Old 02-19-2013, 08:13 AM   #33226
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 8,817
Originally Posted by cjbiker View Post
I tried the heat shrink first, but couldn't get the grip over the HS+heating element.
Toss the grip in damn near boiling water for a minute or two, it'll stretch nicely when you install it and once it cools down will tighten back up. Apply it to the bar still wet, just shake off the excess water but don't actually dry it.
Go forth, wander aimlessly, explore, have adventures and shit...
MeefZah is offline   Reply With Quote
Old 02-19-2013, 08:28 AM   #33227
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 350
Originally Posted by ggemelos View Post
Does anyone have experience using heated grips with fat bars? I just ordered an HDB setup and was thinking it would be easy to replace the grips at the same time as I install the new bar, but I have heard that heated grips don't work well on aluminum bars as the aluminum soaks up the heat. Any first hand experience and recommendation for heated grips?
Have you tried using HVAC heat reflective Duct tape (available @ hardware store) on clutch side and use a plastic throttle tube, not metal one.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-19-2013, 08:43 AM   #33228
10Cup
10Cup's Avatar
Oddometer: 2,269
I have the hot grips on my WR with the aluminum handle bars and they work perfectly. VERY warm.
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
SpearMotorSports, Inc.
The cost of living's going up, and the chance of livin's going down.
10Cup is online now   Reply With Quote
Old 02-19-2013, 08:47 AM   #33229
UtahFox
UtahFox's Avatar
Oddometer: 423
Originally Posted by Sewerat View Post
Sounds good, it's only ice racing season here so won't need it for at least a month. Yu think I'd lern. This is the second one ive done hi too. The first one wasn't on my bike though.
My stuff is on the way, but so is a storm and my work area is covered but outside. I'll give a shout out when I get it done. Have you thought about a tail tidy? Maybe that'd work better for you than stock.
UtahFox is offline   Reply With Quote
Old 02-19-2013, 09:27 AM   #33230
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 8,817
I know there's a lot of guys that use the DRC kit, but it seriously limits the intensity of your brake light and signals. The OEM Yamaha setup is a little big, but kind of balances the back of the bike in appearance; and is way safer on the street.
I've used both setups, and I went back to the stock setup after getting complaints from riding partners that they couldn't see my brake light or signals once they got the tiniest bit of dirt on them. The LEDs in the DRC also are known to go out prematurely; presumably bad soldering on the circuit board. No such issues with the OEM setup.
The OEM is fairly durable, too. The design of the signals allows them to pop out rather than break, and the taillight is pretty protected, minus looping the bike backwards.
Old 02-19-2013, 09:40 AM   #33231
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,324
Originally Posted by MeefZah View Post
...No such issues with the OEM setup.
Agreed.
"Coffee first..."
Next Trip: didn't get enough...Death Valley
"it's a dog's life.............and I love it"
HardWorkingDog is online now   Reply With Quote
Old 02-19-2013, 09:49 AM   #33232
oldtrucks
oldtrucks's Avatar
Oddometer: 212
Originally Posted by HardWorkingDog View Post
Agreed.
Sometimes the Japanese Engineers get it right
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin
oldtrucks is online now   Reply With Quote
Old 02-19-2013, 01:39 PM   #33233
UtahFox
UtahFox's Avatar
Oddometer: 423
Right on. Well for me it's mostly the look, and I can't stand the WRR tail look. If the lights don't turn out to be bright enough I'll address that. SO, you can still get mine :)
In the last 3 years I've had 3 bikes, the first of these was my first bike, a 2010 Triumph Scrambler and I didn't like its tail section either. So I changed this...
...to this...
