Old 04-28-2013, 06:21 PM   #35101
AZ TOM
Oddometer: 3,934
Originally Posted by 10Cup View Post
Tom, I have the stand (#17 on fich) and Bracket (#24 on fich) You welcome to them, both brand new. I don't have any of the bolts or springs. Sell them too you for what I paid plus shipping.
Let me know if that helps. Stand is $39.27 and bracket is $46.14
Thanks so much. Will let you know. Looking at one on E-bay but the guys feedback is suspect!
AZ TOM is offline   Reply With Quote
Old 04-29-2013, 02:42 AM   #35102
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,186
Originally Posted by Red Sand View Post
With only 666 miles on my WR250R (hahahaha - no kidding) my front sprocket cover (?) had a fairly significant layer of muck inside it.
Made me glad I got this setup:
I just drilled holes in the standard one
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is online now   Reply With Quote
Old 04-29-2013, 03:55 AM   #35103
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,106
Originally Posted by Jonathan75 View Post
Wonder what kinda power the 250r is capable of with big bore kit exhaust and any and all mods available? I rode that bike today at full throttle and got it to 71.
Originally Posted by viper770 View Post
mine is fully moded and i got 97.1 mph out of mine but mine is just a 250 not a 290
but back when it was stock i was still hitting 90 mph
FWIW it would take aprox 2X the HP to turn top speed from 71 mph to 97 with all other conditions being the same.
I used to ride freeway from Riverside to Anaheim hills with a mate where the flow of traffic was usually about 80mph. I was on a KTM690 and my mate on a pretty stock WR250R. Riding with him, his "real speed" would fluctuate between 70 & 80 ish with the throttle permanently pegged. His speedo was quite optimistic ("Hmmm... Why are all those cars flying by when I'm doing 85 mph!")
When a small bike is geared tall what it potentially can do is a pretty big difference from what it consistanly can easily hit.
1 more vote for the WR450R!!
rickypanecatyl is offline   Reply With Quote
Old 04-29-2013, 10:19 AM   #35104
shep546
shep546's Avatar
Oddometer: 215
In the spring I put new tires on my bike and had to adjust the chain tension once the wheels were back on... I set the chain tension within specs even though it feels a bit on the tight side.
I just noticed today I am eating into the rubber guard on the swing arm.
Should I just tighten it up more?
shep546 is offline   Reply With Quote
Old 04-29-2013, 10:28 AM   #35105
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,025
Make it a tad looser, not tighter. IMO.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 04-29-2013, 10:33 AM   #35106
shep546
shep546's Avatar
Oddometer: 215
I'm not really familiar with this issue... I assume'd it was during low strain the chain would glide along it because it was too loose but I could be out to lunch on these theory... so I should loosen it up?
Old 04-29-2013, 10:35 AM   #35107
larryk
Oddometer: 31
Renfro Dual Sport
Originally Posted by indypup View Post
I've had it for about a year now. I usually just swap it in when I need it. I just recently started leaving it on because of putting the spare tube pack on front fender and having it cover stock light. Yesterday I rode some stuff that had lots of waterbars and was catching some air big time. I washed out the front end and when down too. (video)
I plan on riding some really rough stuff this weekend down in Kentucky at the Renfro Valley DS so I'll have to report back on how it holds up.
Indypup, I'll look for you at Renfro and say hey. I'm coming up from Atlanta with a friend.
larryk is offline   Reply With Quote
Old 04-29-2013, 10:40 AM   #35108
larryk
Oddometer: 31
New fuel pump p/n
Originally Posted by Bogus Jim View Post
Has anyone noticed the 2013 WRR's have a different part number on the fuel pump? Yamaha has also updated the part # when you order a pump for 2008-2012. 3D7-13907-10-00 new vs. 3D7-13907-00-00 old.
I wonder if this means the pump has been improved.
FWIW
The sticker on the box of the one I just bought has the new p/n you mention (minus the -00 on the end)
Old 04-29-2013, 10:46 AM   #35109
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,025
There are a couple theories as to what causes the chain guide excessive wear, but too tight was high the potentials. Yamaha even changed the spec at one point, making it wider. Due to the swing arm pivot and countershaft sprocket not being on the same plane, a tight chain gets tighter when the swingarm moves through its range of motion...has no choice but to wear through the guide. Sticking links were also a potential culprit.
Old 04-29-2013, 10:52 AM   #35110
larryk
Oddometer: 31
Just spooned on a pair of Motoz
Originally Posted by BlueLghtning View Post
I was wondering if anyone had run the Motoz Tractionator Tires. - http://www.phatperformanceparts.com/...s_s/585480.htm
They have the Desert H/T DOT tires and the Enduro I/T DOT tires. The Enduro seem to be a good setup for all around terrain. If you are in the desert or frequently ride on dry terrain, the Desert looks mean! They come in a little cheaper than the D606's.
The Husky guys love these tires. I've seen a few mentions when I searched for WR250R, but no true reports. A lot of reports I'm digging up too are on the non DOT tires which I think is all they sold a couple years ago. The DOT series seems to be a bit on the newer side?
Motoz Tractionator Desert H/T DOT Tires - http://www.phatperformanceparts.com/...tracht-dot.htm
Motoz Tractionator Enduro I/T DOT Tires - http://www.phatperformanceparts.com/...duroit-dot.htm
Blue, gonna torture test em' this weekend at Renfro. I'll let you know how they do. I've got a desert H/T on rear and enduro I/T on front
Old 04-29-2013, 11:27 AM   #35111
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,737
I though Yamaha REDUCED the chain slack measurement to counteract the chain slipping on the OEM rear sprocket.
running too loose is just as risky as too tight. A bigger rear sprocket helps the most, IMO.
z@ch is offline   Reply With Quote
Old 04-29-2013, 12:14 PM   #35112
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,025
You could be right..might be tighter. I never had a huge issue with my chain guide, so I never paid too close attention to what all the posting was about. Generally, on any bike, a looser chain is better than one that is too tight. One that is too tight will not allow the rear suspension to work the way it should, and will probably eat the guide as well.
Shep, as awful is it may be to find, you may have to search through this thread to get the right answer.
Old 04-29-2013, 02:49 PM   #35113
what broke now
Petroleum Brother
Oddometer: 1,379
Also, don't neglect setting sag. This multiplies the wear if you are riding too low in the shock stroke. EG, sag set for rider only, then you put 40# of tripgear on the back and don't compensate on the preload.
what broke now is offline   Reply With Quote
Old 04-29-2013, 02:52 PM   #35114
Subaru297
Oddometer: 116
Pull the bolt out of the bottom of the shock and run the swingarm up through its complete range of motion. You will easily be able to tell where the chain is at its tightest point. Leave it a little loose at that point and you shouldn't have any problems.
This works on any bike with any gearing and hardly takes any longer than measuring chain slack.
I think the slider being eaten is from chains that are too tight as well. I have run mine too loose with stiff links and my slider is still fine.
Subaru297 is offline   Reply With Quote
Old 04-29-2013, 02:53 PM   #35115
Subaru297
Oddometer: 116
This is true too. Many of the reports of chain slider wear are from people on the road loaded up with gear that have never had the problem before. They probably had an in spec or slightly tight chain to begin with and then loaded their bikes up and.......
Times are GMT -7.   It's 09:56 PM.
