01-18-2013, 03:48 PM
#32566 |
Oddometer: 9
They're so different I'm sure they won't. I have a YZ250.
01-18-2013, 03:49 PM
#32567 |
Oddometer: 2,086
IMO Kinda 270's SUCK !
Life is to short to run suckey tires
ADV Relay Rider 08 (The Texas Connection) Ride Pooie Ride ![]() Don't stop riding until you get to the crash , you might save it! |
01-18-2013, 07:32 PM
#32568 | |
Adventure Geek
Oddometer: 55
Something else I've found that works well are Dyna Beads. Over the years I've used lead, Slime, Ride-On, and now Dyna Beads. I was pretty skeptical about the beads, but I spent a weekend running tests with the same tire/rim combo and there was no more room for doubt. Way out of wack with no compensation, decent with lead, smooth as glass with both Ride-On and Dyna Beads. |
01-18-2013, 08:00 PM
#32569 |
Oddometer: 87
Has anyone replaced the radiator shroud, on the right side? Wondering if you need to order the two pieces and the plastic rivets? I am struggling to see the rivets in the parts fiche.
Sent from my iPad using Tapatalk HD |
01-18-2013, 08:47 PM
#32570 |
Oddometer: 1,290
01-18-2013, 09:08 PM
#32571 |
Oddometer: 87
Not looking for brace or guard, the plastic shroud itself got damaged and I need to replace it.
01-18-2013, 09:18 PM
#32572 |
Professional nOOb
Oddometer: 350
Tire Problems
TNX for the recommendation on tires guys. I have one more check to do tomorrow to see if it is "out of round", if it is I will probably leave it on for now and just do some winter trail riding. I have a fairly new 606 on the rear. Possibly the high spot will get worn in a little while I do load testing in anticipation of my summer trip. I only payed $46.00 for the Kenda 270 so it isn't worth taking it off and returning it to Rocky Mountain MC. I already have a TKC 80 or Shinko 700 to replace it with in the spring before I leave for my trip to AK./Yukon and I have a set of Warp 9 wheels I'll use for that trip.
ps. Isn't a IRC GP1 a copy of the Kenda 270? kenda 270 ![]() IRC GP1 ![]() ![]() ![]() ![]() ![]()
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875 2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours May the Lord bless you and keep you in all the Dark places you must travel
pfy50 screwed with this post 01-18-2013 at 09:31 PM |
01-18-2013, 09:41 PM
#32573 | |
hunting and riding!!
Oddometer: 1,664
I put a Flatlands racing guard on mine,it touches the big IMS tank lightly so i had to put some rubber between the two
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel! WR250r of Awesomeness.......now with extra added Awesomeness! |
01-18-2013, 09:43 PM
#32574 | |
Oddometer: 69
01-19-2013, 03:11 AM
#32575 |
Feel lucky?
If anything, the Kenda K270 is a copy of the IRC GP1.
A cheap copy. I was using IRC GP1s on my 1990 Yamaha DT-200R back in the day, and they were/are awesome tires for smooth running on the street with casual off-road use, and that's the reason I mounded the IRCs for a trip up to Mt. Washington from CT. back then. The wheels were balanced after the tires were mounted (with an old-fashioned static balancer), and the bike was as smooth as glass for the trip up and back. Myself, I'd recheck the balancing job with another wheel balancer. You may be surprised. |
01-19-2013, 05:39 AM
#32576 |
Oddometer: 541
First post on this thread, but I have been reading on it a lot.
You guys are busy on here. Just picked this up.
01-19-2013, 05:49 AM
#32577 | |
jack of all trades...
Oddometer: 6,587
Actually the Kenda is a "copy" of the old Yokohama, which was run as OEM on a bunch of 70s Honda dual sports. I was running the Yokohamas on my trials bike around 1983. I'm thinking Kenda may have bought the Yokohama tooling when they quit doing bike tires. Shinko got some of the tooling too. Personally I've had great success with the Duro HF903/904, but I don't know if they're available in the correct rear size. I have always wondered about the GP110 myself. But the Duros have done so well both on and off road, that with the price they are, I just won't change. Oh, I run them on a 650, was just nosing around in this thread.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 |
01-19-2013, 05:56 AM
#32578 | |
Professional nOOb
Oddometer: 350
01-19-2013, 05:59 AM
#32579 | |
Professional nOOb
Oddometer: 350
Thanks for the clarification, I believe I have seen your avatar on some RR's and 650 forums ![]() ps the Motorcycle-superstore still sells them: http://www.motorcycle-superstore.com...ront-Tire.aspx
01-19-2013, 06:26 AM
#32580 |
Oddometer: 195
