Old 12-27-2012, 10:46 AM   #32071
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
Set sag FIRST.......then move on to preload/rebound settings
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 12-27-2012, 10:51 AM   #32072
ba_
ba_'s Avatar
Oddometer: 2,723
The dealer did help me set sag albeit very quickly when I picked it up.
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 12-27-2012, 10:57 AM   #32073
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by ba_ View Post
Thanks.
I'm 150 without gear so perhaps I should just leave it for now and see how it rides with the other settings changed.
At 150 lbs the stock spring will probably be too stiff to even get a proper sag setting set all the way soft. That's part of what a sag setting is for................... to see if your spring is too soft, too stiff, or just right. I would do what HF said and go all the way soft. Support your bike off the ground, back the nut off until the spring is loose.......... there will be like one thread left on the top of the shock. Screw it down a couple of turns once it starts to compress the spring.
C Daddy..... I'm not sure you said that right............ Did you mean to say, Set the sag, then adjust the compression, and rebound clickers? The preload "IS" the sag.
KansasBob screwed with this post 12-27-2012 at 04:43 PM
KansasBob is offline   Reply With Quote
Old 12-27-2012, 11:22 AM   #32074
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
set sag before adjusting preload and rebound in front too....
Old 12-27-2012, 01:46 PM   #32075
mpatch
Oddometer: 903
Preload and sag are the same thing.
You can't adjust front sag/preload without spacers or a spring swap.
mpatch is online now   Reply With Quote
Old 12-27-2012, 02:16 PM   #32076
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,479
So the guys walking down the street with their pants hanging off their ass have preload problems?
swimmer is offline   Reply With Quote
Old 12-27-2012, 03:01 PM   #32077
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
I was referring to compression and rebound settings in the forks.......bottom line, set the rear sag first then screw around with the clickers for rear shock/forks......
Old 12-27-2012, 05:16 PM   #32078
AZ TOM
Oddometer: 3,880
No thats pantload
AZ TOM is online now   Reply With Quote
Old 12-27-2012, 05:21 PM   #32079
shep546
shep546's Avatar
Oddometer: 215
Does anyone know where I can get the exhaust/side cover in this video?
shep546 is offline   Reply With Quote
Old 12-27-2012, 05:47 PM   #32080
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,969
^^^^ It is "Cutomized".
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 12-27-2012, 05:56 PM   #32081
shep546
shep546's Avatar
Oddometer: 215
I tried messaging the uploader, his description says it's made for the 250r/x models, not the F?
edit: the uploader messaged me back, he doesn't speak english very well but he gave me their website here
shep546 screwed with this post 12-27-2012 at 08:35 PM
Old 12-28-2012, 02:00 AM   #32082
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,969
The side seat bolts look like an F, where the side panel is from too. Looks like he merged the two.
Sent from my DROIDX using Tapatalk
Old 12-28-2012, 02:32 AM   #32083
Llamaha
Oddometer: 819
Am I the only one that thinks the WRR/X isn't underpowered ? I keep reading everywhere that it is but for me it has plenty of power. I've owned both the WRR and WRX, left them stock and only ever needed more power in sand or above 115km/h. Used to have an RM250, would never ever go back to it even if it does have 45hp at 100kg, I much prefer the WR.
Llamaha is offline   Reply With Quote
Old 12-28-2012, 02:41 AM   #32084
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,174
only on the highways and sometimes i would like better bottom end power but really its not a bad package
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 12-28-2012, 04:50 AM   #32085
1Down-5Up
1Down-5Up's Avatar
Oddometer: 109
Headlight adjustment
Anybody adjust their headlight? I looked in the owners manual and there was nothing listed.
I thought I'd ask before taking the unit off (lazy). If I jab the front brake the lighting positions to the correct angle.
Hi beam is useless because it's all in the trees. It must be blinding traffic as it is.
1Down-5Up is offline   Reply With Quote
Times are GMT -7.   It's 12:35 PM.
