Old 04-16-2013, 12:32 PM   #34741
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by Rapid Dog View Post
...beauty, eh?
I'm coming over so you can do mine :)
UtahFox is offline   Reply With Quote
Old 04-16-2013, 12:51 PM   #34742
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,661
Thumb
...your bike looks great Utah.
Black is besterestess...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 04-16-2013, 02:34 PM   #34743
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,803
...beauty, eh?
I love engine mods.
Hate gets you nowhere.
Old 04-16-2013, 04:03 PM   #34744
soupknotzee
soupknotzee's Avatar
Oddometer: 246
Rear fender mudflap tag / brake light plate holder assembly needed
Curious if any of you inmates has an OEM take off big ugly rear fender mudflap / license plate holder / taillight / tag light assembly unit (not sure what the actual name is) laying around gathering dust, using up valuable garage space, and that you are sooo ready to kick to the curb for spring cleaning... If so, I am in need and would be more than happy and appreciative to take it off your hands
... Please PM me if you can help
THANKS!
soupknotzee is offline   Reply With Quote
Old 04-16-2013, 04:12 PM   #34745
viper770
viper770's Avatar
Oddometer: 592
if i knew i could get tens of thousands of miles out of a athena i would drop one in my wrr so fast
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 04-16-2013, 07:54 PM   #34746
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,905
Originally Posted by UtahFox View Post
Yeah, it's mounted on the other side of the dash, you can see the ass end of it below the Voyager in the pic above. I'm going to cover that hole at some point. I'm only mounting a small USB port on the dash, so I have plenty of room and its buttoned down pretty good up there.
The day will come when you need to access the OEM head unit to observe error codes and initiate tests.
Looks pretty good though.
Mr. Fisherman is offline   Reply With Quote
Old 04-16-2013, 07:58 PM   #34747
jefmad
Oddometer: 652
The 280 from Thumper Racing appeals to me more but I am right there with you. If I heard from 5 people that had the 280 kit and went 20K miles without problems, I would order it tomorrow.
jefmad screwed with this post 04-17-2013 at 04:11 AM
jefmad is offline   Reply With Quote
Old 04-16-2013, 08:01 PM   #34748
JustKip
JustKip's Avatar
Oddometer: 4,713
...beauty, eh?
Beauty indeed!
At what revs do you notice the increase most? Does it pull harder thru the full range, or run out of steam at the top? Stock FI, air box, and pipe?
This soooo appeals to me!
JustKip is offline   Reply With Quote
Old 04-16-2013, 08:13 PM   #34749
reddirtjoe
motorcycle addict
reddirtjoe's Avatar
Location: Let's Ride some red dirt!!.... NorthCentOklahoma
Oddometer: 2,294
...beauty, eh?
Mine is still in the box,waiting for a clear weekend to get er done!!
I used to be a dumbazz,
then a smartazz
this year,....just an azz
reddirtjoe is offline   Reply With Quote
Old 04-17-2013, 03:52 AM   #34750
Red Sand
Red Sand's Avatar
Oddometer: 300
Originally Posted by ET-VT View Post
Yah. I think it's when you get rid of it and buy the KTM you're trying to turn it into.
I've thought a lot about this comment - thank you.
There will always be room in the garage for another one.
My zeal to pour money into this machine is fading fast. With the new tires, I'll have everything checked off on my "add/replace first" list and so I think I'll just see how far I can go with it "almost stock."
On another note, am I the only one here who's envisioned transforming the extra, ground-level bedroom into a dedicated motorcycle garage complete with wide access door to the back yard?
When I mentioned this to wifey, she stopped what she was doing and expressed a few words of serious concern for my mental health.
Some people just don't get it and . . . hey, that's okay.
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
I used to remove the rear pegs . . . now I keep them on just in case I find a gorgeous woman with no STD's who needs a ride . . . like that's ever gonna happen
Red Sand is offline   Reply With Quote
Old 04-17-2013, 05:31 AM   #34751
ilyaon
Oddometer: 92
Could someone post what is the distance between the pegs and the top of the seat on WR250R?
Thank you.
ilyaon is offline   Reply With Quote
Old 04-17-2013, 07:23 AM   #34752
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,661
Thumb Athena-ism
Originally Posted by JustKip View Post
Beauty indeed!
The kit I bought came with a FI programmer box from Athena. Two choices, I believe it's stock pipe and aftermarket pipe.
My scoot has an opened up airbox and K&N filter. Drilled holes through the airbox door and side panel (see pic).
I have a FMF Powerbomb header and a slightly modified stock muffler.
Basically I just drilled a hole in the baffleplate inside the exit end.
Just remove end cap and drill a 3/4" hole with a hole saw.
Note, I bought a modified stock exhaust that had the cat removed and the bike ran no better, but this was before the Athena install.
Overall the 290 kit has more power across the power band as described.
The mid to top range hit is very noticeable. I'm always surprised and pleased how more quickly it revs.
Downside is, the motor has more vibes felt through the handlebars and pegs, which to me is annoying. I've quelled it pretty well with the combination Progrips and HDB anti-vibe inserts . the FLEXX bars don't hurt either. I've used bar-end weights as well, but the grips and inserts do the trick. (arthritic hands easily go numb!)
The pegs don't bother me.
Only other nit pick is the Athena FI seems to take a few minutes for the bike to warm up and begin fueling correctly. Starts right up but likes to get 'settled'.
I'm going to test the FMF Q4 and controller next for a comparo.
We set up my buddy's stock (except foam airfilter) WR with the FMF exhaust and FI and it ran great!
But still, the WR250X/R pulls away from him...
Old 04-17-2013, 08:17 AM   #34753
dazler
Oddometer: 183
do the highway dirt bikes mirrors only work with their handguards?
dazler is offline   Reply With Quote
Old 04-17-2013, 08:19 AM   #34754
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,661
...pretty much but I'd ask. I believe there's another kind of flip out mirror.
Best option for most that don't want the HDB guards is the Double Take's sold in the Vendors here on ADV.
http://www.advrider.com/forums/showt...hlight=mirrors
Old 04-17-2013, 08:31 AM   #34755
ohgood
ohgood's Avatar
Oddometer: 3,119
Originally Posted by dnsjo View Post
Anyone join the FaceBook WR group?
what for ? the thread is right here, on advrider.
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Times are GMT -7.   It's 04:55 AM.
