Old 04-26-2013, 06:03 PM   #35056
jkstehn
Oddometer: 115
Originally Posted by bogboy View Post
Now that the weather is good , I've been out having a blast. A couple of times I've winded the engine out. I only have 2500 miles and wanted to start checking out peak power. I noticed when its probably near redline it acts a bit weird like there is some kind of governor in the software to lower throttle response like an engine brake or something. It feels like fuel is being cut back. It seems to kick on right away. Very strange.
Anyone ever notice this?
It is an electronic rev limiter. Just have to learn the sound of being almost to that RPM
Sent from my SCH-I605 using Tapatalk 2
Jon
WR 250 R
jkstehn is offline   Reply With Quote
Old 04-26-2013, 06:54 PM   #35057
Bogus Jim
Oddometer: 110
Originally Posted by WeazyBuddha View Post
Re: cam chain tensioner, what was the way that worked?
I used indypup's method - long screwdriver. Don't insert the screwdriver into the engine too far; that will reduce your leverage. Just put the blade near the top of the chain guide and push it towards the rear of the engine, the tensioner should pop right out.
For locking the tensioner plunger into the body, I used a method I haven't read about before... find a bar stool with a hard seat, place an inner tube on top (for grip), hold the tensioner with one hand and press the plunger end into the inner tube with about 15 lbs. of force, walk in a circle around the stool about 3 times, then use your free hand to set the circlip. Presto, tensioner is locked and loaded. No vice or clamps necessary.
One other tip (sorry if this is obvious). If you don't want to buy an expensive valve shim kit, or you don't want to pay 6 bucks a pop for OEM shims, you can order Pro X shims from Rocky Mountain ATV for $1.49. Order the WRF shims, they don't stock "WRR valve shims" even though they're the same size. Even better, the Pro X shims come in 0.025 mm increments so it's easier to get the valve clearances where you want them. Most shims are sold only in 0.05 mm increments.
The downside is, if you only need 1 valve shim, you'll have to add $98.51 to your order to get free shipping.
2012 800 XC
2009 WR250R
2008 250 XC-W
Bogus Jim is offline   Reply With Quote
Old 04-26-2013, 07:29 PM   #35058
bogboy
bogboy's Avatar
Oddometer: 58
[QUOTE=jkstehn;21276771]It is an electronic rev limiter. Just have to learn the sound of being almost to that RPM
Ahh, Got it. I was hoping something like that. Love this bike
Thanks Jon
bogboy is offline   Reply With Quote
Old 04-27-2013, 06:20 AM   #35059
Rider_WV
Rider_WV's Avatar
Oddometer: 2,376
Originally Posted by DNF View Post
Rim locks yes or no?
About to replace stock tires with some Mitos.
20 % street
70% fireroad/trail
10% single/gnarly
Kootenays so 20% mud, almost no sand.
Motion pro lite locks are the ticket
Rider_WV is offline   Reply With Quote
Old 04-27-2013, 11:25 AM   #35060
yaw
lost
yaw's Avatar
Oddometer: 76
Starter dampener
Bogus Jim! Thanks for the feedback. I love the photo of your engine on the dining room table. A man that knows how to live! I will be diving further into my engine soon. Need some wheels! The r2 is currently my only mode of transportation besides my bicycle. Will update when I find the source of the noise. Marc
10 ktm 530 exc
08 yamaha wr250x
07 ktm 990s sold
67 bmw r69s sold
yaw is offline   Reply With Quote
Old 04-27-2013, 12:18 PM   #35061
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,975
Originally Posted by rider_wv View Post
motion pro lite locks are the ticket
+1
GSBS is offline   Reply With Quote
Old 04-27-2013, 12:19 PM   #35062
Paebr332
Oddometer: 1,167
Originally Posted by indypup View Post
lol, where did you find that graphic? I do a lot of night riding and that think is pretty sweet. No need for helmet lights with that thing...
What light array is that?
Paebr332 is offline   Reply With Quote
Old 04-27-2013, 02:08 PM   #35063
ecarnell
ecarnell's Avatar
Oddometer: 394
X2??? Interesting to see some front pics!
2014 KTM 500 EXC
2011 KLR
2012 Dacre Challenge -Team Explore the Bruce - 8th (i.e last) Place. 17:59
ecarnell is offline   Reply With Quote
Old 04-27-2013, 02:53 PM   #35064
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,371
Originally Posted by CJ smith View Post
Replacing means $300 for inner tube,+seal rebuild kit & oil+specialty tools. If anyone comes across a used fork for the wr250r please let me know. Until then I'll try sanding & filling in with epoxy.
What are the odds of something like this buffing out with emery cloth/fine sand paper? The right fork just started showing signs of fork oil residue rings, its not a fast leak but in time im sure this gouge will take a toll on the seal.
[IMG][/IMG]
I've seen it done on logging hyd. cylinders and it's worth a shot....
It's not a cure but more of a band-aid...
Sand it down with water and light sand paper to get the burs off. Clean it very well with carb cleaner. Fill in deep scratches with JB Weld. Sand down agian with fine sand paper.
Kinda like Bondo on a car fender.
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 04-27-2013, 03:42 PM   #35065
sieg
sieg's Avatar
Oddometer: 2,867
How did you do that? I've had upside down forks on my dirt bikes since they were invented (yes I'm that old) and ain't never done no shit like that. All in all $300 ain't bad to fix that. For what you'll pay for a used one, or a set, you might as well bite the bullet and get new stuff. Good luck, let us know if it works. I've filled stuff like that on hydraulic cylinders with silver solder, and re-chromed them. BTW
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 04-27-2013, 03:50 PM   #35066
shep546
shep546's Avatar
Oddometer: 215
Easy to do if you ride hard, my forks are scuffed a bit but not gouged and pitted like that. All it takes is a low side onto big rocks to do some serious damage.
shep546 is offline   Reply With Quote
Old 04-27-2013, 03:58 PM   #35067
sieg
sieg's Avatar
Oddometer: 2,867
Hmmmm.... By your description it doesn't seem to be the hard riding but the low siding that causes the problems.
Old 04-27-2013, 04:11 PM   #35068
shep546
shep546's Avatar
Oddometer: 215
If you ride hard enduro crashing is inevitable. Most people in this thread use their wrr's to just cruise around dirt roads and that is 100% fine but if you are riding fast over very rough terrain anybody can and will fall, even the pros...
Old 04-27-2013, 04:18 PM   #35069
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,797
This is a legit repair method and will hold up for a long time. The whole tube can even be ground and replated after it gets too beat up.
Hate gets you nowhere.
Old 04-27-2013, 04:38 PM   #35070
Bogus Jim
Oddometer: 110
fork damage
You mean rocks like this?
2012 800 XC
2009 WR250R
2008 250 XC-W
Times are GMT -7.   It's 02:20 AM.
