Old 02-19-2013, 05:16 AM   #33211
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,374
It's a good idea to give the swing arm a once over anyways. But I'd also say that the po might not be lack of maintenance. Tht old slide looked gummed up with lots of oil, lube of some sort. I always have a spare seal in my inventory for the bike as they seem to just disintegrate whenever they feel like it???
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 02-19-2013, 06:21 AM   #33212
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,688
Yes, the old slide is gummed up with some heavy lube, and the case saver / sprocket cover was completely clogged with lube and sand. Those spots should be cleaned every now and then, if not the resulting lapping compound shortens the life of chain, sprockets, and sliders.
The reason why I mentioned probable lack of maintenance, is because there were other things as well - such as misaligned rear wheel, loose axle nuts...
henrymartin is offline   Reply With Quote
Old 02-19-2013, 06:29 AM   #33213
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,826
It's too bad that TM Designworks doesn't make a chain slider for the WR250R. Their stuff is indestructible.
cjbiker is online now   Reply With Quote
Old 02-19-2013, 06:33 AM   #33214
bogboy
bogboy's Avatar
Oddometer: 58
Originally Posted by UtahFox View Post
Anyone have an opinion on grips? I'm going to swap out my bars soon, but don't know what to get for grips.
http://www.twistedthrottle.com/oxfor...s-sports-style
Very toasty, easy install
bogboy is offline   Reply With Quote
Old 02-19-2013, 07:26 AM   #33215
ggemelos
ggemelos's Avatar
Oddometer: 171
Does anyone have experience using heated grips with fat bars? I just ordered an HDB setup and was thinking it would be easy to replace the grips at the same time as I install the new bar, but I have heard that heated grips don't work well on aluminum bars as the aluminum soaks up the heat. Any first hand experience and recommendation for heated grips?
Preparation for RTW trip and future site of ride blog -> www.onthewanderlist.com
ggemelos is offline   Reply With Quote
Old 02-19-2013, 07:38 AM   #33216
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,766
Originally Posted by ggemelos View Post
...Any first hand experience and recommendation for heated grips?
I'm probably the only one here with this set up, but I like it. I use aerostich's velcro wrap grip heaters. They heat up very quickly and when I don't need them (which is most of the time) I take them off and store them. That way I can use the grips I like best and since they are positioned immediately under my gloves and insulated from the bars by the grips it doesn't matter whether you've got aluminum or steel bars.
They've worked well for me:
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 02-19-2013, 07:48 AM   #33217
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,848
I've used the standard symtec grip heaters on all my motorcycles including my current two (tiger 800 roadie and the wr) which both have Al bars. The symtec unit is supposed to compensate somewhat for the greater bar conduction on the clutch side. Yes, the Al is a great conductor of heat. To minimize the losses into the bar on the clutch side I wrap the bar with a couple layers of kapton tape. This helps but the throttle side still gets warmer. I am going to try to fit a thin piece of plastic tubing/pipe to mimic the throttle tube and secure that to the clutch side bar which I think will make things better. The symtec set-up is $35 and I've found it to be very reliable.
swimmer is online now   Reply With Quote
Old 02-19-2013, 07:48 AM   #33218
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,826
I have aluminum bars and the under-the-grips heating elements on my KLR. It does not work well. I even wrapped the left side with a few turns of electrical tape before applying the heating element to try and stop the heat loss. The grips get warm when I'm stopped at a light, but as soon as I get moving, they cool off as the airflow wicks the heat away through the bars.
I used the velcro heated wraps, and they get nice and hot, but I didn't like the extra bulk. I prefer thin grips. I'm going to try heated gloves next.
Old 02-19-2013, 07:55 AM   #33219
Outwardbound
Oddometer: 698
Picked up an "X" rear wheel today. My plan is NOT to pick up an X front wheel because I don't want to be swapping brake rotor hardware around to convert to a 17" front. I'm thinking about using street oriented tires and simply swapping for wheels with knobbies installed when I go for real dirt. The new wheel is a 17" rim as opposed to an OEM 18 on the "R". If I go with a higher profile on the tire ( for example 130/90 rather than 130/70) the rolling diameter of both the 18 and 17 should be very close to being the same. Thus from a handling standpoint it should be equivalent.....right? I'm NOT a suspension geometry expert, so I seek the wisdom of the hive (so to speak). Has anyone ever done the 21/17 combo?
Outwardbound is offline   Reply With Quote
Old 02-19-2013, 08:09 AM   #33220
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,989
A large piece (like sized for a battery cable) of heat shrink over the clutch side bar works well; in the past I have also glued a cut up piece of a soda bottle over the clutch side and then glued the heating element and grip over top of that.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 02-19-2013, 08:11 AM   #33221
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,826
I tried the heat shrink first, but couldn't get the grip over the HS+heating element.
Old 02-19-2013, 08:13 AM   #33222
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,989
Toss the grip in damn near boiling water for a minute or two, it'll stretch nicely when you install it and once it cools down will tighten back up. Apply it to the bar still wet, just shake off the excess water but don't actually dry it.
Old 02-19-2013, 08:28 AM   #33223
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 587
Have you tried using HVAC heat reflective Duct tape (available @ hardware store) on clutch side and use a plastic throttle tube, not metal one.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-19-2013, 08:43 AM   #33224
10Cup
10Cup's Avatar
Oddometer: 2,665
I have the hot grips on my WR with the aluminum handle bars and they work perfectly. VERY warm.
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup is offline   Reply With Quote
Old 02-19-2013, 08:47 AM   #33225
UtahFox
UtahFox's Avatar
Oddometer: 446
Sounds good, it's only ice racing season here so won't need it for at least a month. Yu think I'd lern. This is the second one ive done hi too. The first one wasn't on my bike though.
My stuff is on the way, but so is a storm and my work area is covered but outside. I'll give a shout out when I get it done. Have you thought about a tail tidy? Maybe that'd work better for you than stock.
UtahFox is offline   Reply With Quote
Times are GMT -7.   It's 05:44 AM.
