Old 01-30-2013, 07:49 PM   #32836
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by what broke now View Post
Are you running the stock muffler or something else?
I would like to know too...........
I've been having some trouble with "top end" power. A clean air filter doesn't change anything. The bike doesn't want to pull 65, 70 mph in 6 th like it used to................................
KansasBob is offline   Reply With Quote
Old 01-30-2013, 08:16 PM   #32837
easy_dualsport
Easy E
easy_dualsport's Avatar
Oddometer: 389
Originally Posted by UtahFox View Post
Awesome, those are really nice.
Worth the investment in my experience.
--Easy
Raleigh, NC
ZR-7 2000
WR250R 2010
easy_dualsport is offline   Reply With Quote
Old 01-30-2013, 09:18 PM   #32838
DefyInertia
Saratogian
DefyInertia's Avatar
Oddometer: 153
Originally Posted by jon_l View Post
One reason to stick with 21/18 is that they will use the same brake caliper location and disc size. Also, I would think you would need to adjust the suspension to go 21 > 17 in the front, and 18 > 17 in the rear. Ditto the chain length. No big deal maybe, but messing with brakes and forks with every wheel swap would be a turn-off for me.
Just buy another set of 21/18 wheels, and mount some Trailwings or Shinko 700s on one set, and run DOT knobbies on the other.
Huh?
You can use whatever rotor on the front and whatever sprocket you want on the rear regardless of wheel size. Wheel size itself does not have a direct impact on caliper location or chain length.
I have a set of 17s for my WRR that swap out in 10 mins. 17s with sticky rubber dot compare to a 21/18 set up with ok street rubber.
My bike is set up for dirt but I can run a good pace at the motard track without adjusting the suspension, but I'm light.
There's a feeling I get when I look to the West...
DefyInertia is offline   Reply With Quote
Old 01-30-2013, 09:47 PM   #32839
UtahFox
UtahFox's Avatar
Oddometer: 446
I wonder if they'll work with Easton fat bars?
UtahFox is offline   Reply With Quote
Old 01-31-2013, 03:45 AM   #32840
ba_
ba_'s Avatar
Oddometer: 2,774
rear brake lever bolt
Is there a proper torque for the bolt that goes through the rear brake lever? Or do you just make it tight enough and then slide the clip through the back end?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 01-31-2013, 04:10 AM   #32841
easy_dualsport
Easy E
Oddometer: 389
Paul, the owner at HDB would be able to tell you. He could also probably change the clamp to fit if you wanted. Go to his site, and contact him for a direct answer.
--Easy
Raleigh, NC
ZR-7 2000
WR250R 2010
Old 01-31-2013, 05:52 AM   #32842
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
Fat bars are a common width.......shouldn't be an issue.......I just threw a set on my KTM along with a dash mount to move the instrument cluster up top, Powerlet, pushbutton for heated grips....
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 01-31-2013, 07:37 AM   #32843
UtahFox
UtahFox's Avatar
Oddometer: 446
Cool, I will put that in the vault until the time comes.
That setup is tight, and looks exactly like what I would want.
I've got the bars, now I just need to get my bike sold, find and retrieve a Wrr, then I'll be all over it. With luck *knocks on wood* this will be happening within the next 2 weeks.
Old 01-31-2013, 07:46 AM   #32844
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,125
Just snug against nut. Should give plenty of room to get on the washer and clip through there. Clip will keep nut from coming off if it loosens up. Also, it is a pivot point, so remember to lubricate( I like waterproof bearing grease) the shoulder of the bolt( non threaded) section, where the lever pivots on.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 01-31-2013, 07:52 AM   #32845
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,530
...HDB guards work with any fatbar. He sends you threaded inserts including a tap to thread it in. I've been down with mine more than I like to admit and they are killer strong.
And the mirrors work great.
I like crashin' thru thangs...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 01-31-2013, 07:55 AM   #32846
ggemelos
ggemelos's Avatar
Oddometer: 154
Why aftermarket bars?
I noticed a lot of people in this thread have replaced the stock bars with aftermarket bars. What is the main reason for doing so, is it ergonomics or are aftermarket bars less prone to damage during a crash? Given that most aftermarket bars are aluminum and the stock are steel, I would have thought the stock would be stronger. Thanks for the feedback.
Preparation for RTW trip and future site of ride blog -> www.onthewanderlist.com
ggemelos is offline   Reply With Quote
Old 01-31-2013, 08:01 AM   #32847
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,731
Most aluminum fat bars are stronger than the cheap steel 7/8" OEM bars. Also, lighter.
And in most cases, the fat bars will not have the silly cross bar that seems to just be in the way when you want to add things like RAM mounts, or hand guards.
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 01-31-2013, 08:16 AM   #32848
UtahFox
UtahFox's Avatar
Oddometer: 446
In a word? MacGyver.
Old 01-31-2013, 08:28 AM   #32849
ba_
ba_'s Avatar
Oddometer: 2,774
+1 on the grease. I was going to use waterproof grease
I was referring to bolt 2 in this diagram:
I'm not sure what nut you are referring to
Old 01-31-2013, 08:59 AM   #32850
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,959
More bend resistant in a crash or a drop.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Times are GMT -7.   It's 06:59 AM.
