Old 02-28-2013, 06:06 PM   #33451
Harcomo
Oddometer: 120
Originally Posted by viper770 View Post
i use the flatland racing skid plate and i get alittle noise but not very much but ill do some thing about it one of these days
Is that the Wolfman Enduro bag on your bike? Looks good on there!
Harcomo is offline   Reply With Quote
Old 02-28-2013, 06:16 PM   #33452
viper770
viper770's Avatar
Oddometer: 591
yes it is a Wolfman Enduro bag
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 02-28-2013, 07:49 PM   #33453
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,743
Originally Posted by henrymartin View Post
Given the condition of the maintenance items on my "new to me" bike...
Christ, we get it, your bike was owned by a moron.
You're clearly such an expert on bike maintenance I'd think you'd notice some of these items before buying...
Also, no reason to buy non-oem bearings. Ones that haven't been abused last 10s of thousands of miles.
z@ch is offline   Reply With Quote
Old 03-01-2013, 05:11 AM   #33454
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,688
How about a little easy on the keyboard. AFAIK, I haven't said anything to offend you.
I never said my bike was owned by a moron. I never said I was an expert at anything. I also never haven't seen the bike before it was delivered to me (gift from a spouse).
If I were buying it myself, I would have checked some things, like sprockets, wheel spin, et cetera.
So, forgive me if my desire to learn a few tricks from this forum disturbed your morning web browsing.
Geez, my posts on rebuilding old bikes have helped a few members along the way, so maybe I was hoping this forum would help me the same way.
henrymartin is offline   Reply With Quote
Old 03-01-2013, 05:55 AM   #33455
ggemelos
ggemelos's Avatar
Oddometer: 172
Question Throttle cable housing question
I took apart my throttle cable housing to install a new throttle tube and Hot Grips heated grips. When opened the throttle cable housing, I noticed a black plastic disk on the throttle tube that slides off when you remove the old grips. I transferred the disk to the new throttle tube before mounting the new grips. Now that I want to put everything back together again, I am not sure if the black disk is meant to go inside the throttle cable housing or stay outside and act as a barrier between the rubber grip and the housing (maybe to avoid the rubber touching the housing and getting stuck?). The service manual does not mention this disk. Can anyone tell me if I should put the black plastic disk inside the housing or leave it outside between the housing and the grip? Thanks
Preparation for RTW trip and future site of ride blog -> www.onthewanderlist.com
ggemelos is offline   Reply With Quote
Old 03-01-2013, 06:17 AM   #33456
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,993
What amuses me is that a lot of guys who are obsessive over maintenance usually have few miles; while guys that ride a lot tend to do what needs to be done in the interests of keeping on riding. Shit, I replace tires when cords are showing, the only time I even think about replacing a wheel bearing is when it goes out, and I usually lose a few teeth off my sprocket before I change that out. Swingarm bearings, what the fuck ever, x 21,000 miles now. I literally do not care - even though I love my bike.
Come to think of it, the guy that bought my 1st WRR later complained to me about the chain slider being half clapped out, missing bolts, gouged plastics, and a shagged chain and sprockets. He totally disassembled the swingarm and subframe and cleaned, greased, ejaculated, whatever it is those guys do... and he's since put about 800 miles on it in 2 years. I used to invite him to dirt rides until it became obvious he was never going to come because he might tweak some of the new bits he had put on and he was worried that water crossings would instantly cause his wheel bearings to seize.
You know what preventative maintenance I have done... I replaced the left side engine case after I holed it... and I didn't even change the oil; just topped it off. I guess I did also, a while back, replace the swingarm chain slider, but that was just to disprove a theory. I should put the old one back on and return the new one to Service Honda...
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 03-01-2013, 06:18 AM   #33457
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,993
It is external, you have it right. It is designed to minimize friction between the rubber grip and the plastic housing so the throttle doesn't get stuck open.
Old 03-01-2013, 06:18 AM   #33458
shep546
shep546's Avatar
Oddometer: 215
So I'm really torn between whether or not I should try and return the 120/100-18 knobby for a 100/100-18... some guys are saying big difference others are not...
shep546 is offline   Reply With Quote
Old 03-01-2013, 06:20 AM   #33459
ggemelos
ggemelos's Avatar
Oddometer: 172
Thanks, that makes sense, I just wanted to confirm.
Old 03-01-2013, 06:45 AM   #33460
alansz400
alansz400's Avatar
Oddometer: 1,002
All this maintenance talk had me thinking maybe I should check my swingarm and linkage bearings so last night I took a look at all those bearings and they all look good. Cleaned then up alittle and put some new grease on them and dont plan on looking at them for another 15000 miles. My swingarm bolt also came out real easy. I never ride my WR in the water so that may be why everything was in good shape.
alansz400 is offline   Reply With Quote
Old 03-01-2013, 07:10 AM   #33461
AZ TOM
Oddometer: 4,075
Would you stop Just mount that 120 up & go out & ride
AZ TOM is offline   Reply With Quote
Old 03-01-2013, 07:22 AM   #33462
shep546
shep546's Avatar
Oddometer: 215
Got people on another forum telling me the 120 is too much for the 250... ahh well it's a $60 tire I'll go with it and see how it is
Old 03-01-2013, 07:24 AM   #33463
viper770
viper770's Avatar
Oddometer: 591
yea baby just do it ride it like you stole it
2012 YAMAHA WR250R
Old 03-01-2013, 08:04 AM   #33464
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 587
Given the condition of the maintenance items on my "new to me" bike, I'd like to change the fork oil tomorrow. My google-fu is not returning any useable results, and I never emptied WR forks (or any USD forks for that matter, only conventional - plenty of them). So...
loosen top nut, remove forks from clamps, unscrew top, dump oil out, clean, and refill with new?
What is the spec oil amount in each leg and the torque for top nut (not clamps)?
Anyone went with 10w fork oil instead of the stock 5w?
HM,
Sent you a PM
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 03-01-2013, 08:24 AM   #33465
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,993
Das. Ist. Bullshit!!!!!!!!!!!!!!!!!!
I have like 50 more of you but Photobucket is not working so great.
Times are GMT -7.   It's 09:15 PM.
