Old 11-23-2012, 06:28 AM   #31621
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,753
Took advantage of the nice weather yesterday to get out for one last ride of the season (again). The start and the end of the day were both a little chilly, but it was nice for a couple of hours at mid-day.
I managed to tweak the right side hand guard during a little slide on some grassy two track. The ground was frozen and the grass was pretty slick. Lucky for me, I was wearing my Alpinestars Bionic Shorts ...
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 11-23-2012, 12:54 PM   #31622
northerndancer
wandering spirit
Oddometer: 90
love those famous words "no I'm alright!". I almost believe you. Where are you? Doesn't look anything like Edmonton that's for sure. My jealousy is overwhelming my sense of compassion. Sorry.
northerndancer is offline   Reply With Quote
Old 11-23-2012, 01:57 PM   #31623
thumpididump
MacGyver
Oddometer: 2,753
No, really, I was alright.... Fortunately, I was wearing my Alpinestars Bionic Shorts, which took the brunt of the impact. My hip is a little bit sore today, but only 3/10 on the pain scale.
I'm in Ottawa and we've had some pretty nice weather for this late in the year. No snow yet, but I'm sure it won't be long!
Keyboard Diarrhea
Old 11-23-2012, 05:33 PM   #31624
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Originally Posted by sieg View Post
Both procedures are simple and straight forward even a caveman could do it.
Go for it.
Did you replace all those parts they list as "New"--seals & gaskets, in they service manual when you changed your fork oil. Do you need that special wrench they show you need to take apart the head bearing?
leftystrat62 is offline   Reply With Quote
Old 11-23-2012, 05:47 PM   #31625
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,766
It's normally easier if you have the tools, but you can usually improvise. It's part of the learning experience
Same thing with the seals and gaskets. Lots of times, if you have a spare gasket you'll wind up not needing it. It's when you don't have the gasket that you wind up tearing the old one and get stuck. I'm guessing you're talking about the head bearing race that is pressed into the head tube? Those can be really hard to get out, and I've often left them in if they're in good condition. To reinstall you've almost got to have a hydraulic press...
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 11-23-2012, 05:48 PM   #31626
sieg
sieg's Avatar
Oddometer: 2,880
I don't replace any seals on an "oil change". An adjustable spanner wrench should work on the steering head nut. (Or a channel locks or punch and hammer are some other crude tool.)
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 11-23-2012, 07:03 PM   #31627
Kjharn
Hrmph?
Oddometer: 1,140
Or just go to your local hardware store and buy a proper sized socket. I think it's 36mm off the top of my head, but I tear too many bikes down to be positive.
-Kyle
Kjharn is offline   Reply With Quote
Old 11-24-2012, 03:51 AM   #31628
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 178
1) For changing fork oil, the fork seals don't have to be replaced since you won't be separating the inner and outer fork tubes.
2) I don't bother changing the fork cap o-rings unless (never seen one on my bikes) I were to discover it's damaged.
3) I DO change the copper washer (called a gasket on the parts catalogue/microfiche) at the bottom of the fork IF the base valve at the bottom of the fork were coming out.
However, for just an oil change, you will be leaving that alone (see No. 1 above).
4) You can make do without a proper spanner for the slotted nut on the steering head (although you run a risk of gnarling-up the slotted nut by using pliers or a hammer and screwdriver), but I feel you'll be making it harder to get a good feel for applying proper tension on the steering bearings.
I've tried it both ways, and since proper tension is easily reached with just your wrist, you get a much better feel for what you're doing with a spanner wrench.
If you have had your front fork modified/revalved and you want to keep the same feel from it, I'd find out from the guy that did the work (hopefully he sent you a spec. sheet detailing this) what fork oil he used and what oil level he set it at.
YZEtc is offline   Reply With Quote
Old 11-24-2012, 05:24 AM   #31629
sieg
sieg's Avatar
Oddometer: 2,880
Really, you can get a socket to use in place of the special tool for the spanner nut at a local hardware store? Pretty well stocked store then. I've always had to mill my spanner sockets out from a standard socket. Never knew they were so readily available.
Old 11-24-2012, 06:43 AM   #31630
ba_
ba_'s Avatar
Oddometer: 2,791
Greases
In the manual I see mentions of "Silicone grease" and "Lithium-soap-based grease". What are you using here?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is online now   Reply With Quote
Old 11-24-2012, 08:06 AM   #31631
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Check out the Yamalube webpage. If I remember, I'll take a picture later of the recommended "Lithium soap based grease" when I get back home.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 11-24-2012, 08:45 AM   #31632
HardWorkingDog
Harvey Mushman
Oddometer: 1,766
Lithium-soap based grease is the standard kind of "waterproof" bearing grease. Used to use the blue Bel-Ray, now I use the red Yama-lube stuff. Seems to hold up a little better.
Where is silicone grease called for? I have some that is also called di-electric grease, I use it in spark plug caps and around electrical connections that tend to get dirty/wet. Helps seal out moisture and prevent corrosion, and won't arc.
"Coffee first..."
Old 11-24-2012, 09:50 AM   #31633
ba_
ba_'s Avatar
Oddometer: 2,791
Front brake level pivot
Old 11-24-2012, 10:12 AM   #31634
HardWorkingDog
Harvey Mushman
Oddometer: 1,766
Front brake lever pivot
I like tri-flow for locations like that. Very thin, dirt doesn't stick to it, but it has lubricants--better than wd-40.
"Coffee first..."
Old 11-24-2012, 12:20 PM   #31635
Kjharn
Hrmph?
Oddometer: 1,140
I've got one for each of my bikes, ranging from old school SK sockets to cheap-o' ACE Hardware sockets. Even Harbor Freight. Always came through for me.
If I had the ability to mill sockets, I would do the same thing.
-Kyle
Times are GMT -7.   It's 02:25 PM.
