Old 02-28-2013, 02:56 AM   #33421
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,199
B&B all the way on Bash plates
http://www.bboffroad.com.au/wr_250r_steel_frame.htm
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is offline   Reply With Quote
Old 02-28-2013, 05:43 AM   #33422
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,624
Originally Posted by pfy50 View Post
HM
I found these
http://pivotworks.com/ProductInfo.aspx?item_id=1558 Seem inexpensive I sent an email to see where they get their bearings, but no reply yet. They do say they are ABEC3 and come with a lifetime replacement guarantee.
Not sure about pivotworks, as I haven;t used them before.
I'm not obsessive about bearings, I just want to find something that works for more than a season or two. There are only so many replacements that the hub will handle before something else has to be done.
henrymartin is offline   Reply With Quote
Old 02-28-2013, 07:01 AM   #33423
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 577
Hey Henrymartin,
I'm right there with you. I have a regrease or replace of the swingarm and linkage bearings(wheel beaings are new) coming up in a month or so prior to my summer trip to AK so if you settle on anything let us know as I don't fancy replacing bearings or regreasing any more than absolutely necessary.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-28-2013, 07:13 AM   #33424
eemsreno
Oddometer: 974
Out for a ride today.
eemsreno is offline   Reply With Quote
Old 02-28-2013, 09:14 AM   #33425
UtahFox
UtahFox's Avatar
Oddometer: 446
Brrr. I'm ready for Winter to be OVER!!!! Farkles arriving daily and its too cold to do anything about it.
UtahFox is offline   Reply With Quote
Old 02-28-2013, 09:37 AM   #33426
shep546
shep546's Avatar
Oddometer: 215
Hey guys I just bought a tire that is 120/100/18... the guy at the shop mentioned it's probably too big for my bike... should I return it for a 100/100-18?
shep546 is offline   Reply With Quote
Old 02-28-2013, 10:14 AM   #33427
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,481
Size depnds on which tire and manufacturer. A 120/100 in any tire is probably too tall.
You need to physically measure what you bought against the stock tire if you have on. The rear can vary 1"-2" difference in height, which can and will make the bike handle squirrely, pusjing the front end.
OEM size is indeed a 120, but most knobbies are going to run taller.
A 110 could work, but a 100 is highly possible.
Again, depends on the tire.
I run a 110/80 Pirelli MT21 on the rear...I made all the mistakes....
Listen to your shop.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is online now   Reply With Quote
Old 02-28-2013, 11:07 AM   #33428
jon_l
jon_l's Avatar
Oddometer: 3,202
Originally Posted by rsteiger View Post
Just beware that when you bolt on one of the Al skid plates you are going to wonder what is wrong with your motor the first time you start it up. The Al resonates pretty well. Some of the guys will coat the bottom of the skid plate with spray on bed liner from a can. Based on my experience with my KTM that seems to work pretty well.
I wrapped the bike frame with pieces of cut-up tube to isolate the skid plate from the frame. Not sure how much it helps. In any case, after installing the Flatlands, I didn't have the negative reaction to the noise that many report.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 02-28-2013, 11:16 AM   #33429
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,731
I did that, as well as a good set of earplugs; works great.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 02-28-2013, 11:32 AM   #33430
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,328
I did that as well, and never noticed much more sound from the plate. It gets repeated here so often, that there must be some issue. Now the FMF Q4 I added to the bike, that requires ear plugs after awhile.
-= Scott
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 02-28-2013, 11:56 AM   #33431
AZ TOM
Oddometer: 4,000
110/100/18 Should work on most all brands. Maxxis, Perelli, Dunlop. Have been using Maxxis Desert IT 110/100/18. Last well & works great.
AZ TOM screwed with this post 02-28-2013 at 01:44 PM
AZ TOM is offline   Reply With Quote
Old 02-28-2013, 11:58 AM   #33432
viper770
viper770's Avatar
Oddometer: 582
I have the Richochet and my friend is running the Flatland one.
When I look at the two side by side the Flatland has better protection especially around the water pump. I have made the decision to replace my Richochet with either the Flatland or Moose Racing plastic skid plate.
i use the flatland racing skid plate and i get alittle noise but not very much but ill do some thing about it one of these days
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 02-28-2013, 12:04 PM   #33433
TwilightZone
Oddometer: 3,066
120 width works fine on mine.
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 02-28-2013, 12:06 PM   #33434
shep546
shep546's Avatar
Oddometer: 215
Originally Posted by AZ TOM View Post
110/100/18 Should work on most all brands. Maxxis, Perelli, Dunlop. Have been usuing Maxxis Desert IT 110/100/18. Last well & works great.
So you guys think the 120/100/18 is gonna be too tall?
There is about a 1.5" difference in OD between the stock tire and this new knobby...
Old 02-28-2013, 12:19 PM   #33435
TwilightZone
Oddometer: 3,066
>"So you guys think the 120/100/18 is gonna be too tall?"
1) What brand/model is it ??? Different make and model tires vary quite a bit on the outside diameter. (example Dunlop 120 606's add nearly an inch of seat height to the WR) So, how long are your legs?
2) You may need to add a couple links to your chain... (i.e. move wheel to rear).
Times are GMT -7.   It's 12:47 PM.
