Old 06-13-2013, 11:30 AM   #36076
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Need Some HELP
Pulled apart my steering head and forks for the first time. After reassembly and a test drive-steering seemed too tight? ( I normally have my scott's dampener on but did not for the first test ride. I'm guessing that had nothing to do with the tight/stiff steering but thought I'd mention it.)
My guess is that I over tightened the upper and lower ring nut? The torque specs for lower ring nut say:1st 38 Nm loosen fully; 2nd 7 Nm. I used a specific made wrench for that nut so I had to hand tighten it-no torque wrench for this tool. I'm also not sure what the 1st torque spec means? Does it take 38Nm to loosen it and 7Nm when you tighten it?? Either way I plan to pull it apart and only snug the upper and lower ring nuts-but tighten the Steering stem nut to the required 120Nm.
Surer would love to hear from someone who had pulled this apart
leftystrat62 is offline   Reply With Quote
Old 06-13-2013, 11:55 AM   #36077
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,543
Originally Posted by jon_l View Post
Thank you Rapid. How much modifying did the weld86 mounting bracket require?
Bracket didn't require any mods although the mounting holes are designed to line up with somwher on a DR farme.
I used cable clamps to mount the tube to the bracket and around the WR frame rail.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 06-13-2013, 11:56 AM   #36078
DaymienRules
Traffic target
DaymienRules's Avatar
Oddometer: 197
I've always tightened the steering head up by feel. Get the front wheel up off the ground, turn the bars to the right or left about halfway, tighten until they just fall over to the steering stop. If you let go of the steering at the halfway point and it does not fall over the rest of the way, it is too tight. If it flops over, too loose.
DaymienRules is offline   Reply With Quote
Old 06-13-2013, 12:44 PM   #36079
leftystrat62
Oddometer: 999
Are you referring to the upper and lower ring nut--not the steering nut?
Old 06-13-2013, 01:38 PM   #36080
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,764
Originally Posted by coresports View Post
nice video...good driving skills! funny when you pulled up to that guy in red you thought was your buddy..'wrong guy' haha
Thanks, that guy looked almost like the guy I was riding with who was also on a Honda...lol
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 06-13-2013, 04:27 PM   #36081
DaymienRules
Traffic target
Oddometer: 197
All of it really, they're not independent of each other. No matter how tight you set the ring nut, tightening the steering nut will always make the steering tighter. So snug up the ring nut to seat the bearings in their races, back it out and re-tighten lightly enough to keep everything in place. The recommended 7nm is not very tight, so that should give you some indication of where to set the ring. Put it back together and crank down on the steering nut, it's only going to tighten so much, feel free to use the torque spec on it. Now check the steering flop as I described. If it's close, I usually adjust the steering nut a little bit to get where I want. If it's not close, then I take it back apart, adjust the ring nut to get closer and reassemble.
I'd say back the steering nut out a quarter of a turn and see how it feels.
Old 06-13-2013, 04:32 PM   #36082
Rainshadow
Oddometer: 370
Originally Posted by Rainshadow View Post
Has anybody ever used a Mountain Motor Sports Lowering Arm on their WR250R? It's a longer replacement for the Rear Relay Arm that came in 1.5" and 2.5" drops. I was in at Atomic Moto chatting with Brian and he pointed it out on my new to me WRR. Looks like they are out of business now. We searched for a bit but didn't find much about them.
So anybody have a Rear Arm Relay (the "L" shaped piece that the rear swing arm and dog bones connect to) lying around that they want to get rid of? I want to get my bike back to stock height and the person that I bought it from didn't have the original Rear Arm Relay. The Mountain Motor Sports lowering arm makes the bike about 1.5" lower than you can get it with a just a Yamalink. You can use both the MMS relay and the Yamalink (it's how my bike came set up) to get the bike really low.
I'd be willing to do a straight swap with someone if they wanted to lower their bike even more than just a Yamalink.