My second bike, the 2012 Tiger actually had a look I really liked. I can't really put my finger on it, but kind of a euro industrial road tech look. These are the first reflectors I've seen that I really like. The only thing I did to it was an LED bar above the stock tail light, which would make a fantastic tail light for the WRR. It was crafted by another ADV'er - think I'm going to have to look him up :)
The current WRR one isn't long for this world
Old 02-19-2013, 01:40 PM   #33234
ggemelos
ggemelos's Avatar
Oddometer: 115
I just picked up an Eastern Beaver 3CS kit for my bike and was wondering where to tap into the bike's electrical systems for the relay trigger. The kit comes with posi-locks for tapping into the trigger wire. I have read a few posts of people tapping into the rear highlight wire, not sure which wire exactly, but I am weary of the reliability of posi-locks (they looks so flimsy). I read a post by Nice_Rumble about using a relay from the bike itself which appears to be near the battery. It seems a lot more secure to tie the trigger wire into the positive terminal of the relay. Would this work? What relay is Nice_Rumble referring to in his picture? Thanks for the help.
www.tailevent.com
ggemelos is offline   Reply With Quote
Old 02-19-2013, 02:03 PM   #33235
oldtrucks
oldtrucks's Avatar
Oddometer: 212
The Rear Tail Light wire is easy access just above the battery. Pull the seat off, there are several groups of wire going to the rear of the bike that are shrouded by a piece of plastic. Slide the plastic cover back and it exposes all of the connectors. Unhook them until you find the tail light circuit. On my bike there was enough slack in that set of wires to cut and solder into.
Old 02-19-2013, 03:08 PM   #33236
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 1,351
[IMG]https://lh4.googleusercontent.com/-j1wQo9ZYHlo/TiNPdWF_8gI/AAAAAAAADEQ/l_kV9UgDasM/s800/Snowbird%2520Tram.jpg[/IMG
...to this...
What tail light is that on the Scrambler? I had a DRC on my KLX, and it was junk. I don't like the WR tail, but I won't buy another DRC.
cjbiker is online now   Reply With Quote
Old 02-19-2013, 03:16 PM   #33237
Scott_PDX
Scott_PDX's Avatar
Oddometer: 1,096
+1
When I last did the research found lots of reports that the elements that wrap around the aluminium bars suffer from some Heat Sink effect from the Aluminium. Grips that have the elements embeded into the GRIPS seem to be a better choice for heat, but some folks hate the larger grip that they give you. I put Hot Grips on my WR and they've been great. Now the big ass ceramic resistor they give you is kinda a PITA, but it works.
I've got some of the cheaper ones on my KTM but I'm too chicken to try them (tiny battery syndrome).
2011 WR250R
2009 KLR650
2004 KTM 450 EXC
2000 R1150GS
"The older I get, the faster I was"
Scott_PDX is online now   Reply With Quote
Old 02-19-2013, 03:45 PM   #33238
jckid
Oddometer: 232
I'm probably the only one here with this set up, but I like it. I use aerostich's velcro wrap grip heaters. They heat up very quickly and when I don't need them (which is most of the time) I take them off and store them. That way I can use the grips I like best and since they are positioned immediately under my gloves and insulated from the bars by the grips it doesn't matter whether you've got aluminum or steel bars.
They've worked well for me:
I have these too, and I'd recommend them. Prior to this I had the thin, cheap warmers that fit underneath any grip. They didn't work well...well actually the one on the throttle side worked good, but the one on the other side didn't. Maybe the alumimum sucked the heat out of that side. I don't need heated grips too often, so these (like in pic) work good for me.
Current: '11 WR250X, '09 KLX351, '84 Honda Trail 110 Previous: '08 Husky SM610
My one & only ADV ride report: ttp://advrider.com/forums/showthread.php?t=597160&highlight=river
jckid is offline   Reply With Quote
Old 02-19-2013, 03:45 PM   #33239
UtahFox
UtahFox's Avatar
Oddometer: 423
This thing, BCC?
http://www.bellacorse.com/bcc136.htm
Old 02-19-2013, 03:47 PM   #33240
skierd
Wannabe Far-Rider
Oddometer: 2,685
Send a message via AIM to skierd
Hot Grips do a good job of insulating against aluminum bar's heat sink effect. I had a set of my old WRR on ProTaper Evo's and they worked well. They work better on the stock steel bars, but work just fine on aluminum. No idea if the under grips work better or not as I like the fatter grip of the Hot Grips most of the time.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X - 1998 Honda Nighthawk CB750
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is online now   Reply With Quote
Times are GMT -7.   It's 12:41 PM.
