Old 02-18-2013, 06:57 AM   #33166
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,290
^^^^ Henry: I went to a 12/45 combo specifically for more grunt in the woods. Helps to loft front wheel over small logs easier..plus gives more engine braking in second...which is something I wanted for trail riding/rear sliding in tight turns.
BUT, I may go back to a 13T front, since the bike with be a part time commuter this season. I have about 3K miles on my WRR , and minimal wear on my slider, even with the 12T. But again, 80% of those miles are two years worth of single track/enduro riding.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 02-18-2013, 07:01 AM   #33167
viper770
viper770's Avatar
Oddometer: 591
Holy cow !!!!
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 02-18-2013, 07:22 AM   #33168
burtonrider3889
Oddometer: 875
Thanks for the help with the chain. Hopefully I will be able to get this right next time I try. So I need to break loose the lock nut, then use another wrench to screw that screw outward and that will push the chain back right? Then tighten lock nut, then tighten the main shaft bolt back and I'm good?
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
burtonrider3889 is offline   Reply With Quote
Old 02-18-2013, 07:23 AM   #33169
Rider_WV
Rider_WV's Avatar
Oddometer: 2,396
So what is the consensus on the best replacement battery. Mine wont hold a charge so it needs replaced. I will not spring for a Shorai that thats off the list.
I am eyeballing the bikemaster gel battery on Rocky mountain. Anyone running that model?
Rider_WV is online now   Reply With Quote
Old 02-18-2013, 07:49 AM   #33170
burtonrider3889
Oddometer: 875
Also, another noob question. How often to you clean or wax the chain? I used to do it on my SV every 600 miles or so, but since this is getting a lot wetter and dirtier I'm not sure if I'm supposed to do it more often or less.
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
Old 02-18-2013, 07:54 AM   #33171
UtahFox
UtahFox's Avatar
Oddometer: 446
Why not the Shorai? I'm assuming that since you say you won't 'spring' for it, money is your issue? I'm planning on getting one, so I'm curious.
UtahFox is offline   Reply With Quote
Old 02-18-2013, 08:00 AM   #33172
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,980
Now there's a question that might be considered open for debate!
Right now I'm doing an experiment with mine - an off-brand (primary drive) gold x-ring chain. A buddy and I decided to not lube at all to see how our x-ring chains do. Theoretically these chains are supposed to be sealed to keep everything out of the moving innards.
My chain has been on the bike about 10K miles and isn't kinking yet or stretched noticeable yet. Hasn't needed adjusting yet anyway.
Sprockets are pretty shiny though. When it gets muddy I do try to get the mud and grit off the chain as soon as possible.
FWIW, on my 03 Dakar, which now has about 83K miles on her, I was getting over 25K miles on DID x-ring chains and the stock BMW steel sprockets. On that bike I was using the Dupont Teflon lube ($5 at Lowe's), which was a dry lubricant with a solvent propellant. I would lube it every other tankful which on that bike is about 400 miles. However about a year or so ago they changed the formula to a wet lubricant so I quit using it, though if this WR chain goes in the next few thousand miles I'll likely go back to lubing my chains with the Teflon stuff as it's cheap.
GSBS is offline   Reply With Quote
Old 02-18-2013, 08:00 AM   #33173
30Bones
30Bones's Avatar
Oddometer: 4,652
If you want a good battery just go to Batteries Plus if you have one nearby. Why is this so difficult?
30Bones is offline   Reply With Quote
Old 02-18-2013, 08:28 AM   #33174
Rider_WV
Rider_WV's Avatar
Oddometer: 2,396
the main reason for no shorai, all the guys at the local shop(ktm/gasgas/husky/berg) say they are not reliable. Im not spending that kind of cash on a battery that they see issues with regularly. I have known these guys for a long time, rode with them before they ended up in the shop, if they say they are unreliable I tend to believe them.
Old 02-18-2013, 08:30 AM   #33175
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,770
I don't see any reason not to just get another Yuasa, equivalent to the oem battery. They seem to work very well...
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 02-18-2013, 08:32 AM   #33176
Rider_WV
Rider_WV's Avatar
Oddometer: 2,396
I dont have shit near buy, i live in the sticks and need to order parts for 3 other bikes, I was just trying to get a suggestion on a battery that Rockymountain carries, one order one shipment.
Battery quality tends to vary greatly and people in this thread have tried several different ones. Since there is no back up kicker its kind of important to pick up a good battery.
You dont even own a WR so STFU and get back on PBB
Old 02-18-2013, 08:44 AM   #33177
30Bones
30Bones's Avatar
Oddometer: 4,652
Fair enough.
Old 02-18-2013, 08:56 AM   #33178
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,615
+1
Batteries are a consumable, might as well save some $'s. I triend a Shorai once...ONCE!
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 02-18-2013, 08:57 AM   #33179
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,689
As far as batteries go, I had good luck with Scorpion in my KLR250. The shop shipped it to me via USPS priority mail, and the battery worked well.
I have a Extreme Magna AGM in my 650GS (from Autozone) and I have not even put it on a trickle charge in the last two years and it always cranks like crazy. No issues whatsoever.
henrymartin is offline   Reply With Quote
Old 02-18-2013, 09:30 AM   #33180
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,980
+1 for Scorpion battery...
FWIW...I've had good luck with these batteries from this dealer:
http://www.batterystuff.com/powerspo.../sYT5L-BS.html
Times are GMT -7.   It's 06:05 AM.