Rainshadow is offline   Reply With Quote
Old 06-13-2013, 04:36 PM   #36083
leftystrat62
Oddometer: 999
Thanks so much for the reply-that sound very helpful. Cheers
Old 06-13-2013, 06:35 PM   #36084
Off Road USA
Off Road USA's Avatar
Oddometer: 140
Rainshadow, I have that L piece left over from when I lowered mine , it's just collecting dust. your more than welcome to it
Off Road USA is offline   Reply With Quote
Old 06-13-2013, 07:19 PM   #36085
japako
japako's Avatar
Oddometer: 592
rainshadow, now that you have a stock link, what would you want for the lowering link?
japako is offline   Reply With Quote
Old 06-13-2013, 07:19 PM   #36086
ViaADV
Oddometer: 10
Thanks Ronin. In looking at the photos you posted of installing the Scott's damper on your WRR, it looks like you had the Contour Pantrana FMX bars at one time. In looking at the Protaper website, the Pantrana FMX are 121MM tall and the Woods are 95MM tall. For my height, I'm leaning toward getting the Pantrana FMX.
Also, I'm not purchasing the Scott's damper at this point so I'm not sure the Scott's sub mount will work for me?
Thanks for the lean on Pivotpegz. I'm on the hunt for new pegs, so I'll take a look at these too.
Originally Posted by Ronin ADV View Post
The Scott's sub mount comes with a lower bracket / riser that lift things up quite a bit. I then mounted some Pro Taper Woods high bars and that got me enough height. You can also get more "height" by lowering your footpeg position. As I recall the Fastway pegs have a high/ low position option. I took them off and went with Pivotpegz so I can't remember exactly. I'm sure someone here knows.
ViaADV is offline   Reply With Quote
Old 06-13-2013, 07:29 PM   #36087
ViaADV
Oddometer: 10
One more question on raising the bars: Anyone know if the stock cables have enough length to accommodate the Pro Taper Contour Pantrana FMX bars w/a riser? Thanks!
EDIT: I think I found the answer searching through the thread back at #35382. If one can install ProTaper bars with 4" of rise (Windham/RM MID bend) plus have the Rox 2" risers and not have to replace any cables or wiring, I should be good to go!
ViaADV screwed with this post 06-13-2013 at 08:09 PM
Old 06-13-2013, 09:10 PM   #36088
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
My bad. You are right. I have the Pastranas on my WR and the Woods Highs on my EXC. Both have Scott's dampers.
So yeah you can get risers and Pastranas on the stock WR cables. Sorry about the confusion.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 06-13-2013, 09:45 PM   #36089
Rainshadow
Oddometer: 370
That's awesome! Sent you a PM.
I have no idea why Yamaha has this part listed as obsolete as every wr250r ever made has one right in the heart of the rear suspension.
Thanks again!
Old 06-13-2013, 11:16 PM   #36090
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,478
Overall:
Which is the “better” bike? I think this question is fundamentally flawed as they are slightly different tools. I like to think of the two as the difference between a racehorse and a packhorse.
The WR is smooth and reliable. It’s comfortable to ride and has long service intervals and a heavier sub-frame. If I was going on a tour or out in the middle of nowhere for a longer time, I would take this bike. Dependable, solid, packhorse.
On the other hand the EXC is a grin producing, powerful ride. It just begs to go faster, to loft the front, to push things a bit more. For day rides, especially in harder stuff (except maybe slow first gear stuff like rock crawling), this is the bike. In fact, once I started riding my EXC I thought I would sell my WR. Then I got back on the WR and realized what a good bike it is. Each has its place and you have to decide what are your individual priorities.
For me at this time, I’m keeping both
(Obviously the above is just my opinion. If you don’t agree with me, that’s cool. Just don’t get your knickers in a twist because you think I insulted your bike.)
Nice write-up pretty much sums up my comparison of my WR (Pretty much same setup) and my 2004 KTM 450 EXC. I thought the KTM would be suck on the pavement getting to dirt roads, but it's really not that bad, and the power makes it a lot more fun. But if I want to go overnight or serious dirt miles the WR is better. Also lots of little things make the WR a more refined bike for light touring. But for day rides blasting around, the KTM is great. Dried up mud puddles and an ATV trails I rode were so much better on the KTM than the WR. Might have been my suspension set-up but the KTM is more dirt-bike feeling than the WR.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Times are GMT -7.   It's 05:05 AM.
