Old 12-10-2012, 07:20 AM   #31801
einnar
einnar's Avatar
Oddometer: 175
Tore down the engine yesterday on my R after it failed a compression test. Showed about 30psi on the guage.
This last summer my bike died on the highway suddenly. No power, and a puff of smoke suddenly came out the back end. Come to find out, the oil had suddenly disappeared. (I checked it less than 10 miles before it died.) I bought the bike used, and managed to put only 2 tanks of gas in it before this happened.
Months later, I finally have time, and a buddy available to help who has all the tools.. (Amazing how hard it is to get together when he travels for work, and I have a newborn in the house. )We tore it down, and found out the compression ring is broken. Fortunately, all the parts stayed in the groove until we coaxed the piston out of the cylinder (packing the bottom end before we did this.) All bits recovered!
While I had it apart, I tested the valves, and found that 3 of the 4 are definitely leaking... the 4th looked moist, so it probably is too.
Now to find a machine shop.. Kinda sad for a bike with about 8k on it.
An amateur practices until they get it right. A professional practices until they can't get it wrong.
Det finns inget dåligt väder, bara dåliga kläder
einnar is offline   Reply With Quote
Old 12-10-2012, 09:10 AM   #31802
KansasBob
KansasBob's Avatar
Oddometer: 454
I sounds like it may have had a pretty severe over heating event while in the hands of the PO.
KansasBob is offline   Reply With Quote
Old 12-10-2012, 09:27 AM   #31803
isaac004
isaac004's Avatar
Oddometer: 402
Anal fact for the day:
A DAMPER damps excessive movement, such as handlebar jerk or a bump.
A DAMPENER makes things more damp or wet.
So a steering damper will help you keep your front wheel in your intended direction.
A steering dampener will keep your steering assembly damp and wet.
A Father and Son Trip Down the Great Divide: http://www.advrider.com/forums/showthread.php?t=606301
A Father and Son Trip Through Death Valley: http://www.advrider.com/forums/showthread.php?t=869090
BMW F800GS, Yamaha WR250R, Suzuki DR650
isaac004 is offline   Reply With Quote
Old 12-10-2012, 09:53 AM   #31804
AZ TOM
Oddometer: 2,364
Excessive heat, the enemy of all things mechcanical. Good luck on the rebuild
AZ TOM is offline   Reply With Quote
Old 12-10-2012, 10:58 AM   #31805
sturgeon
sturgeon's Avatar
Oddometer: 742
I prefer the term `stabilitator`myself.
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 12-10-2012, 11:12 AM   #31806
what broke now
Petroleum Brother
Oddometer: 627
I usually take my dampener off this time of year. Why wear the thing out when everything is damp already?
Usually have to let stuff dry off a little before it can be properly damp anyway.
what broke now is offline   Reply With Quote
Old 12-10-2012, 11:23 AM   #31807
ramz
Professional Trail Rider
Oddometer: 1,720
Well actually, Webster's thinks otherwise:
damp·en verb \ˈdam-pən\
damp·ened damp·en·ing
Definition of DAMPEN
transitive verb
1: to check or diminish the activity or vigor of : deaden
2: to make damp
3: damp 1c
intransitive verb
1: to become damp
2: to become deadened or depressed
— damp·en·er noun
Examples of DAMPEN
Dampen the spot with a wet cloth.
The shower barely dampened the ground.
We wouldn't let the bad weather dampen our excitement.
damp·er noun \ˈdam-pər\
Definition of DAMPER
1: a dulling or deadening influence
2: a device that damps: as
a : a valve or plate (as in the flue of a furnace) for regulating the draft
b : a small felted block to stop the vibration of a piano string
c chiefly British : shock absorber
3 Australian : a simple usually unleavened bread of a kind made originally in the Australian bush
Examples of DAMPER
the pianist used the damper pedal on the piano for the quiet passages
ramz screwed with this post 12-10-2012 at 11:29 AM
ramz is offline   Reply With Quote
Old 12-10-2012, 11:54 AM   #31808
AZ TOM
Oddometer: 2,364
Old 12-10-2012, 12:41 PM   #31809
DougZ73
Lacks Freetime
DougZ73's Avatar
Oddometer: 4,918
So, if your DAMPER fails you, and leads you to wash out the front end and crash, in say a large puddle, it would in fact be a DAMPENER, now wouldn't it.
