02-06-2013, 07:44 PM
#32986 |
Riding is my passion
My WR250R and myself being rescued by a FJR with a trailer
So, my WRR battery decided to croak tonight when I was leaving bike night. Had no warnings it was even going, but guess it had had enough. Tore into it in the parking lot thinking it was a fuse, but realized it was a very dead battery that would eventually bring up the fuel pump if you let it sit long enough. Amazingly, we were able to bump start it and I thought I was set as it was running great. But, after letting it idle a few minutes while I put it back together it started sputtering. I tried riding it around the parking lot, but anything over 1/8 - 1/4 throttle was bogging down so I knew there was no way I was riding home like that. There just wasn't enough juice to keep the fuel pump primed I guess?
So, Garry to the rescue who just happened to have his homemade hitch & bike trailer he built for his FJR with him tonight and carrying an old Honda 2T on it. We unloaded the Honda and loaded up the WRR and Garry took me the couple miles home 2up. Of course the guys couldn't wait to snap some pics! ![]() Amazingly, this setup worked pretty well! Garry said it even handled better with me on the back. ![]() ![]() Here's his Honda loaded back up. ![]() The FJR Hitch setup ![]() Yep, he's a darksider too.
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
02-06-2013, 09:35 PM
#32987 |
Oddometer: 1,082
Bummer you had to two the WR home...but...that is AWESOME!
2011 WR250R 2009 KLR650 2004 KTM 450 EXC 2000 R1150GS "The older I get, the faster I was" |
02-07-2013, 04:18 AM
#32988 |
Bob
Oddometer: 45
I have to admit that at first glance Gary's setup looks to be a bit redneck, but it actually works quite well. I rode behind the two of you on my Strom for a bit and I noticed that he even has all the electrical hooked up to the trailer (stop light and turn signals). Very nice setup.
2012 WR250R 2010 Beta 520 RR 2009 DL650 2003 KTM 450 EXC 2001 GasGas XC250 |
02-07-2013, 06:13 AM
#32989 |
Oddometer: 4,561
Nut to butt
Today is the tomorrow you worried about yesterday |
02-07-2013, 06:30 AM
#32990 |
Oddometer: 115
Aftermarket bars
I am looking at picking up a set of Pro Taper Contour bars. I am happy with the stock ride position and was wondering which bars are closest to the stock geometry.
www.tailevent.com |
02-07-2013, 06:33 AM
#32991 |
Oddometer: 4,561
Why change bars if the stock ones feel fine?
02-07-2013, 06:37 AM
#32992 |
Oddometer: 115
Get rid of the cross bar and more resistant to bending in a crash. I also am thinking of a Scotts stabilizer and do not believe it would fit with the stock top clamp and bar setup.
www.tailevent.com |
02-07-2013, 07:59 AM
#32993 |
armchair asshole
Oddometer: 2,565
02-07-2013, 08:31 AM
#32994 |
Oddometer: 2,355
02-07-2013, 09:11 AM
#32995 | |
Oddometer: 113
If you decide to mount a stabilizer with an under the clamp mount you could go with a Pastrana MX/RM LOW bend to keep the bars from getting too high. Pro Taper gives you dimensions of the bars here |
02-07-2013, 10:59 AM
#32996 |
Oddometer: 421
Anyone know of a tail rack that is compatible with a Rotopax mount? One that no drilling would be needed.
02-07-2013, 11:02 AM
#32997 | |
Oddometer: 115
Thanks for the feedback. It make sense to pick somewhat lower bars to offset the risers needed for the stabilize.
www.tailevent.com |
02-07-2013, 11:40 AM
#32998 | |
Oddometer: 212
http://wr250rforum.forumotion.com/t6...rack-available
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin |
02-07-2013, 11:42 AM
#32999 |
Oddometer: 54
What size of socket/ allen wrench do I need to remove the front axle? 17 mm is to big 14mm looks too small Is it a 15mm, if so where do I find one... Or do I even need on to remove the axle?
02-07-2013, 11:54 AM
#33000 |
FunHog
Oddometer: 3,455
Deadblow hammer or rubber mallet... remove axle nut (27mm), loosen the four pinch bolts around axle, tap with hammer to remove. If it's gritty or stuck you may have to use a drift (I use a 3/8" extension) to tap it once the nut end of the axle is inside the left fork. The end with the hex is not threaded, but larger than the part of the axle that goes through the wheel, so once you drive it 2" or so (width of the fork leg) it's easily removed.
My book's website (Now Available) 2003 BMW F650 Dakar (Back from the Brink) 2003 Victory V92C + Velorex sidecar chassis + Harley sidecar body (Canine Chariot) ![]() 2010 WR250R (Twiggy)
