Old 11-26-2012, 08:38 AM   #31651
coresports
coresports
coresports's Avatar
Oddometer: 294
+1
i put in 1qt yamalube, start the bike up to fill the oil filter with oil, let it sit for a minute so any oil runs back down to the case then top it off slowly until it's between the 2 lines on the sight glass, sitting on the tires on level ground. over-filling can be almost as bad as under-filling - im kinda picky about that but that's just me!
Originally Posted by ba_ View Post
I just completed my first oil change. Things look good.
One question though --
the manual states that the engine oil quantity is 1.30L without filter replacement and 1.40L with filter replacement.
I've seen quite a few people state that they put in 1.30L (with a filter replacement) which seems too low.
Which is correct?
Regardless I put in 1.30L and then put in more oil little by little until I was halfway between the sight glass.
coresports is offline   Reply With Quote
Old 11-26-2012, 04:56 PM   #31652
ba_
ba_'s Avatar
Oddometer: 2,732
Originally Posted by coresports View Post
+1
Makes sense. How many of you are doing the step with the oil bleed bolt?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 11-26-2012, 05:11 PM   #31653
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,719
Not me.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 11-26-2012, 06:55 PM   #31654
japako
japako's Avatar
Oddometer: 592
I am, but the bike was used and I wanted to make sure everything was working after the first change.
japako is offline   Reply With Quote
Old 11-26-2012, 07:05 PM   #31655
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,682
I usually eyeball the quantity of oil, then go for a quick zip around the block, turn it off for a minute, and hold the bike up at a crooked angle in my sloped driveway, only to discover I've overfilled it way too much... then I pull the drain bolt for a second, spilling oil all over my hands as I frantically try to put the bolt back into place before all the fresh oil runs out into the drain pan with the old oil.... then I've let out too much, so I have to top it up... I usually repeat this process 2 or 3 times, wasting a litre or two of fresh oil, and making a big mess.
It would be a whole lot easier if I just measured.
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 11-26-2012, 07:24 PM   #31656
ba_
ba_'s Avatar
Oddometer: 2,732
But a whole lot less fun...
Old 11-26-2012, 08:07 PM   #31657
PappaBear
Oddometer: 2
Where is this spot, Garand?
What an idyllic setting for a motorcycle expedition.
Originally Posted by Garand View Post
Bob and I managed to find some good riding for our Rē's this weekend!
Definitely going to have to go back for more exploring!
PappaBear is offline   Reply With Quote
Old 11-26-2012, 08:24 PM   #31658
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,223
That pretty much sums up my last few oil changes also. Have found draining all the oil into a fresh catch basin and putting *most* of it back works well also!
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 11-26-2012, 08:31 PM   #31659
Mikef5000
Oddometer: 2,030
My understanding is that bleed bolt is handy immidiately after major engine work (post-rebuild) but is completely unnecessary after simple oil changes.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 11-26-2012, 08:32 PM   #31660
StG
Oddometer: 131
Is it correct that the reach for the brake/clutch levers are non-adjustable? And if so, is there any good reason for not offering that stock?
I'm pretty sure the brake levers on every mtb I've owned have been adjustable... Any recommendations for something duurable & affordable? Thanks!
StG is offline   Reply With Quote
Old 11-26-2012, 09:21 PM   #31661
ba_
ba_'s Avatar
Oddometer: 2,732
Now that makes sense to me...
Old 11-27-2012, 12:23 AM   #31662
andrew.pdx
Thump
andrew.pdx's Avatar
Oddometer: 29
My old Harley specified a bleed with every oil change to let out any air cavitation (thats why they are up high). I did it faithfully.
I was hit and miss about it on my WRz until one time when it took a long time to get any oil to gurgle out of it. Since then I have done it every time. How far can you ride without oil where it is needed?
andrew.pdx is offline   Reply With Quote
Old 11-27-2012, 06:40 AM   #31663
jon_l
jon_l's Avatar
Oddometer: 3,137
re: oil change volume
I have one of the old, clear, 1 liter BPA Nalgene bottles with graduations, so I measure my oil. Takes a couple extra minutes, but no waste and I know the volume is correct.
It is well labelled as 4-stroke engine oil, and lives with the chemicals in the garage, so no worry about ingestion.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 11-27-2012, 06:58 AM   #31664
ET-VT
ET-VT's Avatar
Oddometer: 244
There actually was a pretty good beer named 'Old Engine Oil', so specifying that it's 4-stroke is probably a good idea.
ET-VT is offline   Reply With Quote
Old 11-27-2012, 08:22 AM   #31665
coresports
coresports
coresports's Avatar
Oddometer: 294
not me
Times are GMT -7.   It's 09:48 AM.
