Old 03-22-2013, 11:36 AM   #34021
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by z@ch View Post
A couple shots from last weekend is SE OK
Gorgeous shots. Where were they taken? I'd like to look it up on Google Maps. I'm headed down to a cousin's place in Austin in May, and I'd love to start building a tic list of places twixt here and there.
UtahFox is offline   Reply With Quote
Old 03-22-2013, 11:39 AM   #34022
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by KansasBob View Post
The honest truth is I love to work on my bike....... almost as much as I love to ride it. If I go the extra mile and engage in the art of preventive maintenance well before it is absolutely needed I receive the dual satisfaction that I won't be stranded with a worn out part, and that I am riding a machine that is truly a part of me. It's all very ZEN ......... and again, not saying there is anything wrong with the way you do it. Ride that Bitch till she breaks, and fix it. It's just a motorcycle.
+1 When I'm working on my bike time just flies. Throw on some tunes, can't think of many better ways to spend the day.
Old 03-22-2013, 11:42 AM   #34023
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,751
Those were all taken in OK on forest roads in the Ouichita nat'l forest.
z@ch is offline   Reply With Quote
Old 03-22-2013, 11:42 AM   #34024
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by Counselor1 View Post
header/exhaust changed
ultimate airbox mod
flapper removed
exup removed
all body panels removed and painted.
sounds about it.
They look like seat bolts to me. That said, I had lots of nuts bolts and random doohickies after doing all that stuff. I've come to not worry about it, I just check for what needs to be buttoned down and don't sweat it.
Old 03-22-2013, 11:45 AM   #34025
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by shep546 View Post
Hey guys,
Just got my FMF pipe in the mail, I started removing my old pipe until I got to the exup part...
what do I do here so I don't throw a code? I don't want to spend $50 on some module.
Thanks.
Unless you know how to fab one up, yeah. You could just disconnect the cables and leave it in place too.
Old 03-22-2013, 11:50 AM   #34026
UtahFox
UtahFox's Avatar
Oddometer: 446
Hmm. Kind of out of the way on the way to Austin, but maybe after.
Old 03-22-2013, 12:55 PM   #34027
skierd
Wannabe Far-Rider
Oddometer: 2,990
What size bolts are they? 10mm, rear fender bolts. 8mm, they're something else. Too short to be seat bolts.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 03-22-2013, 12:56 PM   #34028
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 706
methinks you're running your chain too tight.
ftfw
IBA #33260
cablebandit is offline   Reply With Quote
Old 03-22-2013, 01:02 PM   #34029
z@ch
z@ch's Avatar
Oddometer: 4,751
Originally Posted by cablebandit View Post
ftfw
wrong.
too tight kills the countershaft seal before you kill the slider.
Old 03-22-2013, 01:23 PM   #34030
shep546
shep546's Avatar
Oddometer: 215
This is where I get confused.. should I removed the electrical connectors? Or just those two wired cables going to the valve? You just leave the cables hanging there? Won't that throw a code?
shep546 is offline   Reply With Quote
Old 03-22-2013, 01:26 PM   #34031
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 90
I'm looking to run my iPhone as a GPS once in a while on my WR, picked up a nice little mouning case, etc. I plan to run an SAE => cigarrette plug from the Battery Tender lead to the front, where I can plug in a phone car charger to keep the phone juiced.
My question is: the phone charger will basically be plugged directly into the battery. Is that OK for the phone? Should I look at putting a fuse in line? Any other issues? I don't want to fry my phone.
ADWrider is offline   Reply With Quote
Old 03-22-2013, 01:28 PM   #34032
UtahFox
UtahFox's Avatar
Oddometer: 446
The cables have to be disconnected one way or the other, but I removed everything so I bought the emulator. It tells the computer that the servo is still there so no codes are thrown. When you install your new muffler w/midpipe, the cables have to get disconnected. But if you want, that's all you have to do. If you want to just tie them up and out of the way of things, go for it and you don't have to buy anything.
Old 03-22-2013, 01:34 PM   #34033
UtahFox
UtahFox's Avatar
Oddometer: 446
I've installed one of these - it's fused so you can plug any usb device in there to charge, I've got a few things.
http://burnsmoto.com/usb-power-socket-weatherproof.php
Old 03-22-2013, 01:51 PM   #34034
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 90
http://www.amazon.com/Battery-Tender...der+081-0069-8
This is what I got. I figured with the cigarette plug I can adapt pretty much anything to it. I have a cigarette to USB adaptor for the phone that I have used in the car plenty. On the surface it seems if it works in the car it should work on the bike. BUT - I'm guessing the car is a bit more 'sophisticated' than just a wire straight off the battery. Maybe some type of fuse and maybe more protection in between?
Old 03-22-2013, 02:00 PM   #34035
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 90
http://www.amazon.com/Waterproof-Mot...pr_product_top
And this is the phone mount I got. Fellow inmate janliness showed me this one and it looks pretty decent. Not sure how it will handle a little abuse but functionally it looks pretty nice so far.
Times are GMT -7.   It's 01:10 AM.
