea.
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 10-11-2012, 07:59 PM   #31003
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,129
Reversable Axle blocks??
My Question is, what is the difference in tooth count? 2t on the rear? 3t?
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 10-11-2012, 08:36 PM   #31004
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,572
I have 13t font, 47t rear,,,
Old 10-11-2012, 08:39 PM   #31005
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,572
Best clutch levr for the money IMO...Righteous Stunt metal EZ pull clutch lever....
Times are GMT -7.   It's 05:34 PM.
