Old 07-01-2013, 06:31 PM   #36316
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
Originally Posted by Quantis View Post
I hereby submit my question to the collective wisdom of the megathread...
I have an '09 WR250x. I recently changed the oil and filter using Kawasaki S4 Synthetic 10W-40 oil like to this
Since that I have ridden ~ 1000km over the past weekend. All easy on secondary roads through NY and VT.
Now I'm finding that my clutch is occasionally super grabby. I'm used to the usual grabbiness but this is ridiculous and I've accidentally launched myself through intersections. The strange part is that this only happens 1 in 10 starts.
Also, I occasionally hear some noise/vibration from the engine when letting out the clutch but when I hear the noise is not when the clutch is grabby.
Any ideas? Change the oil brand? Run some sort of engine flush? Replace clutch plates?
Thanks for your feedback!
Adjust your clutch cable.
Hate gets you nowhere.
Old 07-01-2013, 06:47 PM   #36317
Quantis
Quantis's Avatar
Oddometer: 247
I checked it. Little to no slack. Still doesn't explain why it's only grabby occasionally.
Blog: www.Quantis.ca | I take photos: www.fasttrackphoto.com
RR: Trans Tiaga / North Road | RR: Making the TCAT | RR: Moab 2012 |
Quantis is offline   Reply With Quote
Old 07-01-2013, 07:34 PM   #36318
TwilightZone
Oddometer: 3,158
>"I have an '09 WR250x. I recently changed the oil and filter using Kawasaki S4 Synthetic 10W-40 oil like to this"
Well, the easy thing is change the oil.
I'd try the the non-synthetic Rotella and see what happens.
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 07-01-2013, 07:42 PM   #36319
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,741
Same thing happened to me and HighFive asked if I had changed the oil recently and to a different brand.. I said "YEP".. after changing the oil again back to what I had used before.. the problems went away.. I'm using Rotella T 15W40 and now clutch is smooooth!!
I've used SuperTech and had no issues, Rotella T no issues.. but when I used a Castrol oil rated for wet clutch.. the WRR did NOT like it!
Also.. I too.. thought it was my clutch cable slack/adjustment was out of wack.. but it was all related to the oil...
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 07-01-2013, 09:13 PM   #36320
hamish99
hamish99's Avatar
Oddometer: 78
Headlight replacement
Baja Designs has a replacement lens for $44.95
http://www.bajadesigns.com/products/...cle-headlights
I've replaced my headlight a couple of times with this one due to rocks, wrecks....
Bill T.
Originally Posted by AKoffroader View Post
Hello fellow WR riders. I got hit with a rock in the headlight that broke the lens.
Just wondering if anyone out there went to an aftermarket headlight and might have a stock headlight they would be willing to sell.
Yamaha only sells is as an assembly and wants too much for it.
Thank you,
Greg
hamish99 is offline   Reply With Quote
Old 07-01-2013, 09:20 PM   #36321
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,470
I recommend once you get a new light you do this
Perspex Thick it will take a large hit and survive ..I use Velcro dots to stick it on and it stays there no problems
Sean-0 is online now   Reply With Quote
Old 07-01-2013, 10:15 PM   #36322
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,960
Is anyone else thinking Sean-O is having more fun farkling and modifying that bike than Zac
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is online now   Reply With Quote
Old 07-01-2013, 11:36 PM   #36323
Jäger
Osons
Jäger's Avatar
Oddometer: 803
Jäger is offline   Reply With Quote
Old 07-02-2013, 12:38 AM   #36324
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 1,098
registration sticker we need here for rd use
Mine lasted one ride in that position and the casing got smashed, then I stuck it on the fork.
Reeksy is online now   Reply With Quote
Old 07-02-2013, 04:27 AM   #36325
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,832
+1 more on the Rotella T 15w40. It makes my WR shift smooth as butter and gives it great clutch action. Mobil 1 10w40 synthetic motorcycle oil worked well too, but not as nice as the Rotella. Valvoline 10w40 motorcycle oil was terrible, notchy shifting and a grabby clutch.
cjbiker is offline   Reply With Quote
Old 07-02-2013, 04:29 AM   #36326
Quantis
Quantis's Avatar
Oddometer: 247
Thanks for all the oil recommendations. I'll Grab some Rotella-T and give that a try.
Old 07-02-2013, 05:09 AM   #36327
indypup
╭∩╮( º.º )╭∩╮
indypup's Avatar
Oddometer: 3,764
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 07-02-2013, 07:59 AM   #36328
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,621
Originally Posted by indypup View Post
Awesome - Looks like fun. Lots of "Orange" bikes out there - way to represent "Team Blue".
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 07-02-2013, 08:01 AM   #36329
coresports
coresports
coresports's Avatar
Oddometer: 319
i never see anyone recommending yamalube on here which i always run. used it in my xt for 10 years with no clutch or engine issues, using it since break-in on my 08 wrr and i don't plan on changing. synthetic oil is still petroleum based oil, just refined a bit more. my last car hit 300k on regular oil. just sharing my experience. YMMV
coresports is offline   Reply With Quote
Old 07-02-2013, 08:32 AM   #36330
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,306
I have been using Yamalube in my WRR too, since I got it. Oddly enough, I use Motul or Silkolene in my Suzuki SV1K, And Motul/Belray(gearbox) in my KTM 300 EXC.
I guess new bike, I just chose to stick with factory oil....in case...I had any engine issues.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Times are GMT -7.   It's 02:19 PM.
