11-05-2012, 01:36 PM
#31381 |
Oddometer: 2,038
License Plate Light
Anyone else's license plate light really loose? I tried tightening the bolts but there is an internal spacer that prohibits making it any tighter plus the nuts are capped. Is it loose by design? Shorter bolts or a standard nut makes no difference due to the spacer.
'13 KTM 500 EXC, '08 Yamaha WR250R, '08 Kawasaki KLR650 (Sold), '04 CRF250X (Sold) Member AMA, NETRA, MVTR, CCCOFVT Stealth is good! Noise annoys! |
11-05-2012, 01:57 PM
#31382 | |
Curmudgeonly
Oddometer: 8,935
I took an old handlebar grip, cut a rectangular piece the size of the LP light housing, punched holes in it where the bolts would pass through, and used it as a spacer between the light housing and the back of the fender. It solidified the housing quite a bit and I like to think the rubber adds dampening to keep the vibes from breaking the bulb filament.
"A man turns his back on the comforts of home... to ride off alone, and when the dust all settles and the story is told, history is made by the side of the road" -DBT, Monument Valley |
#31383 | |
Oddometer: 2,289
I also found my tail light lens loose and no way to tighten it. Ended up putting some thin (IE cut with scissors) foam between it and the plastic. Has worked well now for many many miles.
10Cup - WR250R - BMW R1200GS Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker SpearMotorSports, Inc. The cost of living's going up, and the chance of livin's going down. 10Cup screwed with this post 11-05-2012 at 02:04 PM |
11-05-2012, 03:26 PM
#31384 | |
Southern Ontario
Oddometer: 2,075
Do we think this is an issue that needs to be addressed, or an intentional design "feature"? |
11-05-2012, 04:02 PM
#31385 |
Harvey Mushman
Oddometer: 1,330
![]() NO! ![]() ![]() ![]() I still can't get over trying to retrofit a manual cam chain tensioner in this bike.
"Coffee first..." Next Trip: didn't get enough...Death Valley "it's a dog's life.............and I love it" |
11-05-2012, 05:43 PM
#31386 |
Lacks Freetime
Oddometer: 4,980
The plate light holder is made that way. IIRC, its a filament bulb( as opposed to an LED), and if hard mounted, is more likely to break...especially on a tail that is potentially bouncing around all the time, harshly.
The filament bulb on my DRZ tailight(aftermarket) would break couple times a season.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
11-05-2012, 10:31 PM
#31387 |
Wannabe Far-Rider
Snow has started to fall in and around Fairbanks, a nice sheet of ice has formed on the roads, and for the first time since I've started riding I've had to put my bike up for the winter. Or at least until I can get studded knobbies... She's been sitting since late september, with the temps getting into the negative teens overnight the last couple weeks, thoroughly cold soaked. Went out to change the oil for winter and run some stabil through her, and she started right up like nothing. If anyone is interested in a set of stock X wheels, let me know if you're interested. I'm pretty well decided on swapping back to dirt wheels come spring, as well as getting a second bike.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
11-05-2012, 11:47 PM
#31388 |
Ok, so I got my starter/kill switch from K&S which is great! Saved a bunch not buying through Yamaha.
![]() BUT!!!!!! Now my bloody indicator switch wont push in to return. I have pulled it apart cleaned, lubed and everything, but I just can't get it to push and return. Any suggestions on how to fix it before I fork out for a new one of these?
11-06-2012, 01:49 AM
#31389 | |||
Very sad to see it go, I have put countless hours into getting it to this stage and it has taken me to MANY incredible places!!
It does not have dual radiators, just a guard to keep roost off all the bits behind there and it is no different than cleaning the radiator guard on the other side! The bash plate does have two tool boxes, one either side. Everything on the bike I built myself, all the info is in my build log here (page 8 has all the new stuff): http://www.advrider.com/forums/showthread.php?t=678192 ![]() Quote:
11-06-2012, 08:36 PM
#31390 |
Oddometer: 1,588
Fork protectors
Does anyone know if the fork protectors have been changed over the years so that they do not rub the forks?
Triumph, BMW, Yamaha |
11-07-2012, 01:35 AM
#31391 | |
Yer' mom!!!
Oddometer: 272
'08 WR250X with X and R setups ![]() '08 KTM 300xc-w ![]() '01 KTM 520EXC - Dirt/Street/Tard <-- RIP....you will be missed
11-07-2012, 03:52 AM
#31392 |
Trail Jester
Oddometer: 1,027
stock WR250R HP
Anyone know what is the HP of a stock WR250R is?
'11 Husaberg FE570S '12 KTM 990 '13 Husaberg FE350 Berkshire Trail Riders on Facebook or follow me on Twitter |
11-07-2012, 05:25 AM
#31393 |
MacGyver
Oddometer: 1,985
It's a monster...
"The stock WR250R makes 28 horsepower and 17 foot-pounds of torque." http://www.cycleworld.com/2011/05/20...ecial-feature/
_______________ "You can't put the shit back in the donkey." - Tony Soprano FYYFF
11-07-2012, 06:55 AM
#31394 |
Navigate 2 Adventure
Oddometer: 2,116
Just throw on a set of black WR250"X" fork protectors....they don't rub like the white "R" model.....slightly different
Chris Crawford (Crawford + 4 kids = Crawdaddy http://www.CrawdadOffRoadEvents.com http://www.DualSportMoto.com http://www.WhereAmIRiding.com |
11-07-2012, 07:25 AM
#31395 | |
Ducati Monster. EVO.
Oddometer: 916
Sounds a bit optimistic to me. ![]() ![]()
2011 Yamaha WR250R 2012 Ducati Monster 2007 R1200GS (Sold) IBA # 20880. STFU and Ride. |