DougZ73 is offline   Reply With Quote
Old 12-10-2012, 08:21 PM   #31810
SuperD!
SuperD!'s Avatar
Oddometer: 110
Need a little help
I know I saw info about this in the thread somewhere but now I can't find it. Anyway, I recently discovered my battery completely dead, and now that I have it charged, my speedometer is reading a little bit high: I can easily break 200mph and cruise with traffic at 180 mph with ease now. I did confirm it's not set to kilometers.
Does anybody know if there's a cure for this?
SuperD! is offline   Reply With Quote
Old 12-11-2012, 01:59 AM   #31811
flatboarder
flatboarder's Avatar
Oddometer: 235
Send a message via Skype™ to flatboarder
That is far from matching even with km. :)
Concerning your problem: http://wr250rforum.forumotion.com/t5...-batter-change
Good luck!
flatboarder screwed with this post 12-11-2012 at 04:51 AM Reason: supply thread with similar problem
flatboarder is offline   Reply With Quote
Old 12-11-2012, 07:30 AM   #31812
expatbrit
Still pretty much a n00b.
Oddometer: 138
Hey! I can't get above 189, even with my speedo broken this way. You must have the superbike version.
If anyone finds a fix other than 'replace the head unit' I'd love to know. That's the only one I've seen. Luckily, it's not /hideously/ expensive, but it does seem a pretty broad problem.
expatbrit is offline   Reply With Quote
Old 12-11-2012, 08:14 AM   #31813
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 350
Trip Info
Not to change the subject BUT, I am planning on a return to Dawson, Yt. Canada for the 2013 Dust 2 Dawson, and I am seeking any long distance RR's done on the WRR. I've read Big Dog's and 10cup's RR's briefly, and was wondering if anyone could share a link to other LONG distance(over 5000miles) RReports done on the WRR. Also seeking favorable tire stores locations in Prince George,BC, Dawson and Whitehorse, YT from our Canadien brothers/sisters . Base route will be north from Tenn. to Calgary, AB to Jasper,Watson Lake, Whitehorse, Dawson,YT this part will be all Highway. So I am starting out with some type of Dual sport road-biased DOT tire; possibly pirelli MT 90 scorpions like I used on my 2010 MC trip on my KTM. I would like to do this on a smaller lighter bike; if I can work out the uncomfortable seat problem(currently trying out a Sargent seat); so I can enjoy some off road sections when I get to Alaska(Lord willing), up to Deadhorse , back down to Homer and over to Haines to get the ferry south to Prince Rupert. When I return to states I would like to pick up CDT down to Colorado and some out west trails before heading back East to Tennessee. Any kit,tires, favorite locals,insights would be appreciated.
TNX Paul
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 12-11-2012, 08:22 AM   #31814
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,326
Originally Posted by pfy50 View Post
...I am planning on a return to Dawson, Yt. Canada for the 2013 Dust 2 Dawson, and I am seeking any long distance RR's done on the WRR. I've read Big Dog's and 10cup's RR's briefly,...
Skierd is the one to talk to. He rode his WRR/X from Baltimore to Alaska, taking a southern route. Don't know if he quite made 5000 miles, cuz He did well over 5000 miles and he's still in Alaska
"Coffee first..."
Next Trip: didn't get enough...Death Valley
"it's a dog's life.............and I love it"
HardWorkingDog screwed with this post 12-11-2012 at 11:38 AM Reason: show off strike thru text
HardWorkingDog is offline   Reply With Quote
Old 12-11-2012, 08:46 AM   #31815
ramz
Oddometer: 1,720
skierd rode his WRX across the USA to CA, up the west coast to WA, and then took the ferry to Alaska.
ramz screwed with this post 12-11-2012 at 08:55 AM
Times are GMT -7.   It's 08:04 PM.
