Old 01-19-2013, 07:21 AM   #32581
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 77
Send a message via AIM to YZEtc
Originally Posted by pfy50 View Post
Yes,YZEtc you may be correct about the order. The Kenda 270's seem to run $5-7 cheaper than the IRC GP1's and I was just looking for an inexpensive trail and hard surface general tire. What type of mileage did you get out of your GP1s, and what pressure did you run it at off- Hard surface?
I can't remember how long they lasted, but I don't recall any memories of thinking they wore out too fast.
I did buy them for street-biased use, and they were excellent for that.
I do remember the GP1s having thin construction compared to an off-road knobby or even the stock Bridgestone tires from a WR-250R, so they're probably not the best to prevent pinch flats in rocky terrain.
For dual-purpose off-road use, I typically compromise at 18 psi.
YZEtc is online now   Reply With Quote
Old 01-19-2013, 07:25 AM   #32582
30Bones
30Bones's Avatar
Oddometer: 4,572
I have used 270's on a KLR and a KTM 640 with good results and life. My husky ate rear tires and an MT21 would last 1500 miles. so I never tried a 270 on that bike.
On a light bike like the WR I see no reason not to run a 270 if you do street and mild dirt. They are soft and were squirmy on my heavy KLR but somehow wore really well. I think low HP helps a lot, and on a significantly lighter WR I think they would wear very well.
Today is the tomorrow you worried about yesterday
30Bones is offline   Reply With Quote
Old 01-19-2013, 07:30 AM   #32583
eemsreno
Oddometer: 522
Originally Posted by shep546 View Post
Welcome... bike looks great... any farkles you plan on getting?
At least a skid plate.
Alaska Ride Report,
http://www.yamahasupertenere.com/index.php?topic=1417.0
eemsreno is offline   Reply With Quote
Old 01-19-2013, 07:34 AM   #32584
bash3r
bash3r's Avatar
Oddometer: 1,596
Send a message via ICQ to bash3r Send a message via AIM to bash3r
Artic Ocean to Baja
Yeah.. those WR250Rs can't be any kinda real adventure bike right!... haha!! WRONG! BigDog and Dingweeds continue riding our WR250Rs on more epic adventures.. they head to Baja today. They've ridden from the Artic Ocean to Baja on WR250Rs, that pretty much says it all to the 250 nah-sayers
ANYWHERE!
Like our disclaimer says......
08' Yamaha WR250R
08' Kawasaki Versys
My ADV Website
| ADV Legends
bash3r is offline   Reply With Quote
Old 01-19-2013, 07:51 AM   #32585
jwdub
Oddometer: 355
Thumper Racing 280 kit
Has anyone installed this kit without removing the engine? Not sure if it's possible.
jwdub is offline   Reply With Quote
Old 01-19-2013, 08:10 AM   #32586
DougZ73
Lacks Freetime
DougZ73's Avatar
Oddometer: 4,913
ANYWHERE!
Nice.
DougZ73 is offline   Reply With Quote
Old 01-19-2013, 08:19 AM   #32587
TwilightZone
Oddometer: 1,947
>"ps. Isn't a IRC GP1 a copy of the Kenda 270?"
Yes... just suggesting different tires rather than pulling your bike apart or adjusting suspension.
If you've mounted a 606 on the back of your bike, check it also. I mounted one on my DR350... it created an intermittent vibration like you're feeling. I pulled the back end off the ground, put the bike in gear... the tire wasn't round, even though it was mounted properly on the rim.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga!
TwilightZone is offline   Reply With Quote
Old 01-19-2013, 08:21 AM   #32588
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 350
Trip to Baja
I hope Mark is documenting it
Is he for sure on his WRR or his new Terra 650??
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 01-19-2013, 08:26 AM   #32589
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 350
The 606 was mounted a month ago before the Kenda. The problem only started after mounting just the Kenda a couple weeks ago. I'm pretty sure it is just a defective tire and I'm going out in a few minutes to check for it being out of round. It may settle down after some more break'in.
ps. I just got finished checking it and it appears to run between 1/16th and 3/32nds out of round. As I posed before not enough to get rid of the tire. just break it in more, and use it for light trail/offroad.
pfy50 screwed with this post 01-19-2013 at 08:44 AM
Old 01-19-2013, 09:26 AM   #32590
UtahFox
UtahFox's Avatar
Oddometer: 416
HighFive did it...
http://www.advrider.com/forums/showthread.php?t=621532
UtahFox is offline   Reply With Quote
Old 01-19-2013, 01:46 PM   #32591
jwdub
Oddometer: 355
UtahFox,
Thanks heaps for the link to HighFive's project. I hadn't seen it before and it's excellent~! Just what I was looking for.
John
Old 01-19-2013, 03:50 PM   #32592
jkstehn
Oddometer: 63
On a light bike like the WR I see no reason not to run a 270 if you do street and mild dirt. They are soft and were squirmy on my heavy KLR but somehow wore really well. I think low HP helps a lot, and on a significantly lighter WR I think they would wear very well.[/QUOTE]
I got about 5000 miles from a 270 on the rear of my WR250R. Traction always seem fine in dry dirt and rocks of southern California. Still had at least 3 mm of tread in center when i swapped it out for an MT 43. The trials tire is wearing faster but gives me much more confidence with traction on the streets and freeways of LA and amazing reaction off road with exception of deep sand. K270 just didn't inspire confidence on freeway interchanges at speed for this noob. Felt squirmy and I always felt like I had to slow down to hold the lane.
Sent from my SCH-I605 using Tapatalk 2
Jon
WR 250 R
jkstehn is online now   Reply With Quote
Old 01-19-2013, 06:49 PM   #32593
UtahFox
UtahFox's Avatar
Oddometer: 416
UtahFox,
John
NP J dub dub. Are you planning on doing it, or just kinda seeing how hard it'll be? If you do it, please let us know here how it goes for you :)
Old 01-19-2013, 08:20 PM   #32594
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 350
Just trying combos to see if I can find an inexpensive substitute for the OEM trailwings. I am running the 270 on the front and a 606 rear. Had it out today and it felt a little loose on pea gravel but otherwise ok on hard pack dirt, even wet surface considering it is a defective tire. Not a supermoto tire but it is fresh so it is holding on tarmac OK>
ps. Next up are Shinko 700 series, then following that a Duro 903/4 combo on Markk53's recommendation
pfy50 screwed with this post 01-19-2013 at 08:25 PM
Old 01-19-2013, 08:29 PM   #32595
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 2,542
My WR came to me with Kenda 270. I haven't had it on the trails yet, but it sucks in snow That's all I tell you until the snow melts. Anyway, as soon as it is worn out, I'll be putting Trakmasters on it. I had them on my KLR250 and loved them in mud, sand, gravel, and okay on the street till about 70mph.
henrymartin is offline   Reply With Quote
Times are GMT -7.   It's 05:37 PM.
