Old 02-07-2013, 03:50 PM   #33001
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,831
I hadn't touched or started my lil quarter pounder since August when I screwed up my quadriceps tendon. Had to air up both tires, turned on the key.... and it fired right up Took a little put around the yard and the culdesac. Felt good.
Mr. Fisherman is offline   Reply With Quote
Old 02-07-2013, 04:17 PM   #33002
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,597
Congrats on getting back on two wheels!
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 02-07-2013, 04:31 PM   #33003
SuperD!
SuperD!'s Avatar
Oddometer: 261
Originally Posted by oldtrucks View Post
There is a guy that sells a nice billet one on WR Forum, comes in two sizes and works with the RotoPax
http://wr250rforum.forumotion.com/t6...rack-available
I've got one of these and I couldn't recommend it more!
SuperD! is offline   Reply With Quote
Old 02-07-2013, 04:33 PM   #33004
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 587
Originally Posted by huron52 View Post
huron52,
Front axle nut is 22mm the rear is 27mm. The axle hex opening is 14mm about $8.02 :http://www.mcmaster.com/#standard-hex-l-keys/=ldpx8x #6958A2.
I only use it at home for axle holding convenience. Not in the field.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-07-2013, 04:37 PM   #33005
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 587
Originally Posted by UtahFox View Post
Well, I'm all set. Driving down to Palm Springs tomorrow and scheduled to pick up a new (to me) 2011 Wrr. Going to drive it back to Salt Lake via the back roads in Nevada in an attempt to stay as low and dry as possible back up here. Pics to follow :)
There is also this:
Mounted looks like this:
They're at Automotive Machine Shop: http://www.automotivemachine.com/ind...d=51&Itemid=56
Congratulations on the New 2011 WRR
pfy50 screwed with this post 02-07-2013 at 04:43 PM
Old 02-08-2013, 06:00 AM   #33006
30Bones
30Bones's Avatar
Oddometer: 4,651
Originally Posted by pfy50 View Post
huron52,
You might be able to get away with flipping a spark plug socket around and using the hex end if it fits in the opening. Did this with a Triumph once.
30Bones is online now   Reply With Quote
Old 02-08-2013, 06:08 AM   #33007
Krabill
Krabill's Avatar
Oddometer: 4,893
All this talk about hex keys and backwards sockets . . . just loosen the axle nut before you loosen the pinch bolts, and vice-versa when you tighten it up. I never realized it was that complicated
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 02-08-2013, 06:12 AM   #33008
sturgeon
sturgeon's Avatar
Oddometer: 946
It's sometimes useful to be able to turn the axle to get it out. I use the back end of a spark plug socket to do that.
Dyslexics Untie!
sturgeon is online now   Reply With Quote
Old 02-08-2013, 07:14 AM   #33009
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,263
Exactly. And if one needs to get the axle out..leave axle nut on a couple threads..and tap with rubber mallet..enough to grab, un-weight wheel, and pull out by hand. .
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 02-08-2013, 07:47 AM   #33010
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,216
I set the fork location on the T clamp using the axle as a guide. Basically, I slip the axle through, loosen the opposite clamp and wiggle the fork enough to slide the axle home easily. I can poke the axle out with my finger if the forks are matched in their T clamps.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 02-08-2013, 02:36 PM   #33011
sodapop
Caffeinated
sodapop's Avatar
Oddometer: 105
I have this one and it's awesome. Really well made.
Sent from my Nexus 7 using Tapatalk HD
Robb
2008 Yamaha WR250R
Gone: 2007 Honda VFR800A, 2006 Suzuki SV650S, 2002 KTM 125SX, 1994 Yamaha YZF750R, 1992 Honda CBR600R, 1991 Suzuki GSXR750R, 1989 Yamaha FZR600R, 1983 Honda CR80R, 1982 Honda XR80R, 1979 Yamaha GT80
sodapop is offline   Reply With Quote
Old 02-08-2013, 02:41 PM   #33012
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 178
I tighten the axle nut first, then tighten the pinch bolts near the axle nut.
Tightening the axle nut first fully pulls the axle to the left, putting tension on the parts the wheel alxe slides through, from the head of the axle to the left side wheel spacer.
After moving the fork up and down a few times, I tighten the right side pinch bolts.
YZEtc is offline   Reply With Quote
Old 02-08-2013, 04:33 PM   #33013
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,993
Originally Posted by ggemelos View Post
I am looking at picking up a set of Pro Taper Contour bars. I am happy with the stock ride position and was wondering which bars are closest to the stock geometry.
Henry Reed.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 02-08-2013, 07:48 PM   #33014
TrailDust&SaddleLthr
TrailDust&SaddleLthr's Avatar
Oddometer: 194
NICEST Rack!!
I have the larger size of this one and it is awesome.... Quality is FIRST class and Jared, the designer and maker of this rack, is an awesome guy too!
I waited a long time to get a rack but sure glad I did... IMHO, this is THE finest made for our bike.
My 2 centavos.
TrailDust&SaddleLthr is offline   Reply With Quote
Old 02-08-2013, 08:11 PM   #33015
Oddometer: 194
Fuel Pump... NO YAMAHA Warranty I was told...
[QUOTE=what broke now;20663968]I have no idea about Yamaha's warranty policy,...
A few months ago I thought my fuel pump had gone out so I had my dealer investigate a possible free replacement by Yamaha should I have needed one.... Good thing there was nothing wrong with my fuel pump afterall and I did not need to replace it... but, for what it's worth, according to my dealer, whom I trust (rare for me to trust anyone!), Yamaha did not show having any recall or anything of the sort on those fuel pumps, so, had I needed a new one, I would have had to pay for it!
From what I have read, it seems that the most common denominator of fuel pump failure was caused by extreme heat (bike sitting in the sun for hours, even with engine off) and low fuel in the tank. So, for better or for worse, this is what I will believe for myself and I won't worry about it until my pump craps out on me... till then, I will just ride and trust the bike!
Some inmates on here also posted failure on replacement pumps as well.
I also read on here that a few members got theirs replaced for free by Yamaha at one point... they were lucky devils! Don't expect it!
As far as cost, several inmates here mentioned the best place to get a new one was from Service Honda and those pumps cost about $215.00 or so a few months back. It seems that they were on backorder for a long time from Yamaha though... don't know if it is still the case.
Thought I'd share my personal experience and what I heard on the subject.
Nothing more.
Cheers!
Times are GMT -7.   It's 05:48 AM.
