Old 01-20-2013, 09:09 AM   #32596
jwdub
Oddometer: 662
UtahFox,
I just bought an unused TR 280 Kit with the liner already installed in a spare cylinder from a fellow in Kansas (from the WR250R forum). I should have it by the end of next week. It may take awhile to get started on the installation though since I'm in AZ for the winter and the bike is in WA. I'll follow up when the time comes.
jwdub is offline   Reply With Quote
Old 01-20-2013, 09:15 AM   #32597
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,838
Originally Posted by eemsreno View Post
Finally got a chance to put some miles on it yesterday. Quite happy with everything so far. I find that you really got to ride it hard to go fast but it is plenty fast when ridden hard. It handles very quick especially in first gear, It will just dart all over where ever you point it. I do really like it and it is fun, I probably won’t get to ride it as much as I should because I also have a BIG XT, the 1200, And that bike is just addictive to ride. The best bike I have ever ridden! Steve
I love my WRR, I only sorta like my Tenere. Maybe not even that much.
The WRR is a ruthlessly efficient, yet fun bike that does it all.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 01-20-2013, 12:44 PM   #32598
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,654
Something good about simplicity...
I'm looking at selling off the street bike to finish the supermoto rims to have a set of roll in SM wheels with street tires for that use while still having the dual sport shod wheel set.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 01-20-2013, 01:20 PM   #32599
krussell
krussell's Avatar
Oddometer: 561
I'm very likely headed down the same path. I really enjoy the WRR, SM wheels and street rubber would be a hoot.
Kevin
krussell is online now   Reply With Quote
Old 01-20-2013, 02:36 PM   #32600
Mr.Black999
Mr.Black999's Avatar
Oddometer: 242
Looking for springs
Hi everyone. It feels like I have been looking for the answer to this for awhile but does anyone know what other bikes have the same fork and shock springs for the WR250X? I'm trying to find something from Eibach or another brand that I can find locally. Thanks a lot everyone.
Mr.Black999 is offline   Reply With Quote
Old 01-20-2013, 04:30 PM   #32601
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,566
It was actually above freezing this weekend (not for long though), so I made my way to the garage and started working on the WR250R.
The bike came to me pretty much stock, so there was a "need" to get some goodies (or, as I explained to my better half: "Honey, I do need that skidplate, you wouldn't want me to break the engine case and get stuck in the woods, would you?" )
A big thumbs up to SoloRacer for fair prices and speedy delivery. Also to Revzilla for the same.
I used SoloRacer for Flatland Racing skidplate and radiator guard, a license plate bracket, new tailight, and turn signals.
Revzilla got some business form me for a Wolfman Enduro bag (cheaper than Wolfman direct AND free shipping).
I started with the taillight and turn signals. That's where I had my 'idiot' moment. I took the parts to the living room, crimped and soldered all my connections, and then I found out that the mounting nuts won't slip over the connectors. Yeah, wasted time. But, with some pushing, pulling, and cussing, I was able to get the connectors apart again, and fixed the issue.
The next issue I had was with the license plate bracket. It was bent (at the factory, I assume), a little too much, and there was no way I could mount the license plate on it.
A couple of decent whacks with a hammer and a wooden block got it where it needed to be.
The front turn signals were easy
Next I tackled the radiator guard. It is a solid little piece, well made, but it could have been engineered a little better. I'm not sure that I'll keep it. It is rugged, yet I feel it doesn't offer enough protection from behind and down at the bottom of the radiator. Also, I wish it would be a true wrap-around design. The way it mounts, it leaves a little bit of the radiator closest to frame exposed. At that location, I'm not worried about rocks, but a small branch could easily get to the core if it came at the right angle.
Mounting this was easy, except at the end when I struggled to attach the side plastics back. There just isn't enough room. I managed to reuse stock bolts, but I had to push my allen wrench through the slots in the guard to tighten them.
The skidplate was the easiest to mount. It is very rugged, well engineered with ample protection, and the bends and welds are of great quality. Easy mounting with four provided bolts. I used a thick piece of rubber at four points were the skidplate ended up touching the frame - both to prevent vibration and protect the frame.
Finally, I attached my homemade rear rack.
The Enduro tankbag is a good fit, and suits the bike rather well. It doesn't interfere with my riding position at all.
Now I just have to wait for the snow to melt so I can hit some trails. The last thing on the list (for now) is a front sprocket cover and a case saver, but I didn't order those yet.
