Old 01-05-2013, 04:29 PM   #32281
Strog
Geek on two wheels
Strog's Avatar
Oddometer: 406
Originally Posted by r6realtor View Post
Love it!
Dale S.
Strog is offline   Reply With Quote
Old 01-05-2013, 04:33 PM   #32282
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,842
Well its an r but I have been doing my best to make it an x
Good job blurring your plate in all but one picture.
You can't be too safe.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 01-05-2013, 04:54 PM   #32283
jon_l
jon_l's Avatar
Oddometer: 3,149
Originally Posted by ba_ View Post
Thanks for the explanation ramz.
Lowering with the stock adjustment is such an easy modification that it certainly will not hurt to try it. Same with lowering the forks in the triples.
If it doesn't feel right I can always change it back.
I struggled with this too, couldn't find clear direction, so I raised my forks in the clamps by 3/4". My rear shock clevis is a couple threads from the bottom. I torqued it up and went for a test ride, and 3/4" felt fine, so I haven't changed it.
Rick has provided some sound advice. Sounds like 15-19mm range should work, if you lower the clevis all the way
CBF1000 & PCX150
jon_l screwed with this post 01-06-2013 at 07:14 AM
jon_l is offline   Reply With Quote
Old 01-05-2013, 05:45 PM   #32284
avgas
amateur
avgas's Avatar
Oddometer: 81
Has anyone tried a Pirelli scorpion rally front tire on their wr250r? I'm looking for something that will handle the deep sand better than my current T63 front, can still handle sharp volcanic rock and won't melt away on the roads. Maybe I'm just to indecisive, I can't decide between the scorpion rally, scorpion pro or mt-21.
avgas is offline   Reply With Quote
Old 01-05-2013, 05:50 PM   #32285
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,025
I run Pirelli Scorpion XCMH's and find them to be pretty good in southern NJ Pine Barrens sand. They are OK on road. Being a 90/10 tire full knobby, I try not to be on pavement more than I need to. No sharp rock experience, so I can not comment on that aspect.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 01-05-2013, 06:03 PM   #32286
zimzooma
zimzooma's Avatar
Oddometer: 175
I also run the scorpions on my WR and they work well. I'm using the scorpion pros. I'm in upstate NY most of the time and they are quite good in the wet and rocky terrain here. Not so awesome in gravel. I've put quite a few road miles on them and they seem to wear well.
Don't check out my adventures.
zimzooma is offline   Reply With Quote
Old 01-05-2013, 06:21 PM   #32287
what broke now
Petroleum Brother
Oddometer: 1,379
Anyone ever try to true a rear brake disc? If so, how did you proceed and what worked?
I have one out about 7 thou; it works ok.but very irritating.
what broke now is offline   Reply With Quote
Old 01-05-2013, 06:41 PM   #32288
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,685
I recently swapped a worn out D606 for a Scorpion Rally on the front of my WR, and while I didn't get a chance to put many miiles on it before winter arrived, I definitely like it a lot. Pretty aggressive tread pattern and it hooks up really well. As long as it lasts for as many rides as a 606 on the rear, then I'll be happy.
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 01-05-2013, 08:46 PM   #32289
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,866
Yes, with an adjustable wrench, and very carefully.
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 01-06-2013, 07:01 AM   #32290
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 563
This is what I did for my Kawasaki. Move the wheel back and forth till you find the high spot, and mark the side it is out to and the location on the rotor. Remove the rotor and place the flat opposite side down on a known smooth surface preferably a thick glass covered counter. With a wooden/rubber/phenolic mallet tap the high spot once. Check to see if it is now flat against the glass. If not do it once more in the same spot. It will be as close to flat as you will probable get(not perfect but usable). If you miss or continue hitting it hard you will set up waves in the rotor and you might as well throw it out, because it is going to vibrate/pulse every time you brake. Good luck
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 01-06-2013, 07:16 AM   #32291
jon_l
jon_l's Avatar
Oddometer: 3,149
Originally Posted by pfy50 View Post
This is what I did for my Kawasaki. Move the wheel back and forth till you find the high spot, and mark the side it is out to and the location on the rotor. Remove the rotor and place the flat opposite side down on a known smooth surface preferably a thick TEMPERED glass covered counter. With a wooden/rubber/phenolic mallet tap the high spot once. Check to see if it is now flat against the glass. If not do it once more in the same spot. It will be as close to flat as you will probable get(not perfect but usable). If you miss or continue hitting it hard you will set up waves in the rotor and you might as well throw it out, because it is going to vibrate/pulse every time you brake. Good luck
I'm pretty sure pfy50 would agree with the edit.
CBF1000 & PCX150
Old 01-06-2013, 07:31 AM   #32292
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,104
They certainly are fun through the twisties!
GotMojo? is offline   Reply With Quote
Old 01-06-2013, 10:12 AM   #32293
steveb126
Adventurer Anonymous
steveb126's Avatar
Oddometer: 1,019
I know exactly where that's at. I'm looking for a WR in OHIO.
I may not be much, but I'm all I think about.
Wee & Wingabago Wanderings
steveb126 is online now   Reply With Quote
Old 01-06-2013, 10:23 AM   #32294
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 563
Yes jon_l,
Silly me
Old 01-06-2013, 10:38 AM   #32295
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,842
Oh so you are sold on the WR then???? Excellent. How far are you willing to go?
I will make you the same offer I make a lot of guys looking at maybe buying a bike far away: I love road trips, comp my gas and food and I'll drive damn near anywhere and trailer it back for ya....
Times are GMT -7.   It's 05:25 PM.
