Old 10-12-2012, 08:20 AM   #31006
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,753
I'm planning to buy one of these.
I recently bought the cheap $8 DRC levers previously mentioned and I got what I paid for. I bought the "short" levers and found they really weren't very short. Plus, the clutch lever in particular doesn't clear the turn signal controls very well. The amount of force required was more than with the OEM lever. I've since gone back to the original levers.
I have read good things about the Righteous Bros units. Probably worth the extra cash.
Originally Posted by Rapid Dog View Post
Best clutch levr for the money IMO...Righteous Stunt metal EZ pull clutch lever....
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 10-12-2012, 08:21 AM   #31007
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,615
+1 ... don't have one, but have been drooling over them since I saw them.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 10-12-2012, 10:10 AM   #31008
Subaru297
Oddometer: 118
I bought a Righteous Stunt Metal lever for my WRX and it is a nice unit but you will lose your clutch sensor (No big deal) and your mirror mount. So keep that in mind.
I didn't have anything to replace the mirror mount at the time so it went on my YZF instead. Great lever though.
Subaru297 is offline   Reply With Quote
Old 10-12-2012, 10:32 AM   #31009
Cygnus X1
Oddometer: 5
I got in touch with Josh from RSM back in July asking about the clutch switch and his reply was
"Quote"I'm hoping to have a clutch sensor switch equipped RSC ready for the public sometime later this year. Probably Octoberish.
If so I will probably try something like this for the mirror mount.
http://www.moto-heaven.com/store/ZET...RROR-HOLE.html
Cygnus X1 screwed with this post 10-12-2012 at 10:38 AM Reason: no image
Cygnus X1 is offline   Reply With Quote
Old 10-12-2012, 10:34 AM   #31010
Cygnus X1
Oddometer: 5
Old 10-12-2012, 11:50 AM   #31011
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,376
I've got the zeta levers on mine and they work great. Fully adjustable, with wrenches. And short enough to fit inside hand guards without hitting, but don't flop around like a marionette on the bar like stock ones.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is online now   Reply With Quote
Old 10-12-2012, 12:18 PM   #31012
DCR
Dave
DCR's Avatar
Oddometer: 17
Help with CA model emissions canister
This is to anybody that can give me some advice on smog removal. I just bought a 2011 CA model and didn't realize it until I had trouble putting on a Ricochet skid plate last night due to the carbon canister. I was wondering if there is a good way to bypass this as it will not fit with the new plate. Keep in mind I just bought this and do not have a service manual although it is on order. If anyone knows how to bypass all the emissions stuff I would be open to suggestions. I live in illinois and do not need any of it. Thanks David.
DCR is offline   Reply With Quote
Old 10-12-2012, 12:58 PM   #31013
KansasBob
KansasBob's Avatar
Oddometer: 515
I did mine this way..........................
Unbolt the canister, follow the vacuum line back to the throttle body and pull it off. Plug the port on the TB with a rubber cap (squirrel condom) Use needle nose pliers to put it on. Auto parts stores have them.
The other hose is a vent line from the fuel tank. Buy a hose coupler at the same auto parts store, couple on a piece of fuel line, route it back under the motor and poke it out behind the motor. Use tyraps to hold it in place.
You loose about a quart of capacity with a CA bike because of the vent. You can push it full if you are careful, but it will drip a little out of the vent line you install when you do. If you just "fill and go" it's not an issue. A couple of drops on the ground isn't a problem for me either.
Hope this helps........ Bob
KansasBob is offline   Reply With Quote
Old 10-12-2012, 04:51 PM   #31014
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
clutch sensor
what is a clutch sensor?
oxygenrace is offline   Reply With Quote
Old 10-12-2012, 05:33 PM   #31015
jkstehn
Oddometer: 118
The church sensor is a switch in the clutch lever housing that tells the computer that the clutch is pulled (disengaged) and it is safe to start the bike even though it isn't in neutral.
Sent from my Galaxy Nexus using Tapatalk 2
Jon
WR 250 R
jkstehn is offline   Reply With Quote
Old 10-12-2012, 05:49 PM   #31016
Joe Watson
Joe Watson's Avatar
Oddometer: 1,033
These are the clutch and brake levers I am using. They are rather cheap but nice and short. The only problem I have with them is they don't have adjustment in the brake lever to get rid of the bit of play before the brake engages, other than than, very happy with them for the last 4000km or so.
http://www.ebay.com.au/itm/PAZOMA-CN...item4ab794a43c
Joe Watson is offline   Reply With Quote
Old 10-12-2012, 06:04 PM   #31017
oxygenrace
Motorcyclist
oxygenrace's Avatar
Oddometer: 69
so with a clutch lever without a sensor the bike could only be started in neutral?
Old 10-12-2012, 06:10 PM   #31018
thumpididump
MacGyver
Oddometer: 2,753
No, doesn't matter which gear the tranny is in. Rather, with the sensor wire connected, you must pull the clutch lever in to start the bike. With the sensor disconnected, the starter motor will engage with or without the clutch lever pulled in.
It's a safety thing... y' know, it's for pussies. Kind of like the side-stand switch (said the guy who rode off with his kickstand down)...
Keyboard Diarrhea
Old 10-12-2012, 07:35 PM   #31019
DCR
Dave
DCR's Avatar
Oddometer: 17
Thanks Bob I will try that in the mean time im just plugging the hoses with some bolts. Take it easy.
Old 10-12-2012, 07:55 PM   #31020
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,129
I removed the switch from the clutch perch, now I can start in any gear without pulling the clutch.
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Times are GMT -7.   It's 01:40 AM.