I love the way the tailsection cleaned up with the aftermarket lights and bracket.
henrymartin is offline   Reply With Quote
Old 01-20-2013, 06:34 PM   #32602
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,294
Double check the bottom bolts on that skid plate. Some are a little long, and come VERY close to the engine case. A good hit might bend and or push the bolt into the case.
WARNING: Most things posted above contain sarcasm.
Daamud is online now   Reply With Quote
Old 01-20-2013, 07:59 PM   #32603
japako
japako's Avatar
Oddometer: 592
Nice job on the bike. I really like the rack.
@daamud, thanks for the time on the bash plate..
japako is offline   Reply With Quote
Old 01-20-2013, 08:32 PM   #32604
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
Originally Posted by riverman View Post
First High Five, now Crawdaddy, and BigDog still has the WR but has purchased another bike as well !! Hmmmmm!
Enjoy boys, its all good! Thanks for all your contributions to this site and for answering many PM's from ADV'ers regarding the WR.
350XCF-W is now trail tested/broken in: http://advrider.com/forums/showpost....&postcount=172
As stated before, and in the link above, the WR would STILL be my first choice if my personal mission statement was "ADV Traveler".....
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 01-20-2013, 08:45 PM   #32605
henrymartin
Mr. Tourguide
Oddometer: 3,566
Thanks, will do. The plate came with allen head bolt, which I do not care for in impact areas. One nick and I'll never get the wrench in there, so I'll be switching to some stainless hex or torx.
Thanks. I wanted to have something that wasn't too big, yet large enough to strap a duffel bag on. If anyone wants to, I can trace the rack and send you a template.
I'm still thinking about cutting a few holes in it, but I'm waiting to see if I'll end up with a Rotopax first. If I do, the holes will be done after attaching the mount.
Old 01-21-2013, 12:47 AM   #32606
mototifosi
what does this one do?
mototifosi's Avatar
Oddometer: 488
Indeed it is!
I have been very fortunate in my riding endeavors to have been able to cycle (pun intended) 25+ horses through the stable at one time or another. Started doing Moto X and desert events. Moved to street and many track days with sport bikes (Duc's, CBR's, Nortons) then big Dualies' (GS's, Tigers, LC4's, 530) etc... This damn WR-X is the most friggen fun out of all of them. In "retard" trim it does twisties, gravel and dirt roads, moto x tracks, hard pack, etc... as long as the dirt isn't to deep (tires plow) it will do it, and do it well. Get the suspenders set up correctly, do the smog surgery, gear it, maxxis rain tires = grins.
Going to mount the Warp 9's this week and try Hollister. Actually for 80% of HH the retard set up would work just fine...
This bike is a hoot, but you guys knew that...
mototifosi is offline   Reply With Quote
Old 01-21-2013, 07:50 AM   #32607
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,732
Enjoy boys, its all good! Thanks for all your congtributions to this site and for answering many PM's from ADV'ers regarding the WR.
As life changes so does bike needs for some folks... so it's all good. Neither High Five nor Crawdaddy switched bikes because the WR had issues(well we know Crawdaddy's story heheh )... just different bike for how they wanna ride these days. BigDog's retired so thats a different story.. lol
I lust daily over different bikes.. not gonna sell my WR... but that Tenere XT660Z needs to come to the states!! If that thing comes over the Versys is gone and Tenere in ....
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 01-21-2013, 10:38 AM   #32608
jon_l
jon_l's Avatar
Oddometer: 3,142
I have the Sandman Freedom case-saver & guard in wrinkle black powder coat finish, and like them a lot.
Nice job with the rear rack, I like the size. My GYTR is too small.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 01-21-2013, 10:42 AM   #32609
jon_l
jon_l's Avatar
Oddometer: 3,142
Does anybody make case savers like this one for the DR650SE from Procycle for the WR250R/X?
CBF1000 & PCX150
Old 01-21-2013, 11:11 AM   #32610
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,574
steering dampner
The term "GPR" isn't handled well when searching for steering dampner info.
The MSRP price of the Scott's and GPR are the same (hmm. nothing fishy there) but was wondering if this group of owners had come to any sort of a preference on one over the other for this particular motorcycle. And if anyone knows of a vendor offering good deals on either one that would be appreciated. Thanks
swimmer is online now   Reply With Quote
Times are GMT -7.   It's 09:50 PM.
