Old 12-12-2012, 02:40 PM   #31831
AZ TOM
Oddometer: 4,044
Originally Posted by HardWorkingDog View Post
I waffled long enough, called justgastanks.com on Monday morning and they had just finished putting the parts together for the Safari 3.7 gal tanks...I placed my order and it's already on the UPS truck for delivery today.
NOT SURE WHY THEIR WEBSITE STILL SAYS OUT OF STOCK...
And, I randomly found they give a 5% advrider discount as well as free shipping.
That extra .7 gal ain't cheap, but I like the protection the tank provides. What the hell, if it's good enuff for Dingweed and BigDog, it's good enuff for me.
You will not be sorry Mine is really scuffed up( i have no idea how this happened) but protects well & uses all the 3.7 Mine is blue because thats all they had in stock at the time but I would prefer the clear.
AZ TOM is offline   Reply With Quote
Old 12-12-2012, 02:43 PM   #31832
bradrh
Oddometer: 424
Originally Posted by Pantah;20225612
2014 I'll use either Michelin T63 tires or Pirelli MT21's on my WRR. I expect to consume two sets. My WRR also has a fly screen, 3.7 gal tank, and requisite electronics. I find it plenty comfortable with stock seat and sheepskin. I wear Nike compression under shorts, which helps a lot too.
The longest trips I've taken on my WRR were only about 3k miles. Seems to me the only difference is tire consumption. If I were doing your trip, I'd have tires drop shipped to hotels.
[URL="http://www.alcan5000.com"
www.alcan5000.com[/URL]. Check out the route and itinerary. Maybe give you some ideas for your trip.
What flyscreen do you have? Pics? I have the laminar lip one (for a KLR), but I'm looking for a little more.
- DR650
- WR250R times 2
bradrh is offline   Reply With Quote
Old 12-12-2012, 06:04 PM   #31833
mpatch
Oddometer: 1,032
project complete
removed the flapper thing from the exhaust, no welding or cutting of pipe involved
mpatch is offline   Reply With Quote
Old 12-12-2012, 06:30 PM   #31834
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,182
Cee-Bailey flyscreen. I'm only 5'9" but works really well for me. It has a little flip shape at the top, plus it's fairly wide.
http://www.ceebaileys.com/yamaha/yamaha_wr250_450.html
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 12-12-2012, 09:09 PM   #31835
jgiacobbe
Skid plate tester
jgiacobbe's Avatar
Oddometer: 2,301
Originally Posted by blz-bob View Post
That would be great!
To all with the speedo reading 2-3x times high, I expierenced this also. Started after I serviced the bike and didn't get one of the battery terminals fastened but so tight. It loosened over the course of a ride. Next time I went to ride, the lights would work but when I went to start everything went dead. That is when I found the loose battery connection.
Afterwards I did a reset and reprogrammed my speedodrd with no change in behavior. Yesterday I took it for a short run and compared the trip odometer versus a GPS trip log. According to that my speedo/odometer were about 2.5 times faster than actual. Looked in the instructions for the speedodrd, found the section that talked about setting multipliers/dividers. Then set the unit to have 2.5 frequency divider. Took another short 4 mile ride after that. Looks like the speedo error is now within 10% and the odo seems pretty close. No long term testing yet but I'm just going to live with it like this for now. I don't want to buy a new speedo/head unit if the same thing will happen to it. Not sure what the cost of the instrument cluster is but I'm sure the speedodrd is cheaper.
Posted this on wr250r forum last night. http://wr250rforum.forumotion.com/t5...-batter-change
2009 Wee-Strom, 2002 VFR800
Sidecar hack coming soon
jgiacobbe is online now   Reply With Quote
Old 12-12-2012, 09:56 PM   #31836
Blaise W
Blaise W's Avatar
Oddometer: 679
That CB Flyscreen looks great! However, for long rides I use a Wolfman carry all mounted above the headlight and it looks like the screen would interfere with the mounting straps. 'May have to give it a shot anyway. A little extra wind protection would be welcomed on the highway.
Blaise W is offline   Reply With Quote
Old 12-12-2012, 09:58 PM   #31837
Llamaha
Oddometer: 850
Question re; Wolfman E12 enduro bags
Hey guys,
I picked up a new WR250X the other day and I'm currently deciding between the Wolfman expedition panniers and the Wolfman E12 bags. I am very concerned that the E12's won't fit properly because there is no plastic panel covering the exhaust. Has anyone successfully used this for extended periods of time? Do they sit properly and function properly? Would it be possible for someone to post pictures of the bags from both sides of the bike, and perhaps the rear?
