Old 01-12-2013, 03:38 PM   #32476
japako
japako's Avatar
Oddometer: 436
Originally Posted by pfy50 View Post
Yes, cjbiker the front is computer spin balanced with no rim lock just a larger alum. air valve cap is what you probably see.
skierd, those bags up front are only light clothing about 2 lbs per side and were there when I had the previous OEM trailwing on it with no problem. This problem only showed up after I mounted the new Kenda 270 which is the first time I have used one, and was wondering if anyone who has used them before ever ran into this problem.
As for the fuel storage I may drop the rotopax before the trip; I'm still in the pre-trip testing stage for full up load.
Just for the heck of it, can you jack up the bike until the front wheel is off the ground?. If you can, make sure the brake is not dragging and spin the wheel. If it stops at the same place after a few times, it is more than likely the wheel is out of balance.
I don't trust spin balances, as they need to be calibrated and they can be off. Also not many shops think that knobbies need to be balanced.
This is not a perfect way, but it will show an out of balance wheel.
japako is online now   Reply With Quote
Old 01-12-2013, 03:49 PM   #32477
GAS GUY
GAS GUY's Avatar
Oddometer: 2,043
Don't actually spin the tire, just lightly move it to various spots every 45 degrees or so and see if it stays or keeps rolling to a certain area.
2008 KLR 705
2001 GAS GAS 321
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 01-12-2013, 04:05 PM   #32478
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 2,570
Originally Posted by ArmyJoe View Post
I just noticed that justgastanks.com is a bit of a misnomer. In addition to the obvious, they also have Wolfman gear, Seat Concepts seats, and Rotopax gas cans. Another plus is they offer 5% off to Advriders.
I have a stock bike in desperate need of attention. Are there any other places with one-stop shopping for touring farkles?
dualsportarmory.com has about the best listed prices I have found plus they also give 5% adv discount. Look for their thread in the vendors section.
swimmer is online now   Reply With Quote
Old 01-12-2013, 04:39 PM   #32479
Scharcon
Oddometer: 14
Originally Posted by ba_ View Post
Chad are you still running your throttle tube and housing 180 degrees upside down? I'm just completing my HDB install and I don't have enough slack in the throttle cables with the housing in the stock position.
I have the HDB setup and am running throttle cables upside down with no issues. Also agree with Chadx with the 1-1/2" max. No way could I have gone the 2" with stock cable even upside down.
Scharcon is offline   Reply With Quote
Old 01-12-2013, 05:27 PM   #32480
shep546
shep546's Avatar
Oddometer: 194
wheelingcyclesupply
shep546 is offline   Reply With Quote
Old 01-12-2013, 06:02 PM   #32481
burtonrider3889
Oddometer: 329
Pic from today. Unfortunately I think I sprained my ankle pretty early in the day so I was taking it pretty easy. Tuckahoe is some DIFFICULT terrain.
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
burtonrider3889 is offline   Reply With Quote
Old 01-12-2013, 06:10 PM   #32482
krussell
krussell's Avatar
Oddometer: 284
Laugh
First farkle on the WR250R this weekend! Been going back and forth on racks, ended up with the IMMIX racing model.
http://www.immixracing.com/make/yama...argo-rack.html
Went on easy, very solid.
Why this one? Well, I like the look of the billet ones, but not the shape. And I plan on having it covered most of the time, either with camping gear, a Pelican, or a milk crate. I narrowed it down to this one and the TCI Borrego, but thought the TCI was a bit too big. The other thing I liked about the IMMIX was that unlike the Borrego, it's a natural extension of the seat, keeping the same line, where the Borrego is more level, but out of line with the seat. I like the larger mounting footprint of the Borrego and the IMMIX. Anyway, it's on and way too clean.
Here are some pics, the ones on the IMMIX site are much better. Did a test fit of a Pelican and a milk crate too. Oh, and the best part, on sale for $80.
Kevin '12 K1600GTL, '13 TR650 Strada
krussell is offline   Reply With Quote
Old 01-12-2013, 06:15 PM   #32483
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,106
Originally Posted by MeefZah View Post
Is the engine case, specifically the stator side, aluminum or magnesium?
I holed mine today, punched the shifter right through it. If aluminum, I can get a guy to weld it up... if not aluminum I guess I'll be buying a new one.
If I can weld it up, should I leave it on the bike to keep from warping it, or pull it off?
Not sure if this guy makes case savers for anything other than KTM's but you could drop him a PM and find out?
http://www.advrider.com/forums/showthread.php?t=839454
If not, I bet Sandman could gin these up for the WR?
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 01-12-2013, 06:17 PM   #32484
ba_
ba_'s Avatar
Oddometer: 1,533
Triumph, BMW, Yamaha
ba_ is offline   Reply With Quote
Old 01-12-2013, 07:10 PM   #32485
japako
japako's Avatar
Oddometer: 436
Yep, that works also.. By spinning the tire, I get to drink a beer before it stops. By the time it's balanced I'm done for the day...
Old 01-12-2013, 07:22 PM   #32486
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,106
I get to drink a beer..... it's balanced
I don't screw with it anymore.....I automatically just throw four 1oz. weights directly across from the Rim Lock/Valve stem......pretty damn close to balanced.......and I use spoke weights....not those adhesive rim strips that fly off.....you can see'em on the front spokes in the below pic (I don't bother to balance the rear)
Crawdaddy screwed with this post 01-13-2013 at 07:50 PM
Old 01-12-2013, 08:08 PM   #32487
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 47
It's almost ready for my trip(ref:#31820,31923), extra fuel capacity includes Safari tank, newer 1.75 rotopax and 8L. fuel bladder. BUT I am having an issue with the current tire. I just put on a new Kenda 270 on the front and I am getting a slight pogo/bouncing action in the front suspension at around 28-35mph more so when I am slowing down from a higher speed than when accelerating up through that range. I have eliminated some of it by uping the rebound setting, but have not eliminated it. Has anyone here have a similar problem?
Crikey, do you ever plan to stop for gas? What's your range with that setup?
Only God decides the LENGH of your life, but you decide its WIDTH.
ADWrider is offline   Reply With Quote
Old 01-13-2013, 05:33 AM   #32488
1Down-5Up
1Down-5Up's Avatar
Oddometer: 60
I think he will have to change tires before he has to refuel!!!
Safari tank= 15L +8L +7L Roto= 30L @ 27km/L = 810 km (506 miles) Best case scenario
As for the tire, I would take the wheel off , let the air out and break the bead. Check the tube for kinks and rotate the tire
and see if a new position helps.
1Down-5Up is offline   Reply With Quote
Old 01-13-2013, 07:03 AM   #32489
bradrh
Oddometer: 143
Did you make sure the bead is seated evenly ?
- DR650
- WR250R times 2
bradrh is offline   Reply With Quote
Old 01-13-2013, 07:05 AM   #32490
zimzooma
zimzooma's Avatar
Oddometer: 175
I just put a steel braided front brake line on my X/R to replace the damaged stock line. The oversized X rotor and the feel of the steel line add up to create a superb braking package. Should have done it sooner.
Don't check out my adventures.
zimzooma is offline   Reply With Quote
Times are GMT -7.   It's 01:50 PM.
