Old 05-05-2013, 08:43 PM   #35296
Rubbernecker
Oddometer: 136
The guys wants 3200 obo so your numbers seem right.! Any difference with later models?
Rubbernecker is offline   Reply With Quote
Old 05-05-2013, 08:51 PM   #35297
TexaNate
TexaNate's Avatar
Oddometer: 405
Mainly cosmetic - anodized fork tubes, new graphics. Some tiny parts changed part numbers (e.g. oil filter), mainly just to give forum members something to talk about. Nothing major.
$3,200 sounds about right for the bike you describe. At 10k miles, you're not even halfway to your first valve clearance check. See if it needs a new chain or new tires - if so, get the seller to knock a hundred bucks off the price. As long as the motorcycle hasn't been abused, change the oil and clean the air filter regularly and you're good for another 10k miles, easy peasy.
2014 690 Enduro R
TexaNate is offline   Reply With Quote
Old 05-05-2013, 09:14 PM   #35298
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,999
The remarks about bounciness are prescient.
I'm clueless about noticing things but the forks did seem stiff. Could some of it be the forks requiring regular air bleeding?
On another subject, I mounted the Zumo 550 and noticed the following speedo deviation
Indicated: 45 GPS: 40
Indicated: 56 GPS: 50
Indicated: 66 GPS: 60
Tried to get it to "true" 70, had the throttle pegged and managed only 68 before my turnoff came up. Seemed interesting to peg the throttle and not be getting a whole lot on the top end
I bought the WR for puttering and exploring what few dirt roads there are around here. Around town, it's a zippy little bike.
It ain't no VFR or GS but I love this little blue demon and can see how it could be setup for adventure travel on back roads with even some highway thrown in.
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 05-06-2013, 12:40 AM   #35299
BluePill
AARP Slacker
BluePill's Avatar
Oddometer: 4,993
Originally Posted by DefyInertia View Post
Yeah I'm going to get the suspension done. With 17s on a goaty back road I bounce all over at pace. On the dirt I bounce off things.
Set the rear rebound to maximum (3 clicks out from full clockwise) to kill some of the pogo effect.
In other news, for breakfast this morning we had two WRRs over easy...............
Went out with a first timer (to D/S) who just picked up a well-beaten 2008 WR250R. He said "Show me some of those tricky single track areas" and I said "Follow my line and do exactly what I do". Silly guy did just that. It's an old guy thing - we like to stop in the middle of hills and grab a little nap.
The next lesson I taught him was "Do not cross fallen trees at an angle - always try to hit them at a 90 degree angle with a bit of throttle to lighten the front wheel". I guess that after the earlier lesson, he felt free to ignore that advice. He did a ricochet off a log and went into the brush at the side of the trail, with some minor damage to the plastics. His comment "I love this shit".
I think we have him hooked.
2008 WR250R - Tru Blu
"While we live, let's live"
BluePill is offline   Reply With Quote
Old 05-06-2013, 04:28 AM   #35300
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by jon_l View Post
I recently put Tusk 1-1/4" risers on, no problem with cable lengths. $20 / pair from Rocky Mtn Superstore.
Awesome, and at $20 bux its sure worth a try.
UtahFox is offline   Reply With Quote
Old 05-06-2013, 04:37 AM   #35301
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,972
My only caution would be that some 2008 models had premature fuel pump failures. My 2010 has over 22K and I've never had a mechanical issue with the bike.
A new fuel pump is in the $200-250 range so it might be a price negotiating point for you.
Good Luck!
GSBS is offline   Reply With Quote
Old 05-06-2013, 06:17 AM   #35302
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,360
Rear suspension: Set rebound damping to max, setting per manual. If its still too bouncy, send out shock to get rebuilt by a professional shop, like GoRace, or WER here in NJ.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 05-06-2013, 07:40 AM   #35303
AZ TOM
Oddometer: 4,149
Set the right amount of sag also, for my 185 lbs 4 in or more. May not need full on rebound damp. Keep balanced & rear wheel on the ground.
AZ TOM is offline   Reply With Quote
Old 05-06-2013, 07:47 AM   #35304
Rider_WV
Rider_WV's Avatar
Oddometer: 2,415
even with sag set the rebound needs to be set at max, these suckers are WAYYYY under dampened on the rebound side. Turns into a pogo stick quite rapidly offroad. IMHO the rear shock is the biggest downfall on these bikes. If I end up keeping mine I have to send the shock out for work.
Rider_WV is offline   Reply With Quote
Old 05-06-2013, 08:00 AM   #35305
johnlt
Oddometer: 591
Air intake
I opened up the airbox under the seat and noticed a real improvement but the induction noise was unacceptable. I fabricated a rear facing snorkel out of aluminum star plate after making a cardboard model then lined the inside with foam and wa-la still had the improvement but much quieter. It has about double the area of the OEM air intake.
Johnlt
2009 BMW R1200 GS Adventure
2000 Suzuki DR200
1975 BMW R75/6
Yamaha WR250R
johnlt is offline   Reply With Quote
Old 05-06-2013, 08:30 AM   #35306
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,390
I did the ultimate air box mod and it kept the factory plastic
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 05-06-2013, 10:03 AM   #35307
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,068
Good Luck!
If it hasn't died at 10k it probably won't.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 05-06-2013, 11:07 AM   #35308
AZ TOM
Oddometer: 4,149
To each his own. Mine works well enough for my 72 year old fat but! Sag at 4 1/4 & rebound all the way off, counter clockwise
http://s43.photobucket.com/user/rtb1...601fe.mp4.html
http://s43.photobucket.com/user/rtb1...12003.mp4.html
http://s43.photobucket.com/user/rtb1...T0005.mp4.html
http://s43.photobucket.com/user/rtb1...T0004.mp4.html
AZ TOM screwed with this post 05-06-2013 at 11:36 AM
Old 05-06-2013, 12:23 PM   #35309
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,360
Since I am at work, I only watched a little bit of the first linked vid. That small rocky bumpy terrain would not require the shock rebound set all the way out , nor a rebuild.
The people that need the rebound set at max and/or rear shock rebuilds, are the guys that ride in a such a way, that the rear shock gets fully compressed, either with small jumps and/or whoops. When the stock shock gets fully compressed, the rebound damping needs to be increased...dramatically.
Edit: The guys that have their bikes bouncing them in different directions from the way that they are trying to get the bike to go, know if they need the rear shock redone or not. I would not advise anyone who does not know what pogo'ing is, or if their bike is doing it, to have the shock rebuilt.
Old 05-06-2013, 12:29 PM   #35310
AZ TOM
Oddometer: 4,149
So little time, so many experts
Times are GMT -7.   It's 02:20 AM.
