Old 05-15-2013, 01:03 PM   #35536
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,661
...I've never had one fall off.
What me worry?
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 05-15-2013, 04:15 PM   #35537
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by Revvy View Post
Please do get a pic. I'd really like to make this fit better. I'll look into adding a spacer tonight when I get home.
If you still need them, this is the rail I've been referring to...
...and a closeup that you can just see the washer that stands the rail just high enough to slip the plastic on...
UtahFox is offline   Reply With Quote
Old 05-15-2013, 05:20 PM   #35538
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by cjbiker View Post
Type "wr250r front sprocket removal" into Google and the first link that comes up is a YouTube video showing how to remove and replace the front sprocket. Watch that and go and do likewise.
So I'm having a bitch of a time getting that nut off. You're supposed to bend up those tabs, and I'm not even getting close. In fact, I think I'm just mashing it in even more. Any advice? Should I just forget about the tabs and go nuts?
Old 05-15-2013, 05:21 PM   #35539
KansasBob
KansasBob's Avatar
Oddometer: 515
I posted this on the wr forum, but I'm looking for more photos concerning my fit issue with the IMS 3 gallon tank. Does everyone else's look like mine in this regard? My front black panel and side blue panel on the clutch side have a rather large gap that seems to me will be a huge mud collector. If your tank fits better than this, can you with post or pm me a picture so I can send it to IMS?
Just for clarification: I have made sure that the side clips are in place and slotted into the panel; I've made sure the front and rear brackets are in the correct position; I've made sure that the rubber pad under the tank is sitting correctly; I have not put the heat tape on the new tank; the panels align perfectly with the stock tank.
Mine....................
KansasBob is offline   Reply With Quote
Old 05-15-2013, 05:54 PM   #35540
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,910
I haven't removed my WR's front sprocket yet, but those peened nuts are used on lots of import car axles, and for those, I just pry the peened part out as best I can and then undo the nut. I think I read that you took the chain off. You'll never get the nut off without the chain and rear wheel in place. You'll need to put the bike in neutral and have a helper stand on the rear brake while you break the nut loose with a breaker bar or impact gun.
cjbiker is online now   Reply With Quote
Old 05-15-2013, 05:56 PM   #35541
UtahFox
UtahFox's Avatar
Oddometer: 446
The chain is on, think I need to get a breaker bar then.
Old 05-15-2013, 05:56 PM   #35542
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,070
Don't try to unbend it, just put a 27mm socket on there and unscrew it, the tab will pop out under the pressure of being unscrewed.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 05-15-2013, 05:57 PM   #35543
UtahFox
UtahFox's Avatar
Oddometer: 446
Cool, thanks.
Old 05-15-2013, 06:28 PM   #35544
rhollamby
Oddometer: 338
New Mt43's, tubes, chain and sprockets
Hey guys and gals,
Long time reader, finally settled into a wr250r from the sport bike world. Have ATv background and love the dirt.
Decided to go with the mt43's front and back. Already have rim locks and going to order heavy tubs (maybe ultra heavy, haven't decided that yet). To help with gearing going to a 13 49 set up and buying a 14 also. 14 for the long hauls and 13 for the mountains here in Colorado. 13 49 with the mt43s should be ~13 47 with stock tires and then the 14 front will put me at 13 43 stock.... At least this is the idea, please correct me if I am wrong
Question I have is will a 112 link chain work with this set up? Any problems anyone see with this plan?
rhollamby is offline   Reply With Quote
Old 05-15-2013, 07:06 PM   #35545
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 1,117
Cool, thanks.
A screwdriver - just bend the tab back. It's the easiest thing you've never done
Reeksy is offline   Reply With Quote
Old 05-15-2013, 07:14 PM   #35546
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,390
You might be too long with a 112? I running 14/50 & 13/50 with 112. Gonna try 47&48/13 soon
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 05-15-2013, 07:23 PM   #35547
rhollamby
Oddometer: 338
Where is your axle adjustment block sitting, towards the end or in the middle? Reason I ask is because I know the mt43 is a fat tire and shooting to have it set farther back to the rear of the adjustment for more clearance on the mud guard. Thanks
Old 05-15-2013, 09:13 PM   #35548
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,390
I running it tight to the front with 14/50 and now with 13/50 it's about 3-4 notches in. I'm running with a wide tire and no clearance issues
1999 Buell X1
2008 Husky TC510
Old 05-16-2013, 07:47 AM   #35549
soupknotzee
soupknotzee's Avatar
Oddometer: 246
Height of the tire is the concern. 112 is what you need with the TALL MT43 so it can be farther back on the swing arm or it WILL rub the front mudflap. Width is not an issue here as this is a narrower tire.
I run 13/47 112 and have been on many of the steep stuff I ride my KTM300 on in CO at 13,000'+ and it can run out of steam with this gearing/elevation. Other than steep rocky climbs or technical single track 13/47 is pretty good all around. But if I had to fine tune it I would give 13/48 a go or the equivalent with a 14 tooth front.
soupknotzee is offline   Reply With Quote
Old 05-16-2013, 07:51 AM   #35550
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,661
Measured the MT43 on my friends trials bike yesterday (400x18).
70cm or 27.5 inches tall.
Anyone know the height of the stock tire?
Times are GMT -7.   It's 03:24 PM.
