Old 04-14-2013, 07:03 PM   #34711
riverman
Life is great !
Oddometer: 172
So, what exactly was the problem with part #14? missing? out of alignment?? It is hard to figure out just by looking at the parts diagram.
Rory aka "Riverman"
'11 WR250R
'13 Tiger 800XC
riverman is online now   Reply With Quote
Old 04-14-2013, 07:04 PM   #34712
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by Sewerat View Post
So I have been working on a project new tail light. I wanted something that was clean and functional. I have tried the drc edge, clean yes, functional, no. They are dim at best and have a short lifespan if you do anything other then dry pavement with them. I have done a hack and butcher job of the stock tail light but they don't last well after you loop them out???? So I ordered up a ktm exc light and got out the metal tools, with some sawing, some grinding and some torching and bending this is what I came up with.
Love it, nice work.
UtahFox is offline   Reply With Quote
Old 04-14-2013, 09:07 PM   #34713
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 1,015
Good point ... i'll explain
14 is a rubber grommet and the prong it sits around needs to locate in a notch in the plastic headlight cowl. If it is not located you can adjust the screws (#15) as much as you like but nothing will happen.
To get the cowl off simply undo #19 on each side.
If you find the adjusters aren't working - be careful not to screw out too far or the tabs on the back will drop out and you will curse - then it takes 2 mins to check and see if the light is located correctly.
Reeksy screwed with this post 04-15-2013 at 02:33 AM
Reeksy is offline   Reply With Quote
Old 04-15-2013, 05:18 AM   #34714
Red Sand
Red Sand's Avatar
Oddometer: 297
  • Skid plate
  • Hand guards
  • Fuel tank (4.7)
  • Front sprocket cover & case guard
And I'm just getting started . . . I already have a big bore kit, new bar & bar mount, rear sprocket, engine/FI computer, air filter, slip-on, tires, rack, panniers, and other items in the shopping carts . . . and this is already after spending $1200 on rider gear . . . I think it would have been cheaper to take up crack or something . . . so I wonder, does the spending have a terminus?
J/K, I know when I'm out there and I think "Damn, this is awesome!" that it's worth whatever it takes.
The wife doesn't have quite the same perspective as I do - yet - but I think if she and I are stopped at the top of a beautiful mountain and she gets off of her Honda CRF250, then she'll be hooked also.
She's just not WR material, and that's not a negative for her or the WR.
Ride safe, ride often, enjoy it.
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
I used to remove the rear pegs . . . now I keep them on just in case I find a gorgeous woman with no STD's who needs a ride . . . like that's ever gonna happen
Red Sand is offline   Reply With Quote
Old 04-15-2013, 05:19 AM   #34715
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 382
Also put a set of white LEDs on the bottom of the light to shine onto the plate to keep things all legal like.
And the finished product.
Next is to rework that hideous bar on the saddle bag racks.
Try turning the bar upside down...
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is online now   Reply With Quote
Old 04-15-2013, 06:37 AM   #34716
AdvRich
Parallel Reality
AdvRich's Avatar
Oddometer: 1,721
Originally Posted by manfromthestix View Post
Doug
Nice shot and scenery
"If you do not change direction, you may end up where you are heading." Lao Tzu
AdvRich is offline   Reply With Quote
Old 04-15-2013, 07:50 AM   #34717
Yaozer
Oddometer: 178
Originally Posted by T-horny View Post
12 1/2 inches from the midline center of the foot to the midline center of the bolt. About 13 1/4" from left lateral side of the foot to the top left lateral side of the stand.
Thank you. Someone bumped my bike and bent the kickstand. Then they left the scene.
Trying to find a suitable replacement.
Yaozer is offline   Reply With Quote
Old 04-15-2013, 08:11 AM   #34718
ET-VT
ET-VT's Avatar
Oddometer: 244
Yah. I think it's when you get rid of it and buy the KTM you're trying to turn it into.
ET-VT is offline   Reply With Quote
Old 04-15-2013, 09:49 AM   #34719
BaronVonDarrin
BaronVonDarrin's Avatar
Oddometer: 590
Originally Posted by sieg View Post
If she's tall enough the WRR will be fine. If not the XT250 is a good choice. It is a much better bike than the XT225 or the DR200. My wife has owned all three through the years so I'm familiar with all of them. BTW the DR200 is the most gutless bike she had ever owned, a her old DR125 seemed to have more power. Nice bike other than that.
well I am 6 even and shes shorter than I am so maybe not. Would lowering it with a link help? I believe she is 5'8''.
