Old 02-19-2013, 07:20 PM   #33241
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,290
Originally Posted by Outwardbound View Post
Picked up an "X" rear wheel today. My plan is NOT to pick up an X front wheel because I don't want to be swapping brake rotor hardware around to convert to a 17" front. I'm thinking about using street oriented tires and simply swapping for wheels with knobbies installed when I go for real dirt. The new wheel is a 17" rim as opposed to an OEM 18 on the "R". If I go with a higher profile on the tire ( for example 130/90 rather than 130/70) the rolling diameter of both the 18 and 17 should be very close to being the same. Thus from a handling standpoint it should be equivalent.....right? I'm NOT a suspension geometry expert, so I seek the wisdom of the hive (so to speak). Has anyone ever done the 21/17 combo?
I had an X and put just a ''21 front on for a few hundred miles. Worked just fine in my book. Only bought the ''18 rear for the sake of having two complete sets.
WARNING: Most things posted above contain sarcasm.
Daamud is online now   Reply With Quote
Old 02-19-2013, 07:25 PM   #33242
viper770
viper770's Avatar
Oddometer: 578
just installed the full Graves Exhaust
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 02-19-2013, 07:26 PM   #33243
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by burtonrider3889 View Post
How do you make sure the rear tire is "aligned" properly?
You can eye ball it and get pretty close, but the acid test is to get on a level flat road and take your hands off the handlebars. (assuming no wind) If your bike drifts one way or the other adjust your rear axle accordingly.
I do it standing on the seat. Makes it more interesting!
KansasBob is offline   Reply With Quote
Old 02-19-2013, 07:50 PM   #33244
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,566
Guys, still looking for the torque specs (if someone has them) for the rear suspension linkage.
henrymartin is offline   Reply With Quote
Old 02-19-2013, 07:57 PM   #33245
Longboardr
Longboardr's Avatar
Oddometer: 143
From the WRR/X forum
http://wr250rforum.forumotion.com/t5...ghlight=torque
Longboardr is offline   Reply With Quote
Old 02-19-2013, 08:04 PM   #33246
Mr.Black999
Mr.Black999's Avatar
Oddometer: 242
The swing arm axle nut is 62 ft lb and the bolt for where the linkage attaches to the swing arm is 51 ft lb, this is per the service manual. If you need any other ones I'll see what I can find.
Mr.Black999 is offline   Reply With Quote
Old 02-19-2013, 08:25 PM   #33247
Outwardbound
Oddometer: 688
Thanks! That's what I suspected.
Outwardbound is offline   Reply With Quote
Old 02-19-2013, 08:51 PM   #33248
henrymartin
Mr. Tourguide
Oddometer: 3,566
Originally Posted by Longboardr View Post
and Thanks!
I'm taking the linkage apart completely (some slight rust on the bushings).
Old 02-19-2013, 10:39 PM   #33249
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 758
Originally Posted by cjbiker View Post
What tail light is that on the Scrambler? I had a DRC on my KLX, and it was junk. I don't like the WR tail, but I won't buy another DRC.
Originally Posted by UtahFox View Post
That taillight looks like one that Baja Designs makes.
http://www.bajadesigns.com/ProductDe...mNumber=600709
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 02-20-2013, 06:45 AM   #33250
ggemelos
ggemelos's Avatar
Oddometer: 127
Originally Posted by oldtrucks View Post
The Rear Tail Light wire is easy access just above the battery. Pull the seat off, there are several groups of wire going to the rear of the bike that are shrouded by a piece of plastic. Slide the plastic cover back and it exposes all of the connectors. Unhook them until you find the tail light circuit. On my bike there was enough slack in that set of wires to cut and solder into.
Thanks, seems easy enough.
Preparation for big trip and future site of ride blog -> www.onthewanderlist.com
ggemelos is offline   Reply With Quote
Old 02-20-2013, 06:47 AM   #33251
30Bones
30Bones's Avatar
Oddometer: 4,634
Originally Posted by Crawdaddy View Post
Tom is in Prescott.......I'm in Bullhead City on occasion since I have a vacation shack over there.....
Those over wrap grip heaters look like a good idea.......I've always used the cheapo under grip elements and isolating the resistor is a PITA..........they work OK but nothing great......when it's really cold I use Elephant ears in front of my bark busters to shield my hands: http://www.motorcycle-superstore.com/2/9/192/7276/ITEM/MSR-Hand-D-Flectors.aspx
(remember, I'm a San Diego wimp so I define cold differently than most )
Those grip over heaters work better than any under grip element heater I have ever had. BMW factory /grips/heaters still are the tops I have experience with. Now if I were buying all new grips and heaters I would get hot grips or comparable.
30Bones is offline   Reply With Quote
Old 02-20-2013, 07:25 AM   #33252
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
As I was riding through the area, I was thinking that there looked like a lot of good riding all around Bullhead City. I'll be back.
Short snipit taken by a buddy who went riding with me 2 weeks ago: http://www.youtube.com/watch?v=P397V...layer_embedded
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 02-20-2013, 08:31 AM   #33253
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,317
Looks a lot better then the stuff I'm riding in right now.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 02-20-2013, 12:59 PM   #33254
True North
True North's Avatar
Oddometer: 19
Not sure how this would work on a bike but on the snowmobile if we want warmer hand warmers we put expanding foam inside the bars. This might hold the heat on the clutch side a little better.
True North is offline   Reply With Quote
Old 02-20-2013, 03:05 PM   #33255
UtahFox
UtahFox's Avatar
Oddometer: 446
I'm wondering, how difficult is it to replace the header? Is it simply unbolt and replace?
UtahFox is offline   Reply With Quote
Times are GMT -7.   It's 05:17 AM.