It would be very much appreciated if you could, thank you.
Llamaha is offline   Reply With Quote
Old 12-13-2012, 03:21 AM   #31838
flatboarder
flatboarder's Avatar
Oddometer: 278
Originally Posted by Llamaha View Post
Hey guys,
I am very very happy with the giant loop coyote.
Using stock exhaust. Applying some piece of protective heat shield sheet to it. In my opinion a perfect solution, well suited for sporty riding and offroad.
flatboarder screwed with this post 12-23-2013 at 04:30 AM
flatboarder is offline   Reply With Quote
Old 12-13-2012, 07:07 AM   #31839
KansasBob
KansasBob's Avatar
Oddometer: 515
Good description on how your head went south, and info on the work around. Much better than buying a new head. Here is something that shows a little of what you are talking about, for people like me, who don't have a speedodrd........... yet.
http://www.youtube.com/watch?v=ikH6Shk3u44
KansasBob screwed with this post 12-13-2012 at 07:25 AM
KansasBob is offline   Reply With Quote
Old 12-13-2012, 07:36 AM   #31840
bradrh
Oddometer: 424
wolfman e12
Hey guys,
Wifey is using the E-12 on her WRR. Works great. The X has a heat shield like the R doesn't it? It gets a little warm on that side, but not too bad. Put beer and chocolate on the left side. See 3rd pic down here:
http://www.advrider.com/forums/showthread.php?t=816651
- DR650
- WR250R times 2
Old 12-13-2012, 09:35 AM   #31841
jon_l
jon_l's Avatar
Oddometer: 3,309
Hey guys,
Wolfman E-12
I have no good side photos right now, but these are what I took for someone who asked about attachment points:
The right bag has scuffed the plastic heat shield a little which is no concern for me; otherwise no issue. My heat shield is never too hot to leave my hand on, so can't hurt the saddle bag or contents.
CBF1000 & PCX150
jon_l screwed with this post 12-13-2012 at 09:40 AM
jon_l is offline   Reply With Quote
Old 12-13-2012, 09:46 AM   #31842
brians
brians's Avatar
Oddometer: 5
Will Renthal 613 handlebars fit with standard cables?
Sorry for the newbie question but my searches produce soooo many results and it is difficult to find a definitive answer.
The standard steel bars are bent on my newly acquired WRR and it is an opportunity to fit some Renthals.
I like the 613s (previously known as Dakar Highs) as they encourage me to stand up on the pegs in the rough stuff and are generally much more comfortable.
Are the standard cables long enough or do I need longer ones?
Many thanks
Brian
brians is offline   Reply With Quote
Old 12-13-2012, 10:12 AM   #31843
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Many thanks
Brian
Probably not Brian, I had the McGrath 795mm width and it was getting kind of tight to reach, but mine was a twinwall 1 1/8" which should make little overall difference. Renthal recommends a Yamaha bend that goes only 802mm on width for Wr250r. Check out this chart
http://www.dirtwarehouse.com/renthal...ocross.htm#613
Brian here is Renthals recommended models page http://www.renthal.com/File/fit_my_b...&bikedate=2008
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 12-13-2012, 10:48 AM   #31844
jgiacobbe
Skid plate tester
jgiacobbe's Avatar
Oddometer: 2,301
Thanks for the feedback. I need to go out and double check against GPS the actual odometer versus just a trip odometer before I consider it a true fix but I don't expect it to be off.
On the SpeedoDRD I'd say it is a great product. It is plug-n-play with the WRR/X and some other bikes but is a pretty versatile system that can be wired into plenty of other bikes and used in plenty of custom applications. It is those extra features that are helping us in this situation. With one button I won't say programming it is intuitive, but it isn't that hard if you read the directions and watch the video.
Old 12-13-2012, 12:08 PM   #31845
burtonrider3889
Oddometer: 862
Ok, I'm trying to pick up a WR250R. I've been having a super hard time finding one close by. I found one that is a 6 hour drive away that I think is a good deal. What do you guys think of a 2012 WR250R with 8000 miles for $3500? No mods, bone stock, immaculate condition supposedly.
burtonrider3889 is offline   Reply With Quote
Times are GMT -7.   It's 01:49 PM.
