Old 10-18-2012, 03:34 PM   #31111
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,498
That Ktm screen looks good. Keen to see it mounted more.
Do any of these screens make the wind on the helmet visor worse, or hopefully better? I use a hornet. Don't find it to bad, but the larger klim one is better in the wind oddly. Just not as convenient.
tmotten is offline   Reply With Quote
Old 10-18-2012, 05:17 PM   #31112
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,766
Wish I could read German.
I'd be interested in one of those Euro lights also... to replace a cheap, junky Edge tail light that got ruined by water and mud in just one year.
While it looks similar to the the as used on the WR250/450F, I suspect those only work as a tail light (no brake light). Can anyone confirm?
Originally Posted by flatboarder View Post
Can you access EU spare parts catalogue via
http://www.yamaha-motor.eu/de/inform...e-katalog.aspx
It is all in there. This assembly has got several components spread over several sheets.
Regards, Phil
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 10-18-2012, 06:17 PM   #31113
BryceKLXer
Oddometer: 23
Regards, Phil
Thanks that helps tremendously--I have part numbers now. Is there a site I can order from online? It seems no one out of the US does this--liability? Too sad that what we have come to if that is the case. I tried to buy from the UK once but without a UK VIN they would not speak to me.
The US spec WR450 tail light can be mounted--I have seen that done already---but I am hell bent on keeping the stock turn signals so I need that black piece at bare minimum, prefer the whole works. The US WR light should also have a brake light but have not seen one personally--the guy that did it said it did.
BryceKLXer is offline   Reply With Quote
Old 10-18-2012, 06:57 PM   #31114
BryceKLXer
Oddometer: 23
I just sourced a US spec WR250/450F tail light & will see what happens when I receive it.
You can get an LED replacement or LED with built in turn signals out of Austrailia here:
http://www.ebay.co.uk/itm/Yamaha-WR2...item53e9693676
I am not saying any of these options are a direct fit or plug & play--just saying it should be doable with some tinkering. We will see what happens when I get my US spec "F" light & go from there (as I said I have seen others do it already--just dont know what they had to do).
Old 10-18-2012, 07:19 PM   #31115
Gany
Oddometer: 366
I think we have the same tail light here in australia as the euro one... Did you want me to try and price anything? Parts are not cheap here unfortunately...
Gany is offline   Reply With Quote
Old 10-18-2012, 08:08 PM   #31116
BryceKLXer
Oddometer: 23
Yes the AUS & Euro are the same.
I ordered a US spec dirt only model tail light & I think it is the same or very similar to the Euro spec. At this time I am going with that. I still need the black piece part number 3D7-84516-00. Once I find a source for that I should have what I need. If you could link me to a place I could order that Yamaha part online from AUS or anywhere else I should be golden. Thanks.
Old 10-18-2012, 08:15 PM   #31117
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Originally Posted by bogboy View Post
Hi all,
I 've done the air box mod. Just wondering if removing AIS is worth it if keeping the original exhaust.
Also , do you lose mpg's with this removal?
bogboy
There is a lot of discussion / debate on the advantages of these mods both buried here in the mega thread and also over on the WR Forum. I think it was High Five who I remember suggesting that either do the whole ball of wax or nothing. By that I mean you are unlikely to note any real change with just the airbox. So with this in mind I went with the usual: airbox, AIS removal, EXUP removal, graves bypass, exhaust and fuel programmer. Personally, I am happy with this and feel it really opened up the bike and gave it a snappier feel. Others may disagree. I guess you should ask yourself what you are hoping to achieve. The WR is a great bike, but in many respects is underpowered IMO. I suspect the airbox mod alone is unlikely to really change that equation. YMMV.
As to the MPG question, I currently get in the mid 40s. Then again I tend to ride pretty throttle heavy on this bike both on road and off. My solution was a Safari tank. Others have reported much better MPG, but the only way I can seem to improve my MPG is to ride very sedately.
Good luck with whatever changes you decide on.
Dan
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 10-18-2012, 10:25 PM   #31118
skierd
Wannabe Far-Rider
Oddometer: 2,990
Mike5000 - Check ebay. There's always at least one or two WRR's being parted out and the yard doing the posting might have something.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 10-19-2012, 03:18 AM   #31119
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,305
Dan
Well, I routinely get over 50 mpg on the super slab, where I've pretty much got the throttle to the stop or just off the stop. If I'm riding higher speed gravel roads like the Pony Express Trail, I get about 65mpg. That is cruising about 45-55mph using the top 3 gears.
My Safari has delivered me 230 miles range, but I was trying to stretch it. Took 3.5 gals, so still not sure if the wings will drain completely. Purty close, though!
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 10-19-2012, 07:53 AM   #31120
ducnek
Satisfied customer
ducnek's Avatar
Oddometer: 1,017
Does anyone have a link to the best (cheapest) place to get a replacement chain slider that mounts to the front of the swingarm?
I got quoted $48 by my local dealer.
Calmer than you are.
ducnek is offline   Reply With Quote
Old 10-19-2012, 09:02 AM   #31121
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,803
Sounds like a great price.
Hate gets you nowhere.
Old 10-19-2012, 09:24 AM   #31122
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,271
$32.92 at Service Honda.
SEAL, GUARD
3D7-22151-00-00 1 $48.04 $32.92
http://www.servicehondapsn.com/fiche...008&fveh=18085
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 10-19-2012, 11:23 AM   #31123
thumpididump
MacGyver
Oddometer: 2,766
Ron Ayers is usually where I begin my search for OEM parts using their fiche.
part #6 Seal 3D7-22151-00-00 is $33.16
http://www.ronayers.com/Fiche/TypeID...Group/REAR_ARM
Keyboard Diarrhea
Old 10-19-2012, 02:31 PM   #31124
Mikef5000
Oddometer: 2,031
A little photo whoring...
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 10-19-2012, 02:57 PM   #31125
sieg
sieg's Avatar
Oddometer: 2,924
Originally Posted by Mikef5000 View Post
Anyone else broken the front caliper off the bike?
Broken Caliper Carrier:
My kid did the same thing to his WR450F. I just welded the broken out hole in solid and redilled and tapped it. Quick cheap fix.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Times are GMT -7.   It's 06:03 PM.
