Old 12-28-2012, 10:20 PM   #32101
jrou111
Stair Climber
jrou111's Avatar
Oddometer: 294
Originally Posted by alansz400 View Post
That cover comes off real easy. I took mine off when my site glass was pushed in. Heres what it looks like with the cover off. I reused the gasket and havent had any oil leaks. I wounder if somthing came loose inside the motor and got wedge between the gear and the case?
Update:
I opened up the side case...not good.
Looks like the nut on the counterbalancer backed off and went for a ride, until it got wedged in the gears on the waterpump.
I've got a replacement clutch case cover on the way (complete with waterpump gear), so I think it shouldn't be too difficult to repair. Hopefully.
Anybody seen anything like this on a WR250? Seems pretty uncommon.
jrou111 is offline   Reply With Quote
Old 12-29-2012, 05:34 AM   #32102
1Down-5Up
1Down-5Up's Avatar
Oddometer: 109
Originally Posted by krussell View Post
I'm trying to decide what sort of rear rack to put on my WRR.
For the cheapie guys out there I used a piece of 3/4 " plywood to replace the tin lid on the Yamaha rear rack.
Nice thing is you can cut them to any shape to experiment. My latest one is cut to fit the Wolfman tail bag.
I have a plywood box for my 68 cc chainsaw that I just screw to the plywood plate and it holds.
I'm going to try a trip with a few overnights so I'll make a bigger one to hold the hammock, bag, and other bulky gear.
In this pic I have my FatMax saw tucked under the bag and the anti-slip stuff contact glued onto it.
1Down-5Up is offline   Reply With Quote
Old 12-29-2012, 06:40 AM   #32103
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
I made my own as well from a scrap piece of .25" aluminum. Picture is before painting. After seeing it my wife said I should have just bought one. Guess she wasn't impressed with my machining skills. I made some aluminum spacers to fit it above the fender of the type that are supplied with the purchased aluminum racks.
FWIW in case it helps someone, I posted a question several pages ago asking about the mounting hole pattern spacing. The front-back spacing is 70mm and the side-side spacing is 50mm.
swimmer is offline   Reply With Quote
Old 12-29-2012, 07:00 AM   #32104
AZ TOM
Oddometer: 4,030
Originally Posted by KansasBob View Post
As I remember........... the consensus was that the bike is sprung stiff for the average rider and the rear shock didn't have near enough rebound damping........ even when maxed out. For a light rider like yourself, the lack of rebound damping, and stiff spring makes the problem even worse. The rear wheel hops up in the air when it bounces of rocks, ledges, and roots......... ect. The settings were to try and keep the rear wheel on the ground with the stock suspension. In other words....... the best you can get with what you got. The right spring for your weight and a re-valved rear shock with more rebound damping is what you "Need" but, if that isn't in the cards right away it's a good compromise especially for someone your weight.
Agree with almost all your advise with the exception of more rebound damping. Once I backed off the spring tension & increased the sag the rebound damping seems more than adequate, no more kicking me forward over the front wheel. Too much rebound damping will also keep the rear wheel off the ground & not return quick enough to follow the terrain.
AZ TOM is offline   Reply With Quote
Old 12-29-2012, 08:13 AM   #32105
oldtrucks
oldtrucks's Avatar
Oddometer: 288
Originally Posted by jrou111 View Post
Update:
After seeing the first picture I figured it would look like that inside. How many miles are on the bike?
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin
oldtrucks is online now   Reply With Quote
Old 12-29-2012, 09:13 AM   #32106
KansasBob
KansasBob's Avatar
Oddometer: 515
Yea, me too. The locking tab for the balancer gear nut is laying there in the case. Must not have been bent over all the way, or something. A close up of the locking tab would be nice
KansasBob is offline   Reply With Quote
Old 12-29-2012, 09:49 AM   #32107
jon_l
jon_l's Avatar
Oddometer: 3,281
Originally Posted by expatbrit View Post
I'm failing here -- I have a WRX and a WRX combo, both in blue.
Any issues with the turbo and the trailer?
Mine is the basic Impreza with 2.5 L engine. Pulls a trailer extremely well for a 4-banger.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 12-29-2012, 11:48 AM   #32108
alansz400
alansz400's Avatar
Oddometer: 968
Update:
Wow that sucks. Looks like it could have been alot worse. Luckily the case didnt get cracked. Getting ALL that metal out of the motor looks like its going to be the hard part.
alansz400 is offline   Reply With Quote
Old 12-29-2012, 12:11 PM   #32109
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,223
Plastic cutting boards work, too.
As it is, I'm scraping a boot trying to throw a leg over the bike. I'm going with the Automotive Machine & Supply Triangle Rack to keep it a low and contoured profile.
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 12-29-2012, 04:49 PM   #32110
shep546
shep546's Avatar
Oddometer: 215
Really thinking of ordering these side panels... only thing is I don't really feel they are worth the price.
shep546 is offline   Reply With Quote
Old 12-29-2012, 05:11 PM   #32111
Joe Watson
Joe Watson's Avatar
Oddometer: 1,033
A ride report will come at some stage, but I have been working on the video and thought I would post up Episode 1. A mate and I nailed down a date and set to work on making our dreams of a Cape York ride possible. Two very well set up WR250R's and a lot of planning later and we did it in September of this year.
Please subscribe to my youtube channel for more vids and to keep updated with the latest episodes.
Joe Watson is offline   Reply With Quote
Old 12-29-2012, 05:53 PM   #32112
ba_
ba_'s Avatar
Oddometer: 2,771
What that thing that is in the line of sight on your buddies bike?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 12-29-2012, 06:08 PM   #32113
scottmac
scottmac's Avatar
Oddometer: 1,760
Those are really nice. The right panel looks like it can do the job of a heat panel too by keeping your gear off of
the pipe. Sure wish they were cheaper.
scottmac is offline   Reply With Quote
Old 12-29-2012, 06:40 PM   #32114
Joe Watson
Joe Watson's Avatar
Oddometer: 1,033
Hey mate. That is is front brake line. It is an aftermarket braided one.
Old 12-29-2012, 07:49 PM   #32115
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 88
Did the AIS removal and air box flapper mod today, quite simple and really only took an hour tops. Made my own block-off plate with a scrap of aluminum bar stock I had laying around and lock-tited it down for good measure
While I had the bodywork off I took the time to install a battery tender lead. Tucked in in nice & tight, real clean.
Tucked the fuse behind the battery strap, ran the wire up the plastic tray, added a couple zip ties and used a Velcro strap to tie it up under the subframe. You don't even know its there.
Also got the Shinko 244 tires on, looks mean! Can't wait to ride, too bad we got 4" of snow the past couple of days.
More mods to come of course....
Only God decides the LENGH of your life, but you decide its WIDTH.
ADWrider is offline   Reply With Quote
Times are GMT -7.   It's 01:42 AM.
