Old 10-29-2012, 03:50 PM   #31261
mpatch
Oddometer: 1,040
Originally Posted by KansasBob View Post
Some have managed to "move" the TPS using this method but others have not been able to make it budge.
What I'm saying is if you loosen both screws to let the TPS "float" and the throttle stops sticking you could tighten them back down with the TPS set correctly, out of a bind.
Heading down another road........... Ford had a problem with the butterfly on some of their throttle bodies sticking a few years back. It had something to do with the shaft and bearings. There was a recall and the TBs were replace under warranty.
There is more to it than just tapping it back you also need to get into diagnostic mode to get within parameters which is somewhere in the mid 90% range
mpatch is offline   Reply With Quote
Old 10-29-2012, 04:06 PM   #31262
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,211
Jeez, and I thought it would be as simple as lubing a cable or two; makes me second guess moving away from the DR.
By God, Woodrow; it's been one hell of a party.
dogjaw is offline   Reply With Quote
Old 10-29-2012, 04:26 PM   #31263
mpatch
Oddometer: 1,040
To access the controls for making these changes, you must first make a jumper wire to ground (did mine to the negative battery terminal) from the "extra" black wire in the connector for the lean angle sensor underneath the seat. There are three wires on one side of the connector that are used by the LAS and another black one on the opposite side that connects to nothing. This is probably used by the dealer to connect to Yamaha's diagnostic software.
OSU:(Here is the lean angle sensor under the seat.)
OSU:(There is the one lone black wire on this side of the connector.)
OSU:(Here is the other side, you need to jump the black wire to the ground wire on this side.)
Hold down the "reset" and "select 1" buttons on the insturment cluster at the same time and Turn on the key (but don't press the starter button) while continuing to hold these two buttons. After 8 seconds the display will read "diag"
press select 1 (i think) until you get to the screen that show throttle % the TPS is a black plasic round thing on the right side of the engine behind the frame rail use a dowel or something similar to try to tap it a bit, it took me a bit of back and forth to get the % right and have no throttle bind
Old 10-29-2012, 04:30 PM   #31264
mpatch
Oddometer: 1,040
The tps was the last thing I messed with after tying everything else. It wasnt until I pulled the cables off of the throttle body and moved the plate by hand and felt the binding issue that;s when I figured it out.
Old 10-29-2012, 05:32 PM   #31265
jon_l
jon_l's Avatar
Oddometer: 3,368
Hey Thump - I recognize the Fall Ride video. Are you the www.fy-yff.com guy?
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 10-29-2012, 06:21 PM   #31266
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,211
So where should I start in the process? I feel like a newbie, modded my DR to the moon, haven't even changed the oil in the WR
Old 10-29-2012, 06:41 PM   #31267
mpatch
Oddometer: 1,040
What I did, first take apart the throttle and remove the cables then put it back together and see if the grip moves freely, 2. follow the cables and look for any kinks, sharp bends etc., 3. rotate the throttle plate by hand if you can get your hand in there if not improvise, turn the plate by hand to where it hangs up stop and check the cables to see if one is tight, if they are both slacked then it's nothing between the grip and the TB. 4. check the return spring, make sure it didn't break or jump off, dont take off the plate because getting the spring back on is a real treat (ask me how I know) if none of that is the issue then the TPS is the only other thing other than something being broken inside the TB.
Old 10-29-2012, 07:09 PM   #31268
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,753
Yes, that's me.
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 10-29-2012, 08:54 PM   #31269
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,211
very helpful, and much appreciated... will tear into it tomorrow
Old 10-29-2012, 11:11 PM   #31270
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,597
Winter Mods
Been spending quality time getting my WR ready for some winter riding here in the PNW. Had some great days last year buzzing around the coast range on days that weren't TOO cold. This year I may even try some local night rides, so lights were in order as well as a few other little mods I thought I'd share.
HDB top plate came in handy again
Velcro'd controller
Who needs reflectors
Low power
High - Notice the heat shield on the heat shield.
My Giant Loop kept rubbing through the paint on the stock sheild. Not ideal, but it's a start.
Made the spacers from the leftover doughnut when using a 3/4" hole saw.
Damn these things are ugly, but they sure help in the heavy rain. Just picked them up last week, and they flopped all over the place.
Had some license plate bolts and some strechy fabric I had laying around in order to make a little support. I can easily take them off on dry days, cause, again, they're fraking ugly.
Hot grips complete the projects. Bring on the winter.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 10-30-2012, 12:05 AM   #31271
DefyInertia
Saratogian
DefyInertia's Avatar
Oddometer: 153
Where are you guys getting your fuel pumps and what is a fair price these days?
There's a feeling I get when I look to the West...
DefyInertia is offline   Reply With Quote
Old 10-30-2012, 02:38 AM   #31272
jon_l
jon_l's Avatar
Oddometer: 3,368
Service Honda, around $213
CBF1000 & PCX150
Old 10-30-2012, 05:17 AM   #31273
bigdon
Oddometer: 2,654
I just bought one. $232 + $20 shipping!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 10-30-2012, 05:31 AM   #31274
jon_l
jon_l's Avatar
Oddometer: 3,368
Ah, sorry. I didn't check this morning when I replied, I just looked back to June when that price was last posted. I sure hope the haven't gone up 10%.
CBF1000 & PCX150
Old 10-30-2012, 05:52 AM   #31275
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,726
My buddy picked up the 08'. Hoping to do a trip with him in the next few weeks.
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My Scramster Build
3 weeks solo: Overland Expo East ,Barber Vintage Fest and beyond
Ginger Beard is offline   Reply With Quote
Times are GMT -7.   It's 01:13 AM.
