Old 02-06-2013, 12:04 PM   #32971
30Bones
30Bones's Avatar
Oddometer: 4,703
Yowza! $405 fuel pump on bike bandit!
30Bones is offline   Reply With Quote
Old 02-06-2013, 12:22 PM   #32972
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,304
That's what I paid for mine at a dealer in AZ.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 02-06-2013, 12:34 PM   #32973
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,906
Ron Ayers has it listed for $223.61. That kind of difference makes me wonder if it's correct, but I've never had any issues getting parts from there.
cjbiker is offline   Reply With Quote
Old 02-06-2013, 01:30 PM   #32974
Krabill
Krabill's Avatar
Oddometer: 4,895
I bought mine from Service Honda for about the same $220. Fit perfect and still runs like a champ.
Write-up here - http://www.wrrdualsport.com/tech-gui...8-fuel-pump-rr
Loud Sucks!
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 02-06-2013, 01:38 PM   #32975
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,906
Since mine is a 2008 with about 4k miles on it, I'm debating buying a spare fuel pump to keep on the shelf. The PO didn't replace the pump, but I don't think he was the first owner. Any way to tell if it's been replaced?
Old 02-06-2013, 02:17 PM   #32976
TwilightZone
Oddometer: 3,184
Valve Clearances WR250R - 13,000 miles.
Sounded like a valve ticking... so I tore mine apart.
Here's what I found. (had to use inch feeler gages)
Intake Left (spec is .13 mm-.20 mm)
.005 yes. .127 mm
.006 no. .152 mm
Intake Right
.005 yes .127 mm
.006 no .152 mm
Both Intakes are near the min spec.
Exhaust Left (spec is .23mm-.30 mm)
.007 yes .178 mm
.008 no .203 mm
Exhaust Right
.008 yes .203 mm
.009 no .228 mm
Exhausts… Yup, too bloody tight. So I've ordered a hot cams kit
and a metric feeler gage. Hopefully valve clearances will fix the problem.
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 02-06-2013, 02:25 PM   #32977
bogboy
bogboy's Avatar
Oddometer: 58
Originally Posted by MeefZah View Post
I agree, I simply bolted 4 metal rubber clad wire looms onto the subframe under the fender and use ROK straps to hold down a duffel. Works great, very minimal and inexpensive, and doesn't interfere with off road riding when not securing a duffel.
I use my WR a lot on tight trails and stuff. I am trying to keep it as lite as possible so I haven't mounted a rear rack. I am doing a week long trip this summer and was wondering about how to mount a duffel . I like your idea, any pics by chance?
bogboy is offline   Reply With Quote
Old 02-06-2013, 02:34 PM   #32978
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,390
Hey TZ. How many miles?
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 02-06-2013, 03:02 PM   #32979
TwilightZone
Oddometer: 3,184
>"Hey TZ. How many miles? "
13,000 miles. Just started ticking.
Old 02-06-2013, 03:37 PM   #32980
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,742
.005 yes. .127 mm
.006 no. .152 mm
Intake Right
.005 yes .127 mm
.006 no .152 mm
.007 yes .178 mm
.008 no .203 mm
Exhaust Right
.008 yes .203 mm
.009 no .228 mm
So much for the 24,000 mile valve check. I'd ask if you've been riding the bike hard, but then, there really isn't another way is there?
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 02-06-2013, 03:43 PM   #32981
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 589
TZ,
Save yourself some money and go down to your local service dept. and pickup some loose shims from the mechanics then shave them down on an india stone(knife sharpening; fine grade)so that your valves will set at max setting assuming they still have more breakin to go before settling.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-06-2013, 07:44 PM   #32982
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
My WR250R and myself being rescued by a FJR with a trailer
So, my WRR battery decided to croak tonight when I was leaving bike night. Had no warnings it was even going, but guess it had had enough. Tore into it in the parking lot thinking it was a fuse, but realized it was a very dead battery that would eventually bring up the fuel pump if you let it sit long enough. Amazingly, we were able to bump start it and I thought I was set as it was running great. But, after letting it idle a few minutes while I put it back together it started sputtering. I tried riding it around the parking lot, but anything over 1/8 - 1/4 throttle was bogging down so I knew there was no way I was riding home like that. There just wasn't enough juice to keep the fuel pump primed I guess?
So, Garry to the rescue who just happened to have his homemade hitch & bike trailer he built for his FJR with him tonight and carrying an old Honda 2T on it. We unloaded the Honda and loaded up the WRR and Garry took me the couple miles home 2up. Of course the guys couldn't wait to snap some pics!
Amazingly, this setup worked pretty well! Garry said it even handled better with me on the back.
Here's his Honda loaded back up.
The FJR Hitch setup
Yep, he's a darksider too.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 02-06-2013, 09:35 PM   #32983
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,742
Bummer you had to two the WR home...but...that is AWESOME!
Old 02-07-2013, 04:18 AM   #32984
rsteiger
Bob
rsteiger's Avatar
Oddometer: 235
I have to admit that at first glance Gary's setup looks to be a bit redneck, but it actually works quite well. I rode behind the two of you on my Strom for a bit and I noticed that he even has all the electrical hooked up to the trailer (stop light and turn signals). Very nice setup.
2012 WR250R
2010 Beta 520 RR
2009 DL650
2001 GasGas XC250
rsteiger is offline   Reply With Quote
Old 02-07-2013, 06:13 AM   #32985
30Bones
30Bones's Avatar
Oddometer: 4,703
Nut to butt
Times are GMT -7.   It's 12:18 AM.
