03-06-2013, 10:33 AM
#33601 | |
Professional nOOb
Oddometer: 350
IMHO heated items should go thru a relay and switch of their own and not pull load off of any primary circuits for safety. At the very least take the power port off the same line as the heated grips which should have their own 5amp line. ps. some useful info on the Hot grips faq pg.http://www.hotgrips.com/faq.php#14
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875 2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours May the Lord bless you and keep you in all the Dark places you must travel
pfy50 screwed with this post 03-06-2013 at 10:48 AM |
03-06-2013, 10:52 AM
#33602 |
Wannabe Far-Rider
I've run my heated grips off of the headlight circuit (a 15A fuse) for years, never had an issue with my lights or grips. Same way BigDog does his.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
03-06-2013, 01:55 PM
#33603 | |
Oddometer: 642
03-06-2013, 07:22 PM
#33604 | |
Professional nOOb
Oddometer: 350
What ever works, it's just a little safer on a lighter loaded circuit as long as the wiring is the same guage.
pfy50 screwed with this post 03-06-2013 at 07:34 PM |
03-06-2013, 08:05 PM
#33605 |
Wrong way 'round
I ran mine on an old honda on the running light circuit.
They don't pull much usually
"Build a man a fire and he will be warm for the night, set a man on fire and he will be warm for the rest of his life." |
03-06-2013, 11:13 PM
#33606 |
Oddometer: 56
WR250R flashing check engine light?
Hey all,
First of all, great thread, I'm learning a lot. I've tried searching for this issue but I haven't been able to find the answer, so here goes... I bought my '08 WR250R used at 5,000 miles with the EXUP valve removed, airbox mod done and the complete FMF system (header, tailpipe and power programmer). The check engine light was on (continuously) but this didn't worry me since that's what happens when you do those engine mods. However, last I rode the light started flashing at a rate of roughly one second per flash. Then it went off entirely. Then it came back on again and went back to flashing. It happens in all kinds of situations, on-road and off, at all rev ranges, speeds and throttle levels. I don't know if the fuel pump was replaced but it works fine after nearly 5 years and 5,000 miles (I try not to run it low on gas). Everything else seems to work as it should. The computer throws no error codes, the engine gives plenty of power and the bike is a blast. I've changed the chain recently and after parsing all the competing scholarly sources on setting the slack, I think I have it set OK. Last oil change was 600 miles ago and I clean/swap the air filter every 3-400 miles (more if dirty/dusty). What does a flashing check engine light mean? Should I worry? Thanks for any wisdom you might offer!
WR250R |
03-07-2013, 12:39 AM
#33607 |
Oddometer: 231
oh thats a easy fix just find some klx or a drz400 and sacrifice it to the WR god and all will be forgiven and check engine light should go away
2012 YAMAHA WR250R 2013 KAWASAKI KLR650 "Take the long way home" YOU GOT TO WATCH ---->http://vimeo.com/53311329 |
03-07-2013, 03:50 AM
#33608 | |
Oddometer: 191
Get the code checked?
03-07-2013, 04:20 AM
#33609 |
Oddometer: 175
No error code...hmmmm? Anyway I hope this is of some help.
Here's a fault code list: http://wr250rforum.forumotion.com/t4621-fault-codes If it's an error code 17/18 there are a couple of easy fixes. One for around $10 (home made) and one from Graves: http://www.gravesport.com/Graves-Mot...liminator.html I went with the rather expensive Graves fix.
With <.001% of earth's landmass paved, don't limit your ride DragonNester screwed with this post 03-07-2013 at 04:28 AM |
03-07-2013, 07:24 AM
#33610 |
Oddometer: 115
I am in the process of installing Hot Grips heated grips on my bike. I am wiring it to a relay triggered by the license plate light. The resistance of each grip is about 10.5Ohm. They are wired in parallel which means they will nominally each pull about 1.15A, 2.3A total. That is not a huge amount, but enough that I would not want to tied in to an existing circuit.
www.tailevent.com |
03-07-2013, 07:33 AM
#33611 |
Oddometer: 1,949
>"I bought my '08 WR250R used at 5,000 miles with the EXUP valve removed...check engine light..."
Sound like you didn't do the resistor jump in the EXUP controller end ($1 from Radio Shack) or buy the pre-made jumper end ($45 12 O'clock Labs). I believe there should be some info on WRRDualsport.com. Post back if you don't find it. BTW: I did the resistor jump, worked fine, no error code. Then I did the pre-made jumper which has a bit more electronics in it. I "felt" that the jumper made a bit of difference... but heck... dunno. Would be nice to perform that test on a dyno.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga! TwilightZone screwed with this post 03-07-2013 at 07:39 AM |
03-07-2013, 08:53 AM
#33612 | |
Oddometer: 211
Without ruling out the EXUP first you're really guessing what the problem is
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin |
03-07-2013, 09:04 AM
#33613 | |
Professional nOOb
Oddometer: 350
ps. the taillight circuit is a 10amp line usually 16 or 18 guage wire so good to go with other loads noted in post #33602
03-07-2013, 11:06 AM
#33614 | |
Oddometer: 56
I'll wire up an EXUP plug in module and I'll let you guys know if anything interesting happens.
WR250R |
03-07-2013, 12:20 PM
#33615 |
Candy-Assed Rider
Oddometer: 170
I love my WR250R
Hey Inmates, I just stumbled across this thread, and I have many questions about the bike and some add-ons. I recently returned from the sandblast rally down in Cheraw, SC. Awesome Rally, and there's much about it on this website. I was the only WR250R out of the 48 bikes, and I came in second in the Light Class.
Does anyone else race their WR250R here on the east coast? I'm looking for some other opporutnities to get involved. Here's a picture from the Sandblast. Great times! ![]() ![]() 2013sndblstrally0214copy_zps824bfebc by louisianazouaves, on Flickr Semper Fidelis, Buck
Mine: '10 R1200 GS ADV (30th Anniversary), '08 WR250R, & '72 R75/5 ToasterTank with sidecar Hers: '09 F800 ST |
