Old 04-22-2013, 10:51 AM   #34936
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,910
Originally Posted by KansasBob View Post
Right, and when someone throws a set of R wheels on an X the geometry is not set up for the R wheels.
I'm not saying it can't be dialed in, but right out of the box it may be off a little.
It may be more than wheel size though................... Yamaha calls the X a "street bike" and the R an "adventure dual sport" I would think the specs baked into the X are to make handle best on the street.
Not exactly. I may be wrong, but I believe the frame, forks and shock are the same dimensions on both bikes. The rear wheels are not much different in diameter, but the front wheel on the X is quite a bit smaller. So, everything else being equal, that drops the front end, making the rake steeper and changing the trail. From what I've read the suspension is valved differently on the X, but that shouldn't affect handling too much.
cjbiker is online now   Reply With Quote
Old 04-22-2013, 12:35 PM   #34937
Gryphon12
Gryphon12's Avatar
Oddometer: 1,347
Does anyone actually read this thread before posting???
WR250R Rake/Trail: 26.7 / 4.37"
WR250X Rake/Trail: 25.3 / 2.99" - they are supposed to be different, but only due to wheels - no need to "slide in triples" unless you want 250R geometry off road on a 250X.
WR250R wheel base: 55.9"
WR250X wheel base: 56.1", due to different sprockets ONLY
WR250R GC / Travel f/r: 11.8" / 10.6" / 10.6"
WR250X GC / Travel f/r: 10.4"/ 10.6" / 10.6", due only to wheel diameter and tire profiles.
Suspensions are the SAME including internal valving; initial settings are different.
Transmission gear ratios are IDENTICAL (unlike SMS 630 / TE630).
Forks, frame, and swing arm are identical. Front brake rotors are different, of course.
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is online now   Reply With Quote
Old 04-22-2013, 12:45 PM   #34938
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,910
Of course not
With close to 35,000 posts and the lousy search capabilities available, any info quickly gets buried and lost in this thread.
Old 04-22-2013, 02:02 PM   #34939
KansasBob
KansasBob's Avatar
Oddometer: 515
You learn something new every day!
I always thought the rake and trail was set in the frame jig, but it's actually measured on the bike once it completely set up and built? Interesting.
KansasBob is offline   Reply With Quote
Old 04-22-2013, 02:06 PM   #34940
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
Originally Posted by dirthauler View Post
ok, guys, prepping for spring, i find my bat has got what my smart charger tells me is a sulfated cell. guess it's time for a new one, anyone got a good suggestions on where to get one for the right price?
I'm a big fan of the AGM "motobatt's.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 04-22-2013, 02:54 PM   #34941
Gryphon12
Gryphon12's Avatar
Oddometer: 1,347
I'm not sure I'd go that far. It is designed w/ CADD, hence the triple clamps / steering stem off-set, and the design length from the head to the axle. After that, there are tolerances in mfg and assembly.
Switching front wheels results in the changes seen in the specs - the triples and stem are the same. Of course, we change these numbers every time we lower a bike with links and by sliding the forks. The changes aren't as severe if you modify fork internals, etc.
Gryphon12 screwed with this post 04-22-2013 at 03:03 PM Reason: type-o
Old 04-22-2013, 02:56 PM   #34942
Gryphon12
Gryphon12's Avatar
Oddometer: 1,347
Originally Posted by cjbiker View Post
Of course not
Yeah, the stock search function is poor.
We need to do a better job of teaching other methods, like:
Google search - "search text"/site:advrider.com/forums/..."thread spec"
The information age is teaching a lack of patience. We all want what we want, "right now". Reading through longer threads is very educational, and not just for information on a specific bike. In reading (over several months) this thread, and the huge DR650 thread, and the Super Tenere thread (just those three), I've learned more about old technology, new technology, other bikes, accessories and mods, riding techniques, maintenance, planning for trips, and fixing things in the field, than I have anywhere else in the past 10 years.
Searches and questions are good for immediate issues. Reading, taking notes (I have a computer journal for each of the three threads mentioned above), and taking time to put information from many other contributors into perspective is absolutely invaluable to me. (Besides, it gives me something else to do over the winter than bitch about not being able to ride!)
Gryphon12 screwed with this post 04-22-2013 at 03:07 PM
Old 04-22-2013, 03:13 PM   #34943
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,070
The S-10 thread has interesting info but I unsubscribed because it's basically just a bullshit thread. I belong to enough of those.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 04-22-2013, 03:20 PM   #34944
what broke now
Petroleum Brother
Oddometer: 1,483
Originally Posted by Mr. Fisherman View Post
Oh, I can stack it higher... and I wear a backpack/hydration system too
Wait, doesn't Oregon allow triple trailers? That might be easier.
what broke now is offline   Reply With Quote
Old 04-22-2013, 04:32 PM   #34945
Red Sand
Red Sand's Avatar
Oddometer: 300
Here are some good tips from Google --> LINK
Is there an automated way to consolidate all these posts in this thread into one text file?
If so, that would be very helpful to me.
I began creating my own personal database with useful WR250R information in it.
At the top of the list is this link (HERE)
Then I add stuff that I am likely to reference later or stuff I've already done that isn't in that link - which tires work well, what upgrades are useful and how to install them . . . blah, blah, blah . . .
~ ~ ~ ~ ~ 2014 Triumph Scrambler ~ ~ ~ ~ ~
I used to remove the rear pegs . . . now I keep them on just in case I find a gorgeous woman with no STD's who needs a ride . . . like that's ever gonna happen
Red Sand is offline   Reply With Quote
Old 04-22-2013, 05:36 PM   #34946
ba_
ba_'s Avatar
Oddometer: 2,827
short video from this weekend
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
FS: DID Chain & front/rear JT sprockets WR250R
ba_ is online now   Reply With Quote
Old 04-22-2013, 06:24 PM   #34947
scottmac
scottmac's Avatar
Oddometer: 1,979
From the ADV WARPed rally last weekend...
scottmac is offline   Reply With Quote
Old 04-22-2013, 09:02 PM   #34948
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 5,004
Sprockets change the wheelbase measurement?
Isn't wheelbase measured from the center of the hubs?
Currently in learning mode as I picked up a practically new '12 R this past Friday. Had it in the bed of the truck the entire CoTA MotoGP weekend.
Hope there's room for one more inmate on this thread.
I'm going to use it to fart around dirt and gravel roads around here, basically motorized hiking. My GS is too much of a pig and my skill level low. The KLR is ok but I wanted something lighter. We'll see how this goes. Was going to dual sport the KDX but I think this WRR will fit the bill.
I do need to figure out the wheel thing as I want to swap SM and DS wheels quickly. Am thinking of having SM wheels laced to WRR hubs.
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 04-22-2013, 09:06 PM   #34949
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,752
And now for something completely different.
http://advrider.com/forums/showpost....postcount=3256
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 04-22-2013, 10:53 PM   #34950
Gryphon12
Gryphon12's Avatar
Oddometer: 1,347
Yep. Use a bigger rear sprocket and the same length chain and the center-to-center hub distance will change slightly. A bigger sprocket will force the rear hub very slightly forward with the same length chain. Two-tenths of an inch isn't much - it's the same swing arm, but different rear sprocket.
Times are GMT -7.   It's 05:44 PM.
