01-24-2013, 06:57 PM
#32686 |
Wannabe Far-Rider
I run my heated grips off the headlamp circuit, but run my heated gear plug off its own circuit off the battery. I don't think there's enough spare amps in the headlamp circuit for a heated jacket's power draw, and wouldn't want to risk the headlight blowing in the middle of a ride to find out.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
01-24-2013, 07:30 PM
#32687 |
Oddometer: 52
Thanks for the replies on the seat height. I think I'll be happy with it, now I just need to wait on a sweeeet deal.
01-24-2013, 07:47 PM
#32688 | |
Professional nOOb
Oddometer: 350
Your headlight is fused for 15 amps. Your jacket and gloves nominally use 7-10amps depending on brand and if used together. Your headlight uses 4.4 to 4.8amps which would put it very close to circuit overload. It is best that heated clothing has its own circuit; fused with or without a switch, depending on whether you do/don't have a rheostat to control heat.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875 2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours May the Lord bless you and keep you in all the Dark places you must travel
01-24-2013, 08:29 PM
#32689 |
Oddometer: 10
thanks for the responses i just wired it direct to the battery with an inline fuse 15A,seems to work fine.
cheers, jon |
01-25-2013, 05:15 AM
#32690 |
Oddometer: 54
Thank you all for the tire advice.... Ya I forgot that tire selection could be as bad a an oil thread. I think I'll put on the Kenda 760 and see if I like them plus I got them here just sitting in the garage.
01-25-2013, 09:08 AM
#32691 |
Oddometer: 9
hello all,,,new on the forum just picked up this WR 250R and have yet to ride it athough it now has 1500 miles on it,,(in the back of my p/u from idaho to west texas) good reviews on it, so i look for to some good rides ,,now,,are there fender bags available for it ???
01-25-2013, 09:23 AM
#32692 | |
Curmudgeonly
Oddometer: 8,815
I use a Moose bag up front, about $25; and a Chase Harper 8800 bag in the back, about $40. Wolfman, DirtBikeGear, quite a few others make similar products. Front: ![]() Back (kind of smushed down in this pic):
Go forth, wander aimlessly, explore, have adventures and shit... |
#32693 |
Oddometer: 1,096
I do that also. Pluse since it's direct, I can also use that plug for a battery tender if the bike ever sits, or to run a small compressor to air up tires, heck I even use it to charge my cellphone/ipod etc. for a couple of hours when I touring on the little bike. It's nice to have an unfused connection to battery.
2011 WR250R 2009 KLR650 2004 KTM 450 EXC 2000 R1150GS "The older I get, the faster I was" |
01-25-2013, 09:31 AM
#32694 | |
Curmudgeonly
Oddometer: 8,815
You should always fuse those connections, especially the ones that are right to battery.
01-25-2013, 09:33 AM
#32695 | |
Lacks Freetime
Oddometer: 4,924
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
01-25-2013, 10:31 AM
#32696 | |
Oddometer: 423
Thanks. |
01-25-2013, 10:51 AM
#32697 |
Cert. bike whore
Oddometer: 889
Just get one of these. http://www.fuzeblocks.com/. Tap into your plate light wire, good ground and power from the battery and wire accessories as required.
2009 WR250R "Da Mini Bike" "That's our colour: mud!"
01-25-2013, 10:52 AM
#32698 | |
bikes, booze, broads...
Oddometer: 8,303
You really only need to wire a + wire to the + on the battery and a - wire to the - on the battery, then one more to a switched wire (one that is hot when the key is turned on like the tailight). After that it's a piece o cake. http://www.fuzeblocks.com/index.php?pid=2
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
01-25-2013, 10:53 AM
#32699 |
Oddometer: 8,303
Fuzeblockism
...Ha!...I guess that's 2 votes!
#32700 | |
Oddometer: 212
http://www.easternbeaver.com/Main/Wi...3_circuit.html I've used it on the WR and a DR650, makes wiring super easy
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin |
