Old 03-07-2013, 10:20 PM   #33631
Gryphon12
Gryphon12's Avatar
Oddometer: 1,346
Originally Posted by TwilightZone View Post
>"I am just curious if anyone can let me know what the benefit is vs. just leaving it alone. Thanks"
Airbox mods (not much change)
Air injection module removal (not much change)
However, the first 2 plus the following:
Q4 Pipe (big change)
Fuel Controller (big change)
Header (big change)
On many other bikes, the pipe / controller / header also result in a significant reduction in fuel economy, because the engine is now making more power and not running lean anywhere in the rpm range. Is that also the case here? If so, how much loss? I'm trying to balance horsepower increases with decreased overall range of travel - which will help me select the right size aftermarket gas tank.
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 03-08-2013, 05:10 AM   #33632
ggemelos
ggemelos's Avatar
Oddometer: 177
Originally Posted by UtahFox View Post
I'm still deciding on what to do about mirrors. I put fat bars on so will most likely be going with HDB handguards, so I'm considering those too. The jury is out, so to speak. Can I screw a ram ball into the OEM mirror mounts?
The OEM mirror mounts are reverse threaded, at least I know that is the case for the throttle side. I would assume the clutch side if the same. That might make it hard to get a ram ball in there. I tried to find a bolt to plug the mirror hole on the throttle side and had a hard time because of the reverse thread. I ended up getting a Yamaha plug.
In progress RTW trip ride blog -> www.onthewanderlist.com
ggemelos is offline   Reply With Quote
Old 03-08-2013, 05:17 AM   #33633
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,972
If I were going with HDB guards I'd use their mirrors that nest inside the guards. Otherwise, I have and really like these.
GSBS is offline   Reply With Quote
Old 03-08-2013, 05:30 AM   #33634
DragonNester
DragonNester's Avatar
Oddometer: 478
Just take the adapter off with the mirror on the clutch side and screw a Ram Ball directly into the perch. Leave the adapter on the throttle side and screw directly into it. I use Double Take mirrors with Ram Ball/ 3" extensions...no more broken mirrors.
Happiness is wanting what you get.
DragonNester is offline   Reply With Quote
Old 03-08-2013, 07:15 AM   #33635
bradrh
Oddometer: 439
AIS, airbox, EXUP
Originally Posted by lammy View Post
Hey there, I have been riding my WR for about a year now on and off the black top and I have been seeing the mods to eliminate the AIS and the airbox flapper. I am capable of doing it, but I am having a hard time finding why it is done and what the benefit is. Will doing these mods increase power or performance? If I do them will it effect any other portions of the bike?
I'd add to that list the EXUP. Has anyone figured out what the purpose is, and what the effect is of removing it, or blocking it open? I've read that it's supposed to close down at low rpm & increase the torque, [ http://en.wikipedia.org/wiki/EXUP ] but I've also read that it doesn't close at low rpm, it closes at high RPM.
- DR650
- WR250R times 2
bradrh is offline   Reply With Quote
Old 03-08-2013, 07:37 AM   #33636
TwilightZone
Oddometer: 3,190
>"the rpm range. Is that also the case here? If so, how much (mileage)loss?"
It really depends on your right-hand wrist. Mileages below are with airbox mod, fuel controller, Q4 pipe (air and exup removed).
In Baja I took it very 'easy' on a 'long-fuel' highway run, I figure at least 68 mpg. (168 miles with no fuel light on!)
Normal dualsport riding, about 60 mpg. (150 miles fuel light on)
Really opening it up... probably 55 mpg.
Dualsport... my 3.1 gallon tank lasts about 180 miles... till dry.
Low fuel warning comes on with about .6 gal left in the tank.
(run till dry = don't want to do that, kills fuel pump)
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 03-08-2013, 07:44 AM   #33637
ggemelos
ggemelos's Avatar
Oddometer: 177
Safari tank installation question
I just ordered a transparent Safari tank for my wrr and after reading a few of the installation instructions, I had a question. Many people advise rinsing out the tank before installing. The instruction from Safari even suggest using some fuel to do this. How do you rinse out the tank with fuel before installing the fuel pump? Does anyone use a different method to rinse the tank out? Thanks
Old 03-08-2013, 07:45 AM   #33638
TwilightZone
Oddometer: 3,190
>"I'd add to that list the EXUP. Has anyone figured out what the purpose is, and what the effect is of removing it, or blocking it open? I've read that it's supposed to close down at low rpm & increase the torque, but I've also read that it doesn't close at low rpm, it closes at high RPM. "
EXUP valve closes at low rpm. The computer controls a servo valve that connects via cables to the EXUP valve. Increases back pressure in the exhaust = better torque down low. Same thing that the 'Megabomb', 'Powerbomb' and 'Graves' headers do via chambers.
I believe that disconnecting the EXUP servo allows the EXUP valve to remain open. Some people have also removed the EXUP valve from the stock exhaust, which requires metalworking skills.
Old 03-08-2013, 07:49 AM   #33639
TwilightZone
Oddometer: 3,190
>"How do you rinse out the tank with fuel before installing the fuel pump?"
Blow the tank out with air (if you have it). Then rinse the tank a couple times with a cup of fuel and dump it out. This removes plastic shavings in the tank that clog up fuel pump (or carb).
Old 03-08-2013, 07:56 AM   #33640
AdvRich
Parallel Reality
AdvRich's Avatar
Oddometer: 1,874
I use air, water and time. I left the tank cradled upside down with the cap area open to aid venting. It was completely dry the next morning. Did this for my KLR 6.6 gallon tank and will again for the 3 gallon IMS for the WR. Simple and effective if you have the overnight time.
FS: WRR/X Parts Garmin mount
"If you do not change direction, you may end up where you are heading." Lao Tzu
AdvRich is offline   Reply With Quote
Old 03-08-2013, 08:06 AM   #33641
simmons1
simmons1's Avatar
Oddometer: 1,597
I have always done mine with water as well.
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is offline   Reply With Quote
Old 03-08-2013, 09:30 AM   #33642
shep546
shep546's Avatar
Oddometer: 215
New shoes for spring, pirelli mt21 front and kenda trakmaster rear.
shep546 is offline   Reply With Quote
Old 03-08-2013, 09:33 AM   #33643
UtahFox
UtahFox's Avatar
Oddometer: 446
What kind of conditions will you be riding those in? Just curious what it's like riding over there. I've wanted to go up your way for as long as I can remember.
UtahFox is offline   Reply With Quote
Old 03-08-2013, 09:55 AM   #33644
Red Sand
Red Sand's Avatar
Oddometer: 300
I plan on riding home this afternoon on a new 2013 WR250R
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
I used to remove the rear pegs . . . now I keep them on just in case I find a gorgeous woman with no STD's who needs a ride . . . like that's ever gonna happen
Red Sand is offline   Reply With Quote
Old 03-08-2013, 11:17 AM   #33645
ggemelos
ggemelos's Avatar
Oddometer: 177
Thanks for all the replies to the tank cleaning question. I also noticed that 10cup added brass weighted fuel pick-up to the tubes that run down the wings. Do people find this makes a difference or is the stiffness of the fuel tubes enough to keep the pick-up tubes from riding up?
Times are GMT -7.   It's 11:36 AM.
