Old 02-13-2013, 07:30 AM   #33121
rdouthit
Oddometer: 30
Originally Posted by BlueLghtning View Post
Instead of the Kenda 270's look at the Shinko 244's. Almost exact copies in the middle tread, but much more substantial side lugs which makes them much more sure footed on the pavement. The middle lugs on the 244's are actually "bigger" too which again helps with stability on the road. They are also cheaper than the 270's usually. Sometimes the Shinko 244's are labeled as "Golden Boy" tires too.
I've ran the Kenda 270's before and I used to like them, but they are either a love or hate relationship. The biggest problem with them is that their side knobs are soft and flex when you get over on them on pavement, so this can make the tires seem squimry. It's definitely worse on larger bikes.
Since I have found the 244', I won't run the Kenda's again. They are almost direct copies of the Kenda 270's and are cheaper to buy, but they redesigned the side knobs to be more substantial and they don't flex like the 270's do. A win/win!! Their beefier knobs gives them a more sure footed feel when you get over on the side knobs in the twisties.
Here's a direct comparison of both tires. That is a Shinko 244 on the left and Kenda 270 on the right. You can see the larger side knobs which I cannot bend with my finger where I can on the Kenda's. You can also see the knobs just in a bit from the sides are also a bit larger on the Shinko's and go all the way to the edge every 2 knobs which gives you more stability there too.
A well worn Kenda 270 on the right and a new Shinko 244 replacement on the left
A close up of the side knobs. See those little bitty side knobs. That is what makes the kenda 270's so squirmy. They give & flex so easily.
What size 244 are you running on the rear? 4.60 or 5.10?
rdouthit screwed with this post 02-13-2013 at 03:34 PM Reason: Brain Fart
rdouthit is offline   Reply With Quote
Old 02-13-2013, 07:53 AM   #33122
UtahFox
UtahFox's Avatar
Oddometer: 446
Sag
Since I'm out of town, I don't have the ability to get both wheels off the ground. Should I find a Yamaha dealer around here and get their help before I head off home?
UtahFox is offline   Reply With Quote
Old 02-13-2013, 07:56 AM   #33123
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,264
In the picture, that was an older XT600, but I have a set of 244's waiting to go on my WRR. I went with the 4.60 x 18 rear for my WRR. I saw no reason to go with the 5.10 rear on a 250. I'm actually running the 4.10 x 18 rear on my wife's XT225. We'll see how the 4.60 does on the WRR.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 02-13-2013, 08:00 AM   #33124
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,743
I wouldn't. Just gas it up and go. Do the basic stuff first--there should be enough tools in the oem tool kit to check the air filter, check the oil level, pull the front sprocket cover and check that the chain slider is still protecting the swingarm, check the chain slack. Check the tire pressures. Make sure all the lights are working. Once you're satisfied, hit the road. Assume they're out to get you, and ride smart!
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 02-13-2013, 08:17 AM   #33125
AZ TOM
Oddometer: 4,036
Mess with it when you get home. Doing all pavement your Seat Concepts seat should give you enough comfort for the ride
AZ TOM is offline   Reply With Quote
Old 02-13-2013, 03:36 PM   #33126
rdouthit
Oddometer: 30
Thank you.
I am running a 4.60 on the rear, also. I was wondering if going to a 5.10 would gain me any traction with the larger footprint or if I would just gain the weight.
Old 02-13-2013, 06:26 PM   #33127
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,781
Thank you.
I am digging the 5.10 on the 17 wheel rear... Will do it again.
Mr. Fisherman is offline   Reply With Quote
Old 02-13-2013, 08:12 PM   #33128
iWander
Adventure Geek
iWander's Avatar
Oddometer: 61
Originally Posted by KansasBob View Post
I did some quick math.......... 40K miles at an average overall speed of 40 mph, with and average rpm of 8k........... works out to around a half a BILLION cycles of the piston. Amazing really. If you count each pass up and down the rings have followed the length of the bore a full Billion times.
Looking at it another way............. The stroke x 2 = .35170604 feet, so it only takes about 15012.5 revolutions of the crank for the piston to travel a mile in the bore......... so in 40,000 miles, on the bike, the piston travels approximately 33,300 miles down the bore.
Huh, I guess math really can be interesting. Makes me wish I had stayed awake more in class...
iWander is offline   Reply With Quote
Old 02-13-2013, 09:12 PM   #33129
BlueLghtning
Oddometer: 5,264
Thank you.
I could see the 5.10 on the 17" wheel because I think its actually a wider rim than the 18" rim? On the 18" rim, I think it will just be pinched not sure it will really gain you anything except extra weight and a higher cost.
Old 02-14-2013, 08:48 AM   #33130
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 88
I have the 5.1 on the 17". Fits good, looks killer, just wish I could ride I now...
Only God decides the LENGH of your life, but you decide its WIDTH.
ADWrider is offline   Reply With Quote
Old 02-14-2013, 05:53 PM   #33131
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Originally Posted by 30Bones View Post
Didn't see it out there, PM me more details, location, price. Thanks
Just pm'd you
leftystrat62 is offline   Reply With Quote
Old 02-15-2013, 05:04 PM   #33132
UtahFox
UtahFox's Avatar
Oddometer: 446
Ready to Ride
Got my new Seat Concept seat, and have installed some USB power too. The tank bag is new, the duffel is packed and mounted with one and a half gallons of gas, as I plan on trying to get home with no slab. Not sure why I'm leaving though, was 82 here today and 35 where I'm going.
Old 02-15-2013, 06:10 PM   #33133
AZ TOM
Oddometer: 4,036
Very exciting. Keep us posted & hollar if you have any problems. Lots of luck
Old 02-15-2013, 06:19 PM   #33134
Bluraywr
Oddometer: 13
Pirelli XCMH
Does anyone know if a Pirelli XCMH 140/80M-18 will fit the WRR?
Bluraywr is offline   Reply With Quote
Old 02-15-2013, 08:17 PM   #33135
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,743
that sounds really big. it may fit, but the little WR is way happier with a smaller tire.
z@ch is offline   Reply With Quote
Times are GMT -7.   It's 07:41 PM.
