Old 06-12-2013, 06:57 PM   #36061
indypup
indypup's Avatar
Oddometer: 3,764
Originally Posted by cjbiker View Post
Awesome video
"Did I get ya?"
That looks pretty hardcore for a dual sport ride. Good job tossing the WR around with all those trailbikes.
Thanks, DS rides in SE Ohio are more like enduros than anything else. ;)
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 06-12-2013, 07:05 PM   #36062
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Originally Posted by indypup View Post
Video from Flint Ridge Dual Sport ride on June 9th, 2013.
I took out a KTM rider so you guys should like it! lol
Good video, how far is that from Vermillion Ohio?
bobbed06 is offline   Reply With Quote
Old 06-12-2013, 07:11 PM   #36063
indypup
indypup's Avatar
Oddometer: 3,764
Looks like about 2 hours 45 min away. Closest town to this DS was Brownsville, OH which is about 1 hour east of Columbus.
Old 06-12-2013, 07:40 PM   #36064
bobbed06
Oddometer: 1,236
Well, I may have a chance to relocate to Vermillion. Its really nice here, kinda beach feel and country all in one.
Old 06-13-2013, 02:48 AM   #36065
jon_l
jon_l's Avatar
Oddometer: 3,454
Agri Supply tool tubes on WR250
Does anyone have photos or suggestions regarding mounting an Agri Supply manual holder / tool tubes on the WR250? I bought both sizes, since shipping is more expensive than the product, and now i need to figure out how and where best to mount one of them.
I can use 3 stainless steel hose clamps to strap it to the frame, but if there is a better solution, I'd like to know.
I read once that the mounting tabs are prone to breaking off, not sure whether true in general or an isolated event. It would require a different mounting design entirely if one needs to eliminate the tabs, including preventing rotation of the cylinder when screwing/unscrewing the cap, so hopefully the tabs are secure.
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 06-13-2013, 03:42 AM   #36066
Sewerat
Cert. bike whore
Sewerat's Avatar
Oddometer: 1,390
I had mine bolted some how between the factory tool box and the helmet lock. Both wre removed. But on left hand tip overs it ended up breaking the mounts on the tube. Now not using the tube but have built a tube from abs to house my ten poles and that is gear clamped to the bike, it will be used for tools when not in camping mode.
2009 WR250R "Da Mini Bike"
1999 Buell X1
2008 Husky TC510
I ain't fully crazy, just crazy enough!
Sewerat is offline   Reply With Quote
Old 06-13-2013, 05:56 AM   #36067
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,063
A guy on here had a nice solution which basically involved a piece of nicely finished black angle irom bolted to the area where the helmet lock was. This gave a flat mounting location facing downward, and he bolted the tool tube to it, essentially upside down from the way it is shown in the quoted image.
He's on here, so he might post up.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 06-13-2013, 06:57 AM   #36068
japako
japako's Avatar
Oddometer: 592
I mounted mine, strapped to the frame where the OEM tool box was.
I also bolted the lower tab to the bike.
Worked out great for about 3 rides, and then I wrecked in some rocks and tore it off. Looking for another place now...
japako is offline   Reply With Quote
Old 06-13-2013, 07:13 AM   #36069
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,654
Does anyone have photos or suggestions regarding mounting an Agri Supply manual holder / tool tubes on the WR250?...
I mounted two, a small one underneath the larger one. Big one for a fuel bottle, small for tire irons and such.
Made a small aluminum bracket to secure it to the toolbox bracket area.
I used a Weld86 tooltube bracket. many miles and it never shook loose.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 06-13-2013, 07:15 AM   #36070
ViaADV
Oddometer: 11
Thanks Ronin!
I appreciate your taking the time to write that up. Very helpful, thank you. I'm still not sure if I'm going to sell my WRR and get a 350EXC; keep the WR and get an EXC; or keep the WR and get an F800GS.
By the way, before installing the Scotts damper, what risers did you use on the WR? I'm 6'2" and need to get my bars high enough that I can stand comfortably.
ViaADV is offline   Reply With Quote
Old 06-13-2013, 07:41 AM   #36071
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
The Scott's sub mount comes with a lower bracket / riser that lift things up quite a bit. I then mounted some Pro Taper Woods high bars and that got me enough height.
You can also get more "height" by lowering your footpeg position. As I recall the Fastway pegs have a high/ low position option. I took them off and went with Pivotpegz so I can't remember exactly. I'm sure someone here knows.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 06-13-2013, 07:47 AM   #36072
sieg
sieg's Avatar
Oddometer: 2,924
As others have said I mounted mine where the stock tool kit was. I used the passenger foot peg mount and the top tool kit mount. I used some aluminum angle for the "home made parts".
Inside view.
Note that I had to heat the bottom of the tube to dent it so it wouldn't hit the chain when the rear shock it fully compressed.
Lower mount.
Upper mount.
The saddle bag mounts protect it from a rare crash. But I don't think it would be an issue as I used it before the bags were on there. I believe it's the large size (it came on my back-hoe) and it's got plenty of room for all the tools I hope to need, plus tape, zip ties, master link.....whatever. My tube, CO2 and tire irons are in a front fender pack.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is online now   Reply With Quote
Old 06-13-2013, 07:48 AM   #36073
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,654
...hate to say it but the WR290X/R has gone to a new home...
I have a few bits left over.
Rapid Dog screwed with this post 06-16-2013 at 07:33 AM
Old 06-13-2013, 07:49 AM   #36074
coresports
coresports
coresports's Avatar
Oddometer: 327
nice video...good driving skills! funny when you pulled up to that guy in red you thought was your buddy..'wrong guy' haha
coresports is offline   Reply With Quote
Old 06-13-2013, 10:03 AM   #36075
jon_l
jon_l's Avatar
Oddometer: 3,454
Thank you Rapid. How much modifying did the weld86 mounting bracket require?
Times are GMT -7.   It's 09:29 PM.
