Old 05-24-2013, 03:46 PM   #35746
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,356
But I stand most of the time on gravel roads?
Peg concepts?????
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is online now   Reply With Quote
Old 05-24-2013, 03:53 PM   #35747
AZ TOM
Oddometer: 4,029
Peg concepts?????
Dr. Schols You be gellin
AZ TOM is offline   Reply With Quote
Old 05-24-2013, 04:44 PM   #35748
Pete-NZ
Pete-NZ's Avatar
Oddometer: 746
Originally Posted by duanew1 View Post
It looks like to me that they use the WR250F engine in those bikes so they are not related to the WR250R/X in any way.
Thats a pitty... Would have been a great bike...
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is online now   Reply With Quote
Old 05-24-2013, 05:06 PM   #35749
CJ smith
Oddometer: 23
What the fork?
[IMG][/IMG]
I've managed to get my forks apart, drained, etc. Now I'm looking at the damper rod and base valve, scratching my head with oily fingers. The service manual says something about a damper rod holder and now that I've almost completely stripped out the bottom base valve piece by attempting to just unscrew it from the bottom I'm thinking this tool must be key.
[IMG][/IMG]
So the less winded form of my question is- How do I remove the base valve and damper rod assembly and is this damper rod holder tool absolutely necessary or can it be improvised?
CJ smith is offline   Reply With Quote
Old 05-24-2013, 05:39 PM   #35750
Bogus Jim
Oddometer: 107
You can make the tool out of a piece of PVC or copper pipe. Cut 4 slots at 90 degrees to fit over the blades on the damper rod. I could post a photo of the one I made (if I can find it) if you'd like.
2012 800 XC
2009 WR250R
2008 250 XC-W
Bogus Jim is offline   Reply With Quote
Old 05-24-2013, 06:01 PM   #35751
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,356
What are you attempting to do that you need this tool for? I replaced my seals without it?
1999 Buell X1
2008 Husky TC510
Old 05-24-2013, 06:11 PM   #35752
CJ smith
Oddometer: 23
Or better yet, if you know the dimensions that'd be greatly appreciated.
I got the seals part down i think, its the replacing the lower fork leg that makes things get a little more involved. This crash is getting $$$ and Im look to avoid any specialty tool fees.
Old 05-24-2013, 07:04 PM   #35753
Bogus Jim
Oddometer: 107
This looks a little different than I remember, but I'm sure it's for the WRR. Did a revalve a couple years ago and haven't had the forks apart since.
1 inch (inside diameter) PVC pipe. The 4 pins are 1/2" long and about 5/16" wide.
If you don't have a 14mm hex to fit inside the base valve, you could use a grade 8 bolt with 14mm or 9/16" head. Put a double locknut on the bolt, then place the bolt head in the base valve and put your wrench on the locknut. Best to use a 14mm hex wrench though.
The factory puts loctite on the base valve so it may be hard to break loose.
2012 800 XC
2009 WR250R
2008 250 XC-W
Old 05-24-2013, 08:17 PM   #35754
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,356
I have in the past used ratchet straps to fully compress the fork then hit the bottom bolt with an impact gun. Make sure it's in reverse first. All you need to do is hold the inside from turning while you undo the bolt.
1999 Buell X1
2008 Husky TC510
Old 05-24-2013, 09:03 PM   #35755
pjm204
Oddometer: 2,013
Picked up my WRR tonight and I now see what all the fuss is about. The engine is silky smooth. 140 miles of highway in rain that ranged from annoying mist to full on downpour and I was still smiling.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 05-24-2013, 09:42 PM   #35756
AZ TOM
Oddometer: 4,029
[/IMG]
So the less winded form of my question is- How do I remove the base valve and damper rod assembly and is this damper rod holder tool absolutely necessary or can it be improvised?[/QUOTE]
OMG what have you done
Old 05-25-2013, 07:00 AM   #35757
CJ smith
Oddometer: 23
That is the result of months without a proper ride, waiting for parts and loosing patience- This "Get the damn thing back together and go ride" attitude is taking a toll on the poor WRR.
Thanks Jim, even if I have to make a trip to the hardware store, I'm sure some PVC & a little elbow grease is cheaper than the Yamaha tool. A 14mm hex head was what I was looking for last night but I settled for the tool that fit provided in the factory tool kit.
I might try this if I can't find any PVC, thanks.
Old 05-25-2013, 08:56 AM   #35758
Ken Mandu
Oddometer: 2
As a new guy here, can someone tell me how to make use of this gargantuan thread? It's obviously too big to read from the start! Can other threads be started that are wr250r specific, like about suspension or something?
Thanks.
Ken
Ken Mandu is offline   Reply With Quote
Old 05-25-2013, 08:58 AM   #35759
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,534
Try the WR250R Forum (google it). There's some decent info over there broken into specifics. Lots of opinions though..........
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 05-25-2013, 09:05 AM   #35760
Ken Mandu
Oddometer: 2
Thanks. I signed up over there about 20 minutes ago, under the same name. I just bought my new 2012 Tuesday in Latrobe, PA. Been about 15 years since I've been on a dirt bike, four years since I sold my Sportster. Good times ahead.
Times are GMT -7.   It's 01:55 AM.
