Old 05-14-2013, 08:26 AM   #35476
rdouthit
Oddometer: 30
Originally Posted by rydnseek View Post
+1 on the motion pros.. i also have 3.. the front axle nut, the rear, & the 10/12 combo. i've only used them a couple of times, but it's nice to have them when needed.
I've used water for bead setting, when changing tires on the trail.. just splash some on.
Here's another pro for the shinko 244's that some of the x guys use:
they ride flat. You can have NO air in the tires, & they will stay full & rideable. They have very stiff sidewalls, & if you ride offroad in them, you don't need over 10#. I pump them up with 32# for long pavement rides, but let it out on trails. I never worry about flats, now.. i'll just wait until i get home to fix it. It's like being born well hung or rich, except you can buy them!
I take it that you use rim locks?
rdouthit is offline   Reply With Quote
Old 05-14-2013, 09:02 AM   #35477
UtahFox
UtahFox's Avatar
Oddometer: 446
Counter Sprocket Bolt Remove/Reinstall.
I did some searches both here and using teh Google, but didn't come up with what I wanted, so I apologize in advance if this has been discussed.
I went to remove this nut yesterday, had it in first gear and turned the wrench counter-clockwise, it turned but it felt as if the gear slipped rather than me loosening anything. I looked at the nut and it appears to have a built in cotter pin or circlip type dealio on there. I decided to leave it be until I understand this, can anyone enlighten me? Maybe a link that explains it?
Thanks.
UtahFox is offline   Reply With Quote
Old 05-14-2013, 09:13 AM   #35478
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,361
Thanks.
I assume you mean countershaft "nut"???To remove front sprocket??
No, cotter pin or circlip..the nut is "peened" in one spot, where there is no threads. You have to bend out this peended spot, and the nut should come off with a breaker bar.
Some guys have just used an impact gun to remove the nut, although I would not recommend this to anyone, since thread damage could occur.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 05-14-2013, 09:17 AM   #35479
UtahFox
UtahFox's Avatar
Oddometer: 446
Yep, counter shaft nut & front sprocket. Would it be better to have it in 6th vs. 1st gear?
Rear wasn't a problem, looks really purdy-like too...
Old 05-14-2013, 09:21 AM   #35480
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,361
IIRC, I had mine in first, stood on rear brake on right side of bike, leaned over and used breaker bar to break it free.
Old 05-14-2013, 09:21 AM   #35481
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,911
Thanks.
Type "wr250r front sprocket removal" into Google and the first link that comes up is a YouTube video showing how to remove and replace the front sprocket. Watch that and go and do likewise.
Or if you want to skip the first step, just watch here:
cjbiker is offline   Reply With Quote
Old 05-14-2013, 09:22 AM   #35482
UtahFox
UtahFox's Avatar
Oddometer: 446
Ahh, OK - the brake. Thanks Doug!
Old 05-14-2013, 09:24 AM   #35483
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,361
hmmm. mine was only peened on one side. ( 2010)
No problem.
Old 05-14-2013, 09:24 AM   #35484
UtahFox
UtahFox's Avatar
Oddometer: 446
My search was something like, remove counter sprocket bolt wr250r - thanks for the video!
Old 05-14-2013, 09:27 AM   #35485
AZ TOM
Oddometer: 4,155
WR 250F counter shaft sprocket, same sprocket.
AZ TOM is offline   Reply With Quote
Old 05-14-2013, 09:29 AM   #35486
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,661
....what size rear tire is that Utah?...muna try me one o them trals tars next go'round.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 05-14-2013, 09:33 AM   #35487
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,361
shows right on it....4.00 X 18.
Old 05-14-2013, 09:34 AM   #35488
UtahFox
UtahFox's Avatar
Oddometer: 446
I bought new rubber all round. The rear is 4.00x18 Pirelli MT43 Trials Tire 1347120002(RockyMTNAtv part #), and the front is a 90/90x21 Pirelli MT21 Dual Sport Rallycross - 1035780001.
Old 05-14-2013, 10:04 AM   #35489
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,661
...that 4:00 looks FAT...and I don't mean like SIC.
Got any idea how tall it measures up against the stock rear tire?
Old 05-14-2013, 10:07 AM   #35490
UtahFox
UtahFox's Avatar
Oddometer: 446
Not really, I'm just following in the footsteps of others like Ramz - http://www.rickramsey.net/WR250Rmods.htm#tires
It was also discussed a few days back, here - maybe on May 6th as that's when I did all my ordering. It's tall enough to warrant gear changes, so I'm doing that too.
Times are GMT -7.   It's 12:50 AM.
