Old 05-22-2013, 05:49 PM   #35686
jon_l
jon_l's Avatar
Oddometer: 3,041
Originally Posted by BluePill View Post
Speaking of sticky levers......................
Many moons ago, before they had little booties to cover the clutch adjuster and cable at the handlebars, I lubed the cable regularly. With the nice, tight fitting boot on the WR, I didn't think it was necessary..................
WRONG!!!
It started sticking, and failed within 10 miles.
You have now been officially warned.
I thought most newer bikes had self-lubricating cables with (silicone?) liners that can be harmed by spraying lube into them, in the old-fashioned way. I have a little tool for exposing the cable and a can of cable lube, but don't use it much lately.
CBF1000
jon_l is offline   Reply With Quote
Old 05-22-2013, 05:49 PM   #35687
viper770
viper770's Avatar
Oddometer: 575
pure sex well i dont know about that only if it was dripping wet then it be pure sex
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 05-22-2013, 07:14 PM   #35688
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 982
I'm fortunate to live very close to an auto cable manufacturer. He'll make me any type of cable I like and indeed he told me to never lube his cables as they don't need it.
Reeksy is offline   Reply With Quote
Old 05-22-2013, 07:35 PM   #35689
sieg
sieg's Avatar
Oddometer: 2,798
Although the cable and sheath don't need to be lubed on modern cables, the pivot point at the lever/cable connection does. I could be wrong, (I was once before) but when cables fail on the end like BluePill's did, it is caused from the cable not pivoting smoothly in the lever hole, thus bending the cable back and forth. When cables do this they rarely give warning or work hard. They just fatigue and break. A drop of oil or chain lube on the pivot every time you lube the chain will prevent this from happening. IMHO
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 05-22-2013, 08:18 PM   #35690
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,187
I got a D606 rear in the mail today to replace the stock Trailwing. Is there any reason I can't swap this out myself? I see this as a dry run for fixing a flat.
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is online now   Reply With Quote
Old 05-22-2013, 08:43 PM   #35691
mpatch
Oddometer: 904
Easier to learn how to do it when you're at home and aren't rushed vs being on the road/trail. The first half dozen or so times will take a bit but once you develop a technique it is fast and easy to change a tire.
mpatch is offline   Reply With Quote
Old 05-22-2013, 09:03 PM   #35692
Reeksy
Reeksy's Avatar
Oddometer: 982
IIRC Yamaha specify lithium grease on the pivot point (and pegs, sidestand, etc)
Old 05-22-2013, 10:47 PM   #35693
MingRidesBikes
MingRidesBikes's Avatar
Oddometer: 206
That is pure sex. I love the black WRX frame with the blue chain and the crash bungs thru the skid plate!
Thanks for the complement! Those holes were a pain in the ass to cut! hahaha, but yes I wanted to keep the frame sliders as well as have a skid plate.
MingRidesBikes is offline   Reply With Quote
Old 05-22-2013, 11:18 PM   #35694
rhollamby
Oddometer: 323
I'm about to do this for the first time. Lots of good videos on youtube to check out on changing the tire/tube. Not to bad with the right spoons.
Does anyone have pointers on balancing the tire without a machine? I have rim locks, and going on mt-43's. with the locks I know I will need weight. Most all of the advice/videos show using static balancer stands (which I don't have).
A bunch of ppl mention to set the heavy spot of the tire to a specific place. I don't see where this place is marked on the tire. tips?
Ryan
rhollamby is offline   Reply With Quote
Old 05-23-2013, 12:14 AM   #35695
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,133
Ryan
I recently put on a 606 for the first time and it was a real PITA. Not sure if it was the tire or that bike (KTM 450 EXC). Never had problems putting other tires (Kenda/Shinko) on the WR. Warming up the tire in the sun or next to some heat sure helps. Keep the opposite bead in the groove is a must. Good skill to have.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 05-23-2013, 07:39 AM   #35696
rsteiger
Bob
rsteiger's Avatar
Oddometer: 204
My experience with the D606 is that it is one of the tougher tires to mount but once it is on it is one of the better DOT tires for Dual Sport riding especially if you are spending most of the time off road.
Check out some of the YouTube videos and take your time. Tire lube or soapy water is a plus and will make mounting that tire so much easier. If you get to the point that you think you are going to bend a spoon or rim take a step back, have a beer, and reassess what you have going on. It is likely you don't have that first bead in the center of the tire or possibly a little too much air in the tube.
One thing I learned was the amount of lube is not as important as where you put the lube. When you are seating that second bead the lube really needs to be on the back side of the bead where it rubs against the rim. I see a lot of people lubing the outside of the bead but when you are mounting the tire that is not the part that is rubbing against the rim. Took me a few beers to figure that one out!
2012 WR250R
2010 Beta 520 RR
2009 DL650
2001 GasGas XC250
rsteiger is offline   Reply With Quote
Old 05-23-2013, 08:34 AM   #35697
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,796
Ryan
No point in balancing an off road oriented tire, IMO.
Fuck Bill de Blasio
MeefZah is offline   Reply With Quote
Old 05-23-2013, 09:35 AM   #35698
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,779
Balancing is a piece of cake. Use the axle and 2 jackstands. Spin the tire and add weight to the opposite side of the heavy spot. Use sticky weights.
Hate gets you nowhere.
Old 05-23-2013, 09:42 AM   #35699
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,546
I'd disagree, especially if you're running rim locks. The last one I balanced took 5 ounces in the front. Before I balanced it, it would rip the bars out of your hands over 40mph.
cjbiker is online now   Reply With Quote
Old 05-23-2013, 09:48 AM   #35700
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,395
Ditto that. Maybe a strictly dirt bike but dualsport, you need to balance it.
I put a standard rimlock on my front (that's right, ripped the stem out of the front), and the damn thing was like nearly 6oz wieghted on the rimlock side!
I tossed that idea...
Going with the Motion Pro Lite rimlocks, only 2+oz...
Best investment for balancing I've spent is the Marc Parnes balancer.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Times are GMT -7.   It's 05:32 PM.