"Dammit Bobby"
Husqvarna 2011 te630
BaronVonDarrin is offline   Reply With Quote
Old 04-15-2013, 10:01 AM   #34720
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,932
Fork axle pinch bolts...
Just a FYI for you WR owners...
When I had a flat on the front Saturday I had no problems at all loosening the 22 mm axle nut with the box-end wrench supplied in the tool kit, but when I went to loosen the four 10 mm axle pinch bolts, which I'd carefully torqued to the recommended 23 Nm, the cheap open-end wrench in the tool kit bent like it was made of taffy. If my buddy hadn't brought along a pair of vice grips I couldn't have gotten them off.
Today I went down to the local Fastenal store and bought stainless steel hex screws (M8 x 40mm) to replace them and added the appropriate allen wrench to my tool kit. These in stainless were around 90Ę apiece.
GSBS is offline   Reply With Quote
Old 04-15-2013, 10:20 AM   #34721
More CowBell
gotahave moreCowbell
More CowBell's Avatar
Oddometer: 208
WR250R, How tuff is the motor?
Ok, I have had a 08 WR250R for a few weeks now. I have had a lot of bikes in the past. I knew going into this that it didnít have much power. I have 13/45 gearing. The speed-O is way off, like indeacated 80mph is 68mph on the GPS. Is this the norm? The bike has just over 6000 miles on it, probaly more like 5000 or so. So my big Qustion is, can I ride this bike all day at almost full trottle without blowing it up. And how long can I do this till it needs a rebuild? The motor and pipe is all stock. I donít want to spend the money on a pipe and programmer for just a little more power. It dosent seem to me to be worth the money. Tell me what you think.
13 KTM 350EXC, uncorked, race bike with a plate
07 YAMAHA FZ6. would trade for the right KLR650
05 Montesa 4RT. SOLD
More CowBell is offline   Reply With Quote
Old 04-15-2013, 10:36 AM   #34722
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,932
First off... please loose the black typeface. It's a bitch to read what you're writing.
About the motor's longevity... I can only speak for mine, which is almost constantly wrung out on the street when I'm riding. It's at 22K miles now and never used a drop of oil or given me any problems whatsoever.
Mine has had the AIS and EXUP stuff removed, FMF pipe, fuel mixture richened via the onboard computer, air box opened up and K&N air filter. I change oil and filter every 3K miles. I'm running 13/47 gearing, but it's effectively about stock with the larger diameter MT43 DOT trials on the back. I regularly run at 70-75 for an hour or more on the slab when I need to make time.
YRMV.
Old 04-15-2013, 10:37 AM   #34723
dnsjo
dnsjo's Avatar
Oddometer: 27
Finally got done with chores and family duties last night at about 5:30, so took a short 60 mile loop through the Virginia country-side and ended up paralleling the Blue Ridge Parkway above Buena Vista (MM45 on the BRP). Tried to get artistic with a sunset motion shot, damn near crashed, and it's even blurry:
Why didn't you stop and put out that forest fire?
dnsjo is offline   Reply With Quote
Old 04-15-2013, 10:40 AM   #34724
ruppster
ruppster's Avatar
Oddometer: 865
Stock is 13/43 gearing and the speedos are usually 7-8% off, so your figures seem reasonable. Mine is geared at 14/48 and I run at 65-70 mph for long stretches, much more seems to be wringing it.
15 KTM 690E, 05 KTM 450EXC
ruppster is offline   Reply With Quote
Old 04-15-2013, 10:56 AM   #34725
manfromthestix
Lost in Space
manfromthestix's Avatar
Oddometer: 2,196
I didn't even know there was one until someone at work asked if my house was in danger of burning. WTF? OH, no, we're ~20 miles west of that spot. I'm surprised anything would burn as wet as it's been! HEY - maybe I caused it?? I was riding up there, maybe my WR was shooting flames and I didn't know it! I did have it wrung out pretty hard a few times.
Here's some cool video - my son is a pilot and loves stuff like this. I'd agree, the helo pilot was on his game:
http://www.youtube.com/watch?v=aT7Y0Aul_bs
Obviously you've never owned a BMW GS . I'm not done yet and I've owned the bike for YEARS!
Hey, thanks for the tips on headlight adjustment, and thanks for the comment on the photo! It was a beautiful night; now it's raining again. That should help with the fire.
Doug
"If it doesn't blow smoke and make noise, it isn't a sport!" - radio ad for shop in Bozeman, MT
manfromthestix is offline   Reply With Quote
Times are GMT -7.   It's 08:59 PM.
