Old 11-15-2012, 08:33 AM   #31516
ba_
ba_'s Avatar
Oddometer: 2,833
HDB questions
I'm quickly coming around to the idea of an HDB setup after a simple tip over bent my Cycra handguards.
I do have a few questions:
- I bought Renthal fatbars. I assume I can use the threaded inserts that come with the HDB kit. Can anyone explain how this works?
- I would eventually like to get a Scotts steering stabilizer and install it under the bars (SUB mount). Does anyone have this setup that can share their experiences and possibly some pictures?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
FS: DID Chain & front/rear JT sprockets WR250R
ba_ is offline   Reply With Quote
Old 11-15-2012, 08:57 AM   #31517
BMW-K
F800GS FTW!
BMW-K's Avatar
Oddometer: 1,520
Right, so I'm using HDB's and a Henry-Reed bend ProTaper Contour bar. They bolted right into the HDB clamp, no problem.
The HDB kit comes with a tap screw and two heavy duty screws. You tap the end of the handlebar directly and screw into it. There's no insert - you literally thread the handlebar.
I also have the Scotts damper. You need a riser kit to fit the Damper under the bar. I can't quite recall but I believe when I ordered the Scotts kit I was able to order a mounting kit that included the riser to create enough height for under the bar mounting.
All in all, I am super impressed with the setup and it's worked wonders for the WR.
2010 F800GS Anniversary - a return to Eden
2011 Yamaha WR250R, 2012 Ducati Monster
2007 R1200GS (Sold)
IBA # 20880. STFU and Ride.
BMW-K is offline   Reply With Quote
Old 11-15-2012, 09:28 AM   #31518
sturgeon
sturgeon's Avatar
Oddometer: 949
Paul at HDB will answer all your questions quickly and expertly. I have no affiliation with him; I'm just a satisfied customer. I'm using bars that I bought from him (so inserts pre-installed) and a GPR damper, else I might be able to answer your questions without speculating.
As for tip-overs, I have actually managed to put a very small s-bend in my left one. But that was the result of falling, with the guard directly hitting a large protruding boulder which was probably 2 feet below where my tires were, with a 200-lb rider aboard. I reckon the HDB guards saved a fair bit of damage to the bike (there was none), and possibly major damage to my hand. Nothing the fault of the guards, just operator error. It's so small a bend that I can't be bothered trying to fix it. I'm probably too old and weak to bend it back anyway
Dyslexics Untie!
sturgeon screwed with this post 11-15-2012 at 09:36 AM
sturgeon is offline   Reply With Quote
Old 11-15-2012, 10:14 AM   #31519
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 394
Originally Posted by jon_l View Post
Same thing re: the GYTR rack and Wolfman racks, which also use the same attachment point on the left side. When I inquired, Wolfman advised me by email these 2 are incompatible. I posted the same here, and immediately several people posted photos of GYTR rack and Wolfman racks, proving it can be done.
You are probably correct since you tried it yourself, just saying...
Yes not completely compatible, but I managed to make them work and am very pleased with the result.
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is offline   Reply With Quote
Old 11-15-2012, 11:01 AM   #31520
ba_
ba_'s Avatar
Oddometer: 2,833
The Renthal bars I have have an opening on the end that is a small diameter. Is this what you end up tapping?
Old 11-15-2012, 01:15 PM   #31521
BMW-K
F800GS FTW!
BMW-K's Avatar
Oddometer: 1,520
Yep. Tap/thread the whole bar end.
2007 R1200GS (Sold)
Old 11-15-2012, 01:24 PM   #31522
ba_
ba_'s Avatar
Oddometer: 2,833
Thanks. Does anyone have a picture of what this looks like when you are done?
Old 11-15-2012, 02:10 PM   #31523
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,760
No picture, but when I recently ordered bars from HDB for a top plate/riser installation he sent me bars with the bar end insert installed even though I wasn't going with the HDB guards. The thread was thread same as my Acerbis Hand Guards that use an expanstion bolt (8mm?). But having the insert threaded into the bar end, makes much more sense and is WAY more secure that what I've used in the past. HDB makes good stuff! Once I totally ruin my existing handguards I will go with HDB's set up for sure.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 11-15-2012, 02:53 PM   #31524
scottmac
scottmac's Avatar
Oddometer: 2,001
Threading your bars and installing the inserts is a real easy piece of work. Paul sends you the tap with your order
and it will cut threads into your aluminum bars like a hot knife through butter.
scottmac is offline   Reply With Quote
Old 11-15-2012, 04:21 PM   #31525
gmtech
Oddometer: 64
for those who have ordered a safari tank for their wr250 in the last 3 months and havnt gottten one look at the vendors thread what i posted
when i emailed aqualine about the hold up on the tanks.
http://www.advrider.com/forums/showthread.php?t=717160
gmtech is offline   Reply With Quote
Old 11-15-2012, 04:53 PM   #31526
ba_
ba_'s Avatar
Oddometer: 2,833
But you still don't have the tank from justgastanks right?
Old 11-15-2012, 05:02 PM   #31527
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,778
It's hard to tell what's going on...other than some bs between justgastanks and Aqualine. Looks like I'm going to have to go with IMS. Don't have time to fool with this kind of crap. Good luck though...
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 11-16-2012, 04:26 AM   #31528
Gany
Oddometer: 366
Originally Posted by pfy50 View Post
TNX WW Ronin,
That is what I needed to find out before doing another this farkle don't fit with that farkle mistake; (Lot of experience with that problem on my KTM 990) Does anyone sell a large area flatplate rack for the rear that just uses the 4 top threaded bolts like the pro moto racks? I'm trying to get a wider mounting surface than the smaller triangle shape racks to support a medium size ortlieb bag and camping gear. Yes you can use the small triangle racks, but I'd like to try for a little more support and attachment points.
Check out the racks Jared makes:
http://www.advrider.com/forums/showthread.php?t=789255
Gany is offline   Reply With Quote
Old 11-16-2012, 08:21 AM   #31529
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 591
Originally Posted by Buzzbomber View Post
Yes - these guys. http://www.automotivemachine.com/ind...d=51&Itemid=56
I have their triangle rack and it's worked great for my needs. They don't include attachment bolts though. When I bought mine it didn't come with spacers either but I see they include them now.
TNX Buzzbomber.
I like their X-Big rack; that may be the way I go. Function over form
Originally Posted by Gany View Post
Hi Gany,
Yes I've read the article on Jared's racks, but I already have a similar one (triangle shaped) which is aesthetically good on the WRR but functionally it is short changed in load carrying and attachment points for larger than rack size bags. Unless Jared is going to start producing some of those one off square racks for the WRR. I have another few weeks before I'm likely to order anything so I'll keep a watch out.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 11-16-2012, 09:34 AM   #31530
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,361
Automotive Machine & Supply Tail rack, and Wolfman racks....and Dirtbagz..since I already had them. Best set up for me.
(BTW...all of a sudden pics from PB are coming up larger than they used to..annoys me. If anyone knows how to remedy tat, feel free to share.)
With bags:
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Times are GMT -7.   It's 10:29 PM.
